Old 05-17-2012, 07:43 PM   #1561
Ken_photo
Oddometer: 16
Microphone cap
Just received my Sena SM10 Dual pack. Each comes with a microphone cap. Not clear what they are for. The quick start guide says "may be useful to reduce incoming wind away from the microphone and provide clearer voice audio sound".
The photo shows it over the bare microphone covering the speaker (?) holes. Says/shows nothing about the foam cover.
Anyone understand its purpose, how it works and whether this is used instead of the foam cover or with it?
Ken_photo is offline   Reply With Quote
Old 05-17-2012, 11:55 PM   #1562
RocketMoto
2 Many Motersikles
RocketMoto's Avatar
Oddometer: 933
Originally Posted by mwood7800 View Post
have had the smh10 for a year, just bought 2 helmet mounts with speakers for 2 new helmets, the speakers fell apart in both lids the first 2 hrs, I put one set back togeather with silicon but now it sounds like crap. also one unit fits loose on all 6 mounts and have to jiggle it for stereo. Hope the warrenty holds out..
All of the Sena product is covered by a two-year warranty. If you purchased from us, we'll take care of you. If purchased elsewhere, your dealer should assist, or call Sena on 866.887.7362, option 2.
=Adam=
Like us on Facebook -- Follow us on Twitter
PM us for your *personal* ADVRider discount code to use at RocketMoto.com
Autocom | TPX Radar/Laser | Sena Bluetooth
| Hi-Power LED Lights
Shorai Battery | Techmount | Powerlet | Rowe PDM60 | Skene Design
RocketMoto is offline   Reply With Quote
Old 05-17-2012, 11:58 PM   #1563
RocketMoto
2 Many Motersikles
RocketMoto's Avatar
Oddometer: 933
Snap the wind cap over the mic and then re-install the foam microphone sponge.
=Adam=
| Hi-Power LED Lights
Old 05-18-2012, 04:57 AM   #1564
Ken_photo
Oddometer: 16
Will this lower the volume?
Old 05-18-2012, 05:40 AM   #1565
Chuffa
TR650 Terra
Chuffa's Avatar
Oddometer: 160
Anyone busted the SMH10 main unit?
After my bike decided we both needed to go somersaulting, my jog dial is worse for wear.
The jog dial & surround is deformed so now only an extremely precise 'press' area is available.
As I can still turn the unit on/off I'm afraid of doing more damage by playing around with it too much.
So... has anyone damaged a unit & found out if the jog dial is removable by a non-tech?
Any ideas would be welcome, thanks.
Chuffa is offline   Reply With Quote
Old 05-20-2012, 07:37 AM   #1566
RocketMoto
2 Many Motersikles
RocketMoto's Avatar
Oddometer: 933
A bit. Keep the mic close to your mouth and you should be OK.
=Adam=
| Hi-Power LED Lights
Old 05-20-2012, 07:40 AM   #1567
RocketMoto
2 Many Motersikles
RocketMoto's Avatar
Oddometer: 933
You can give it a try. It sounds as if you'll need to replace, anyway - so you're not likely to hurt things more than they already are. These do not survive impact all that well. Most often, the clip that fixes the main unit to the clamp, breaks off.
=Adam=
| Hi-Power LED Lights
Old 05-20-2012, 03:36 PM   #1568
'05Train
Mind is not for rent
'05Train's Avatar
Oddometer: 1,046
Adam, any idea when you'll be getting more of the earbud/stick-on mic adapters?
2005 FXSTB/I
2014 K1600GTL
2014 KLR650 NE
'05Train is offline   Reply With Quote
Old 05-21-2012, 04:51 AM   #1569
Chuffa
TR650 Terra
Chuffa's Avatar
Oddometer: 160
Cheers Adam, the clip is fine actually. I will try a gentle attack with a scalpel & see how I go.
The unit copped a battering so I am surprised just how well its working now.
Old 05-21-2012, 07:18 PM   #1570
TowPro
Lets ride
Oddometer: 3,157
Quick Question. I have the SMH10's running the new 4 software. And I have an SR10 running the latest software.
With the new SMH10's I can have 2 "head set" profiles connected (1 SR10 and 1 phone).
can I connect both SMH10's to the SR10 at the same time?
2015 KTM 690 Enduro R
2014 R1200GS - My Naked Street Touring Bike
2000 KTM LC4 640 E - currently up for adoption with 3200 miles
TowPro is offline   Reply With Quote
Old 05-22-2012, 04:53 AM   #1571
danham
danham's Avatar
Oddometer: 268
I don't have two SMH10s to test this with my SR10, but my guess is that the answer is no. The SR10 cannot do more than one HFP connection at a time.
-dan
2009 BMW F800 ST
Never let your motorcycle take you where your brain hasn't been five seconds earlier.
danham is offline   Reply With Quote
Old 05-22-2012, 11:50 AM   #1572
RocketMoto
2 Many Motersikles
RocketMoto's Avatar
Oddometer: 933
You mean the A0303 and A0304 clamp kits? We have 'em in stock. If you meant something else, then, give us a call.
=Adam=
| Hi-Power LED Lights
Old 05-22-2012, 11:52 AM   #1573
RocketMoto
2 Many Motersikles
RocketMoto's Avatar
Oddometer: 933
-dan
Dan is correct. The SR10 will only pair to one headset at a time.
=Adam=
| Hi-Power LED Lights
Old 05-22-2012, 12:17 PM   #1574
TowPro
Lets ride
Oddometer: 3,157
thanks Adam.
Old 05-23-2012, 03:29 AM   #1575
'05Train
'05Train's Avatar
Oddometer: 1,046
Yup, the A0304. Your website says they ship in 1-2 weeks. I'll call today.
2005 FXSTB/I
2014 K1600GTL
2014 KLR650 NE
Times are GMT -7.   It's 04:23 PM.
