Old 06-13-2010, 02:36 PM   #61
Midnightventure
Oddometer: 743
I bought their AC Manifold tester and the second time I used it one of the plastic knobs broke.
Midnightventure is offline   Reply With Quote
Old 07-07-2010, 08:32 AM   #62
hangontight
Rider
Oddometer: 108
harbor freight orbital sander...blew out the air seals within 10 minutes (in all fairness I might have not regulated the pressure off the compressor low enough)
I DON'T ROLL ON SHABBAS
hangontight is offline   Reply With Quote
Old 07-07-2010, 12:25 PM   #63
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,256
I found their electric one to be great. I have used it for at least 40 solid hours with zero issues.
Jim
Old 07-07-2010, 12:35 PM   #64
Bobthebiker
not normal
Oddometer: 493
I've used a few things from them. notably their air horn when I had my samurai and NEEDED a louder horn. got a lot of troublefree use from that horn.
my friend has their wire welder, and stick welder, the wire welder SUCKS, but the stick makes pretty nice welds, and they've got several lifts and motorcycle jacks from there, all working just fine.
compressors though. buy quality brands, just trust me.
I've read great reviews though on the gas engines they sell, frm 3-13hp. they're honda clones and I'm seeing people have built the 6hp horizontal shaft models into 14hp and run reliably. I'm picking one up soon as I can for my big compressor, which is more or less a mobile sandblasting machine.
Where does this road go? screw your maps! we're gonna find out the FUN way!
error 404: common sense not found.
Bobthebiker is offline   Reply With Quote
Old 07-07-2010, 02:47 PM   #65
JimVonBaden
"Cool" Aid!
Oddometer: 52,256
Get him to use a better quality wire, like Lincoln wire from Home Depot. It works MUCH better.
Jim
PS It is half the cost of HF wire.
Old 07-07-2010, 04:02 PM   #66
Bobthebiker
not normal
Oddometer: 493
Didnt know that, thanks for the tip. it'd help if we knew how to USE the wire welder better too. the stick is easy for us.
Old 07-07-2010, 08:10 PM   #67
JimVonBaden
"Cool" Aid!
Oddometer: 52,256
I'm far from an expert, but that simple change in wire made a huge difference in my ability to successfully weld!
Jim
Old 07-13-2010, 10:58 PM   #68
jamesgs4
jamesgs4's Avatar
Oddometer: 480
Originally Posted by BWJ
I have gone through lots of HF tooling. I had a prybar with a plastic handle shattered on the first wack. I also broke a 3/8" drive allen key socket on the first use when torquing down my triple tree clamps. My die grinder has been used and abused and was a good $8 investment. Got a decent bench vise for a good price and my $5 multi meter works like a champ.
You should have bought the w(h)ackbar instead of the prybar, then it wouldn't have shattered. duh
jamesgs4 is offline   Reply With Quote
Old 07-14-2010, 01:32 PM   #69
HuckFarley
Oddometer: 60
Imagine the job security you would have working in the HF returns department!
HuckFarley is offline   Reply With Quote
Old 07-16-2010, 12:24 PM   #70
groundrules
groundrules's Avatar
Oddometer: 1,715
harbor freight is like a disease. I just succumbed and got one of these. diggin' it so far:
groundrules is offline   Reply With Quote
Old 07-16-2010, 01:06 PM   #71
hugemoth
hugemoth's Avatar
Oddometer: 2,842
$20 reciprocating saw chewed up it's gears within an hour of use.
$36 bench top drill press chuck came apart internally after a year. Ordered a replacement part for under $10 including shipping, working fine after 3 more years.
Box of various size hose clamps are crap.
Zip ties are crap.
Cheap rotary tool is worthless.
Compressor working fine after 3 years.
Bench grinder A-OK after 3 years.
Combination wrenches made in India are fine.
Screwdrivers are OK.
Zippo lighter copy is fine.
Handwarmer (lighter fluid type) better than name brand.
Digital thermometers A-OK
Cheap simple pop riveter A-OK, more expensive twistable one junk.
Safety goggles A-ok
Flux welder, welding apron, gloves, self darkening helmet A-OK
Saber saw A-OK
3/8 hammer drill A-OK
1000 watt 4 stroke generator failed after 2 years, stuck valve.
Bolt together trailers are A-OK
99c stainless steel pocket knife is good
$2 Multimeters are good.
Rechargable batteries are good.
Old 07-17-2010, 11:22 AM   #72
BOBaloo22
RIP Baby Girl
BOBaloo22's Avatar
Oddometer: 3,783
I got the air powered grease gun the other day looks great but I cant seem to get it to "pick up" the grease. The 1 sheet paper instructions say to burp to purge the air out so I guess I will try again. Am I wasting my time? Anyone else have good luck with one of these?
Thanks,
Bob
89 Transalp-98 FXDWG
AMA member
BOBaloo22 is offline   Reply With Quote
Old 07-17-2010, 11:39 AM   #73
hilld
riding isn't an addiction
hilld's Avatar
Oddometer: 268
Thanks,
Bob
I think I found your answer, it was on the review of the gg on HF's site. Not my solution.
---quoted---
Not bad, but may need a slight modification. Review by Thomas
This item would work great for bulk grease. I needed it for cartridges...
I bought one and exchanged it, it didn't work with two good quality cartridges. Got the second one home, same problem. Took apart the grease section of the gun (with a HF air ratchet) and noticed that the rubber piston lip is too large for a cartridge. I checked the hand gun I have and it has a smaller diameter plunger. I trimmed the lip around the circumference a bit with a razor scraper (don't take off too much- you want it snug in the cartridge body), reassembled and it fired grease on the second shot. My hand grease gun is going to be very lonely now. I don't suggest more than 3 pumps on this thing into a ball joint, you can burst rubber seals. Keep an eye on the seal as you pump.
With all the discounts, it was worth it to me and I kept it even though I had to modify it. Other stores want twice as much for pretty much the same tool. If you oil these air tools they will have a very long life.
(Posted on 5/28/10)
Every day is a new day
hilld is offline   Reply With Quote
Old 07-19-2010, 10:26 PM   #74
Sucks2drive
Sucks2drive's Avatar
Oddometer: 3,479
I buy what I need to use for a particular job from HF......like say a Cordless drill or a wlve tool.......then you have 30 days to return it for ANY REASON. if it breaks within 30 days i get money back or a new one.... if it breaks within 90 days, store credit or exchange.
Never a quibble..... cant say fairer than that.
Sucks2drive is offline   Reply With Quote
Old 07-20-2010, 06:51 PM   #75
Jimbozini
Misadventurer
Jimbozini's Avatar
Location: The Church of the Twisty Road - East Tennessee
Oddometer: 435
Thumbs down
Total garbage, HF Haul-Master Motorcycle Swingarm Rear Stand and Front Fork Adapter
On first look, this appeared to be of acceptable quality and capable of doing the job. In reality, it was incapable of performing its intended function and is downright dangerous to use. First off, the wheels were not in alignment with each other making it impossible to lift the bike and remain level. Secondly, the "prongs" on the fork adapter started to bend when the weight of the bike was applied during the lifting operation!
I was only trying to lift a YZF600, not a fully laden Harley-Ferguson!
Needless to say, these two fine examples of Chinese craftsmanship went back to HF and I picked up an overpriced Made-In-the-USA Pit Bull front stand to compliment my existing Pit Bull rear stand. There is something to be said about a quality product that performs its designed function!
-Jim
TiMe WaRP vINtaGe mOTOrCyCLe cLuB
Moto Images
$5 off on a Smugmug accout Use this coupon code: LlVtvdPX4gIjg
Jimbozini is offline   Reply With Quote
Times are GMT -7.   It's 11:02 PM.
