Old 06-11-2010, 09:31 PM   #61
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,260
ah the old headlight disable connector! well, you can't go around disconnecting the headlight disable connector... really, um, because, um... what the headlight disable connector?
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 06-17-2010, 08:22 PM   #62
Low594 OP
Adventuring Creep
Low594's Avatar
Oddometer: 1,160
Laugh Excellent Day!
Just picked up my motor from Greyhound! Thanks Sanjoh! Here's to another late night in the garage before going to work!
Low594 is offline   Reply With Quote
Old 06-17-2010, 10:55 PM   #63
Low594 OP
Adventuring Creep
Low594's Avatar
Oddometer: 1,160
Well, not too late after all, but the motor is in place and torqued down. Resuming after work tomorrow! Thanks go to Panda! and my Dad for the encouragement to get just a bit further! Thanks you two!
Low594 screwed with this post 06-25-2010 at 06:05 AM
Old 06-18-2010, 05:44 AM   #64
Laromonster
Vesperado !
Laromonster's Avatar
Oddometer: 1,335
you work fast
'99 Road king
'09 XR1200
Laromonster is offline   Reply With Quote
Old 06-18-2010, 06:33 AM   #65
Low594 OP
Adventuring Creep
Low594's Avatar
Oddometer: 1,160
I've been waiting months to get closer to a running bike!
Old 06-19-2010, 11:42 PM   #66
Low594 OP
Adventuring Creep
Low594's Avatar
Oddometer: 1,160
She lives! Still need carb adjustment and bleed the brakes, but she starts up and runs!
A few other things to do before riding, like finishing the funky fuel line routing, aux power plug and turnsignals.
Old 06-22-2010, 07:23 PM   #67
motorjon68
motorjon68's Avatar
Oddometer: 433
I'm waiting.
Do you know what "nemesis" means? A righteous infliction of retribution manifested by an appropriate agent. Personified in this case by an 'orrible c*#t... me.--Brick Top, "Snatch"
motorjon68 is offline   Reply With Quote
Old 06-22-2010, 11:14 PM   #68
Low594 OP
Adventuring Creep
Low594's Avatar
Oddometer: 1,160
Well, third day out on her today and starting to get the hang of a single, carb tuning is a little more difficult/finicky than a twin or 4! Really getting her dialed in, riding today to the Bay Area meetup @ Sams BBQ was pure joy, not just the ride, but meeting other locals! Im looking forward to dirt time!
I tryed to bleed the brakes, front went fine a little dirty and some water, but all clean! The rear didn't go so well, due to the pin hole in the line!
Just got to figure out what is up with the IMO! MPH is almost double! and the options in the wheel menu dont scroll like in the manual! Good thing I have the GPSr!
The dash lights are another annoyance! The high beam indicator work fine, the neutral & turn indicators I have only seen work while on the center stand, but I have yet to confirm they are consistant. Not huge concerns, I can see the turn signals and most of the bikes I've owned never had turnsignals or neutral lights!
Low594 screwed with this post 06-25-2010 at 06:07 AM
Old 06-25-2010, 06:13 AM   #69
Low594 OP
Adventuring Creep
Low594's Avatar
Oddometer: 1,160
Well, last night I opened her back up! And started work, removing the stock coil and finding a suitable location for the upgraded coil that the Ignitech TCIP4 needs! This ignition is programmable and has alot of features I could use at a later date, like shift light and control relays. Once I get the coil in and the wiring redone, then its off to MotoLab to see Derek for DynoTuning! I'm really looking forward to what the bike will be like with the better ignition mapping, dialed in carb and Dyno time!!
Old 06-25-2010, 09:18 AM   #70
Gerst
Gerst's Avatar
Oddometer: 253
Sounds like fun! Wish I had a dyno tunner close by. Will she be ready for WF?
Gerst is offline   Reply With Quote
Old 06-25-2010, 12:07 PM   #71
Low594 OP
Adventuring Creep
Low594's Avatar
Oddometer: 1,160
The bike will be ready, its paying rent that is in question!
Old 06-25-2010, 03:32 PM   #72
overlandr
Dystopist
Oddometer: 5,926
wf?
overlandr is offline   Reply With Quote
Old 06-25-2010, 04:00 PM   #73
Low594 OP
Adventuring Creep
Low594's Avatar
Oddometer: 1,160
You're welcome to come out to the West Side for a visit and borrow mine!
He's known here as motolab
Originally Posted by overlandr
wf?
Also known as WestFest2010 roughly 900 miles 1 way ride.
Old 06-27-2010, 10:16 PM   #74
Low594 OP
Adventuring Creep
Low594's Avatar
Oddometer: 1,160
@ the ADVRider Bay Area Meet Up, last Tuesday!
Old 06-27-2010, 10:31 PM   #75
Low594 OP
Adventuring Creep
Low594's Avatar
Oddometer: 1,160
Here's the platform I had welded to the roadbook mount and then attached the RAM mount for a camera/video/etc & mounts for the GPSrs, yes there are 2, 1 for road nav and 1 for trail nav
And the tab that was welded on for power using Boschs version of a surface mount BMW style plug.
Times are GMT -7.   It's 06:17 AM.
