09-21-2010, 11:35 AM
#16 |
The Chameleon
Oddometer: 745
Any update on the Traxxion solution?
I need to do something about the suspension for even the most mild of offroad adventures....
Gumbeaux |
09-21-2010, 01:27 PM
#17 |
Oddometer: 234
Here's from an e-mail thread (09/21/2010) I've been having with Dan at Traxxion on this very topic.
question from jscottyk ...curious where things stand with the latest fork caps that allowanswer from Dan We do have the fork caps ready. With the new caps, one fork is adjustablefor rebound, and one fork is adjustable for compression, and both are preload adjustable. Note that this setup differs from the setup on some of the OEM forks on bike like some new Triumphs and the new FZ1, which literally have a rebound piston only in one fork, and a compression piston only in the other. This is our normal AK20 cartridge, with a rebound AND compression piston in each fork. follow up question from jscottyk One follow up question, what's the reasoning behind rebound and compression damping in both fork legs, but adjustability for one/another in each? Is this a limitation of the fork cap?answer from Dan It is a limitation of the fork cap. Most compression adjustable forks have an adjuster in the bottom of the fork, and rebound at the cap. There is no easy way to add compression adjustability at the bottom. And there is no easy way to have both C+R in the cap in a fork with a standard cartridge. Generally, our compression/rebound at the cap will provide more than sufficient adjustment range if the forks are valved properly. The rebound only in one leg comp only in the other setup does not have enough piston area for proper tuning. It is hard to get the firm low speed, softer high speed for bump absorption with a single small piston. The Showa Big Piston Forks (rebound one leg, comp other) work like that, but they have BIG PISTONS, hence the name. follow up question jscottyk So for the rebound or compression valving that is in the non-adjustable leg, is it set in the middle of it's range?answer from Dan Yes. Its set to what would be the middle of adjustment. The compression leg is pretty interesting. It was one where the tech actually had a dream about the fork and came up with the idea in his sleep. He was unhappy with the single piston setup but wanted fully adjustable forks for his SV650 racing buddies. |
09-21-2010, 09:43 PM
#18 |
How hard can it be?
Oddometer: 551
Looks like the Traxxion site is down for maint. so how much do these go for? I'm a noob but I'm starting to notice the front suspension diving a lot. Wouldn't mind an upgrade.
![]() Never mind, got on their site. $1100, bit much.....but needed.
I'll have one if you do.....
09-21-2010, 11:18 PM
#19 | |
Oddometer: 2,145
09-22-2010, 01:08 PM
#20 | |
Flame Bait
Oddometer: 937
09-22-2010, 11:17 PM
#21 | |
Oddometer: 2,145
11-24-2010, 04:10 AM
#22 | |
seaswood
With the Traxxion Caps the numbers are slightly different because of the cap length but they all equal out. The bleeders would not eliminate the preload adjustment. The caps would have Spring Preload on both sides, Rebound on the right and Compression on the left. Both caps would have the bleeder valve as well. Preload Spacer 215mm Oil Level 115mm (125/150 7wt Maxima Oil) Compression Valve 2 turns out (3 total Turns) Rebound Valve 2 Turns out (3 total turns) Preload set 7 turns in (15 total turns) Price 1249.99 $ 1299 for bleeders. Pricey but it is a proper fix . You can install yourself or they will do it for 150$ ![]()
1200GSA /7/2 |
12-22-2010, 09:08 PM
#23 |
Oddometer: 730
Ok, heres a query. If you were to use a dirt bike fork on a dual sport bike (f800 etc), change the travel (possible), change the spring length and rate (possible) what about damping? As said earlier I think dirt bikes (high speed) road ish bikes (low speed) damping. If the valves are set for high speed what happens when oil weight for a road ish bike is added? Is there a problem with the oil flowing through other parts of the fork?
If ignorance is bliss, why aren΄t more people happy?????
12-22-2010, 09:46 PM
#24 | ||
Flame Bait
Oddometer: 937
One thing to understand is that, while the high speed damping is stiffer on a road bike (that sees less big hits and has less travel) than a dirt bike, there's nothing inherently different between the internals of a street and dirt suspension--its just the specific tuning that's different. Different shim sizes and shapes, different shim stack profiles, sometimes different piston orifices/geometry...but that's about it. You could tune a sportbike to be as plush as a dirtbike off road (up until it bottomed out its 4" of travel), and you could tune a dirtbike to be as stiff and controlled as a track bike (but you would use a fraction of its 12" of travel). |
12-22-2010, 09:47 PM
#25 |
NoMoTDM still Gary
Oddometer: 3,711
If you are looking for the best set up for a bike for both street and dirt, the best you are going to get is a compromise.
Cartridge forks are typically set up with certain terrain, weight and rider skill in mind. To achieve that, a spring rate is determined and a particular valve shim pac is chosen that will work best with a limited range of oil viscosity. Most good cartridge forks have adjustments that the rider can change to slow or allow more flow through the valves on both compression or rebound, some even allow separate adjustment for low and high speed flow. Changing the viscosity has minimal good effect, it may even be detrimental causing the opposite of what you are trying to achieve. A small change may extend the range of adjustment available to the rider. Once the internal parts are chosen, you are limited to the external adjustment for compression and rebound with some forks having more than others. I think most riders find that sufficient, because if you are starting with a dual sport bike, suspension is not going to make it competitive with a race bike anyway. Bxr140 you are too quick for me tonight. See anything that contradicts you?
BMW Motorrad USA customer service: "We make superior motorcycles and continue to improve them." itsatdm screwed with this post 12-22-2010 at 09:53 PM |
12-22-2010, 10:37 PM
#26 | |
North Forest Rider
Oddometer: 3,622
12-22-2010, 10:52 PM
#27 |
Flame Bait
Oddometer: 937
12-23-2010, 06:29 PM
#28 |
Oddometer: 963
I spend almost that much on my Shiver 45 swap and I'm still not 100% with them. If I were to do it again, I'd just get an off the shelf solution.
12-23-2010, 07:14 PM
#29 |
North Forest Rider
Oddometer: 3,622
Good info.
12-23-2010, 07:21 PM
#30 |
Reseda, CA
Oddometer: 3,489
Bitubos still kicking ass. Just sayin'...
Rebuilt only once and about 13,000 miles on them now.
http://johngil.whereamiriding.com johngil screwed with this post 12-23-2010 at 07:32 PM |
