Old 04-22-2012, 09:34 PM   #1501
SaharaJp99
Oddometer: 370
Originally Posted by radon222 View Post
Just a heads with the Cardo BTAs. They do work ok but you will have to go through the pairing process every time you power up the up the Sena.
Why would that be? The manual on the BTA says it remembers a pairing, and I know the Sena does. Why when powered up wouldn't they pair up automatically?
SaharaJp99 is online now   Reply With Quote
Old 04-22-2012, 10:11 PM   #1502
FireIdiot
Lost in translation
Oddometer: 82
I have the earbud clamp mount on my helmet for about 2 months. It now is very intermittent with the audio and the jack is loose. I assume from setting my helmet on flat surfaces. Anyone else had this issue? I wonder if Sena will warranty it ?
FireIdiot is offline   Reply With Quote
Old 04-23-2012, 02:29 AM   #1503
radon222
1150GS-ADV
radon222's Avatar
Oddometer: 323
Send a message via AIM to radon222 Send a message via Yahoo to radon222
I have to apologize... it was the Camos BTA that I tried and had re-pair constantly, not the Cardo. Maybe I'll give the Cardo a try too
'05 R1150GS Adv
'12 R1200RT (Wifey's bike)
radon222 is offline   Reply With Quote
Old 04-23-2012, 07:30 AM   #1504
SaharaJp99
Oddometer: 370
Yes and yes, on my 3rd earbud clamp mount. They will warranty them. I can't believe they haven't re-designed them yet.
Old 04-23-2012, 07:52 AM   #1505
AlecMyrddyn
Oddometer: 140
For anyone who had the Intercom dropping problem since upgrading to 4.0: my 4/17 update to 4.0 seems to have done the trick. Took a nice ride this weekend with my girlfriend, and the Intercom ran the whole trip, never dropped once.
My final comments to Sena on the support case included a copy of the 4.0 file I downloaded on 4/4 to prove to them they have released different versions of the firmware under the same file name. So far, no response.
-Alec
AlecMyrddyn is offline   Reply With Quote
Old 04-23-2012, 10:20 AM   #1506
Ohio_Danimal
Midlife Crisis Man
Ohio_Danimal's Avatar
Oddometer: 557
I have read here where some Inmates had issues getting the SMH10 bracket to mount nice and flush to RF1100's and similar FF helmets due to the curvature on the helmet not matching the bracket and clip, etc. Not wanting the Sena mount to be distorted in any way to ensure a nice smooth fit of the unit on the mount.
I have just ordered a Sena SMH10 to replace the $40 Chinese Cardo Scala clone I have been using (that acts up so intermittantly I had to pull the trigger on a Sena) And here is what I did to mount my last unit.
I eliminated the entire screw or stick on bracket and simply used some Sugru silicone to stick the sucker in place. It hasn't budged in a year and is still as solid as the day the Sugru hardened.
This also mean there is no inner 'clip" to reduce the helmet opening slightly, causing issues with it hitting your ear when taking the helmet off. The Sugru fill all voids well so it has less windnoise as well.
As soon as my Sena arrives I will post a brief how-to. IIRC it only took one 5g packet of Sugru to do it.
Wisdom is age well spent.
Anger is age, hell bent.
Ohio_Danimal is offline   Reply With Quote
Old 04-23-2012, 12:05 PM   #1507
mpenner
Heavy Cruiser
mpenner's Avatar
Oddometer: 718
BT Dongle with A2DP for Satellite radio
Has anyone used a BT transmitter plugged into the audio jack of a satellite radio to connect with the SMH-10 that they would recommend?
Mike
2001 KLR 650
2003 V-Strom DL1000
mpenner is offline   Reply With Quote
Old 04-23-2012, 01:09 PM   #1508
radon222
1150GS-ADV
radon222's Avatar
Oddometer: 323
Just last week I tried out an IMC Camos BTA with Zumo 550 with XM30. The bluetooth portion worked great once I discovered I had to turn down the master volume in the Zumo to alleviate some distortion/interference.
However, I ended up sending it back because it wouldn't retain its pairing. Any time I cycled the power on the Sena, meant having to go through the Media Select pairing. EVERY TIME.
'05 R1150GS Adv
Old 04-23-2012, 03:24 PM   #1509
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 3,863
Send a message via AIM to BlueLghtning Send a message via MSN to BlueLghtning Send a message via Yahoo to BlueLghtning
I started with a Schoshe BT transmitter on the audio output of my GPS which also had XM. It worked great, but after a year decided not to turn on one day. Now I have one of those cheapy ones off ebay labeled as A2DP Bluetooth transmitter that you can find for under $20 and it works great. If I get a year out of it, I'll be happy. Best thing is they use a mini-usb charger to charge and I already had a ton of those plugs so its easy to charge on the bike when I need to.
BlueLghtning - Follow me on my SPOT Messenger
Mine: 09 DL650, 01 FZ1, 08 WR250R, 98 DR650
Hers: 06 F650GS, 12 Duc 696, 13 CRF250L, 06 XT225
Smugmug Pics - Save $5: Y2l43o9LVBERU
BlueLghtning is online now   Reply With Quote
Old 04-23-2012, 08:16 PM   #1510
Macho Man2
Oddometer: 54
Upgrade
I have been trying to upgrade my SMH10 to the new 4.0 upgrade and when I click on the new 4.0 link my computer comes up NOT Implemented/ 404 not found... error. Can anyone tell me what to do.. I got a reply from Kim with sena but it still doesn't work.
Bill
Macho Man2 is offline   Reply With Quote
Old 04-24-2012, 05:02 AM   #1511
levain
STILL Jim Williams
levain's Avatar
Oddometer: 5,954
Had mine since they came out. 2 years now. Never had a problem, and I'm hard on my stuff.
Click Here!
2012 Triumph Tiger 800 XC
1971 Lambretta DL
levain is online now   Reply With Quote
Old 04-24-2012, 05:58 AM   #1512
AlecMyrddyn
Oddometer: 140
Bill
Bill,
If you go directly to http://www.senabluetooth.com/support...d_document.php does it work?
-Alec
Old 04-24-2012, 11:15 AM   #1513
Macho Man2
Oddometer: 54
Update
No it still doesn't work same thing comes up every time, I'm calling sena right now... hoping for a fix.
Bill
Old 04-24-2012, 11:30 AM   #1514
danham
danham's Avatar
Oddometer: 184
Bill,
Have you cleared your browser cache?
-dan
2009 BMW F800 ST
Never let your motorcycle take you where your brain hasn't been five seconds earlier.
danham is offline   Reply With Quote
Old 04-24-2012, 11:50 AM   #1515
SaharaJp99
Oddometer: 370
Lucky you. This is a known problem with the ear bud mounts. Mine last abou 4-6 months before they break. I'm not the only one experiencing this.
Times are GMT -7.   It's 06:45 PM.
