Old 06-27-2011, 09:45 PM   #61
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,486
Whatever success you have up front may be negated by the Ohlins in the rear. Sad, but true.
Better than stock, but not a great solution for the price.
johngil is online now   Reply With Quote
Old 06-27-2011, 10:33 PM   #62
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,486
Originally Posted by ChiTown View Post
Are you still sore about your bent frame with an Ohlins' on your bike?
Not at all. The other aftermarket (and stock) shocks will produce the same results if not dealt with properly.
For the money, there are much better shocks out there when the overall ride and adjustability are factored in.
At least they (Ohlins) look cool.
johngil screwed with this post 06-27-2011 at 10:44 PM
Old 06-27-2011, 10:57 PM   #63
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,486
They will work on anything. They are in business to make $$$ like the rest of us.
Old 06-28-2011, 09:16 AM   #64
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 1,989
What did you end up with Johngill? Hyperpro or other?
Gangplank is online now   Reply With Quote
Old 06-28-2011, 09:49 AM   #65
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,486
Elka 3 way
Old 07-25-2011, 05:39 AM   #66
HighFive
Bike-aholic
HighFive's Avatar
Oddometer: 2,060
Traxxion all fixed
Think I got my problems sorted out with the Traxxion. Long story short, using 5wt oil and setting the level at 95mm from the top fixed it. The adjuster range is working well now for both C & R, and the fork only bottoms out (lightly) on the hardest of landings......which is what I want. Fork action feels great everywhere, in all scenarios.
My final oil height is higher than most recommended settings (which are 110 - 115mm range). The Traxxion tech (Dan) confirmed not to exceed an oil height of 90mm. I got mighty close to that before I was satisfied. Anyway, no more blowing thru the stroke on hard landing. Now, the damping action feels right....very progressive to a stop. There just wasn't any stop before. It would bottom out on the internals. Even 100mm didn't stop it. When I brought the oil level up to 95mm, it was magical.
Thanks for the input, Indy. Good advice! Its a bit of a PITA to do this correctly. I had to secure the right tools, and make several roundtrips on & off the bike to incrementally figure this out.
Now, I've got to work on dialing my Ohlins in tighter. Its still bucking me a good bit on rebound at the max setting. So, I'm not there yet...
HF
HighFive is offline   Reply With Quote
Old 07-25-2011, 06:15 PM   #67
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,120
Yeah you need to play with the settings, oil level and oil weight to fine tune the Traxxions for your riding style and terrain.
I have no complaints with their tech support and the beauty of these is once you got them where you like them they just last and last and remain consistent. I just wish BMW had some thing like this stock. I have developed a Traxxion AK-20 set up and an Elka 3 way custom rear shock for my buddies highly modified Versys ( 8" suspension travel on both ends) and I am very impressed with the Elka quality and adjust range!
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited screwed with this post 07-25-2011 at 09:13 PM
Indy Unlimited is offline   Reply With Quote
Old 04-12-2012, 12:46 AM   #68
mungus
mungus's Avatar
Oddometer: 92
Question Custom cartridge?
Was this a fully customised job? Can't see anything listed for the F800GS on their website.
Did they say if they are building any more?
"I did not have sexual relations with that woman"
mungus is offline   Reply With Quote
Old 04-12-2012, 06:14 AM   #69
Indy Unlimited
Oddometer: 1,120
They will build them Just call and ask for the F800GS kit with our ADVrider team developed set up.
The AK-20 cartridge product is great and will last and last compared to pressurized gas units.
Here is the latest set up that works great with the Traxxion Dynamics AK-20 Kit:
Preload spacer length 225 mm
Oil level 100 mm using 5 wt fork oil
Springs 0.60 kg/mm x 310
mm long
Range of adjusters is 4.5 turns
Cartridge valves set at C 3 R 3
New fork caps with preload adjustment and compression adjustor on one fork and rebound adjustment on the other fork cap
custom tools for install and service
Spec all that when ordering the kit and get the custom tools for $100 from Dan Anderson at Traxxion Dynamcs.
Current Stable:
Indy Unlimited screwed with this post 04-12-2012 at 03:30 PM
Old 04-12-2012, 03:19 PM   #70
mungus
mungus's Avatar
Oddometer: 92
Question Ok
Thanks for the info. Good to hear there is a real alternative to the Ohlins NIX or TTX cartridges.
Being in OZ I won't be sending my forks to the USA, I'll buy the optional fitting kit instead.
Any idea of price?
mungus screwed with this post 04-12-2012 at 03:26 PM
Old 04-12-2012, 03:28 PM   #71
Indy Unlimited
Oddometer: 1,120
I have done the AK-20 kits myself on other bikes on this forum. Piece of cake to install.
The first few we had to send in while they developed the fork caps and fit.
The kits run around $1,050. US plus some custom tools for $100. that are handy.
Current Stable:
Old 04-13-2012, 03:03 PM   #72
mungus
mungus's Avatar
Oddometer: 92
Wink Thanks
Thanks. They got back to me; $1,199 and a couple of days to get a kit ready.
They have moved on from your specs apparently. And now offer 3 setups; "hard core" off road, ADV tourer and street.
They should be quite an improvement over OEM, being fully adjustable and rebuildable, etc.
I wish there was some comparison with the Ohlins kits was available though.
Its 2/3rds the price, but don't hear much about their plushness or ride quality etc...
mungus screwed with this post 04-16-2012 at 05:59 PM
Old 08-02-2012, 07:30 AM   #73
machinebuilder
Oddometer: 691
Talking WOW what a difference
I have just installed my forks with the AK-20 kit
Currently Traxxion Dynamics offers 3 different setups
1. street oriented
2. "adventure touring" 90%street 10% dirt
3. "hardcore" offroad
the main differences seem to be spring rate.
I decided to go with the off road setup. My riding tends to be about 70/30 but the dirt is usually not smooth.
Because of the amount of time I've been spending at work I removed the forks and sent them to have the kit installed.
over the phone I was told they are running a 1 1/2 week turnaround, they finished them in 8 days from when they received them, and it took me 2 evenings to install (because my smaller torque wrench was at work).
Last night I had time for a short ride, only 1/4mi dirt.
I can tell a huge difference, the brake dive is minimal, the bike feels much more solid in the front without jarring me through the handlebars. I can't wait to get a better ride in.
Now I can tell the shock sucks too, over minimal bumps the rebound is very fast. I have a wilburs shock on order, I can't wait.
the top caps have adjustments
2009 BMW F800GS NON ABS
the best thing to buy for your bike is gas.....Neduro
Remote is not found on the coffee table.......seen on a T Shirt
machinebuilder is offline   Reply With Quote
Old 08-02-2012, 05:37 PM   #74
Indy Unlimited
Oddometer: 1,120
Most of us spending this kind of money fit into the last category! Hardcore off road freaks!
Current Stable:
Old 08-03-2012, 07:47 AM   #75
machinebuilder
Oddometer: 691
I will never say I'm a Hardcore off road rider, freak is a different story.
My thought was since I'm not pushing myself to the bikes limits on pavement I want the biggest improvement off pavement.
the $$$$$ was just to get something I think will fix the problems......without introducing several more.
It looks like the first good test will be Sunday, I hate when work interferes with fun, but it does make buying toys easier
Times are GMT -7.   It's 10:56 PM.
