Old 06-04-2012, 07:45 AM   #1621
danham
danham's Avatar
Oddometer: 268
Originally Posted by waxrash View Post
I am sure I tried the reconnect to single intercom call and it didn't restore the headset connection. On days I was not leading, my GPS would lose the headset connection after the first conference (not to be confused with intercom 1-1). I used the SMH10 the rest of the day with many intercom calls, it never came back. (except after a gas stop and power cycle the GPS).
If you are leading a group, you are almost forced to only pair with one other SMH10 to preserve the integrity of your navigation system (assuming you like Jill warning you of upcoming turns, etc).
If anyone figures this one out, I'd love to hear it. I've opened a call to SENA, but I don't expect much.
From all the rave reviews I had read about 4.0, I had hoped it was more stable.
Lynn
Once the novelty of 3-way intercom wore off, our group decided not to use it much for this very reason (among others). It only takes an extra second or two to place an individual call and avoid these kinds of BT problems.
You do NOT have to restrict yourself to one pairing, however. In fact, for individual calling to work best, you should pair with everybody (up to the limit of 3). I think it's the extra bandwidth needed for bridging two conversations that causes the problems, not the initial pairing.
-dan
2009 BMW F800 ST
Never let your motorcycle take you where your brain hasn't been five seconds earlier.
danham is offline   Reply With Quote
Old 06-04-2012, 08:54 AM   #1622
RocketMoto
2 Many Motersikles
RocketMoto's Avatar
Oddometer: 933
Thumb
Lynn
Lynn:
I'd love to tell you that Bluetooth is 100% reliable - but that isn't the case, at the moment. Each device maker seems to implement the Bluetooth spec in a slightly different way, and combinations of devices are being utilized in a way that was never envisioned by the design engineers. There are wide incompatibilities and inconsistencies between Bluetooth device makers, and that is just the state of Bluetooth today. It's sort of like a Windows PC; reboot and that usually helps . Wired systems are more like a Mac - plug in and forget about it.
While the Bluetooth world works most of the time, the kinds of things you're experiencing are not uncommon, and that is the state of things to have no wire dangling from your helmet. Bluetooth is way better than it was a few years ago, and in time, Bluetooth may approach the reliability and plug 'n' play-ness of wired systems, it's just not here today.
I own two Garmin GPS's - a 550 and a 665. In my opinion, the Bluetooth implementation on both of these devices is far short of what it should be (I was thinking about some harsher words, but restrained myself). The 665 is a bit better, but not terrific.
All that said, most riders (and passengers) that have Sena headsets are quite happy and accept the kinds of things you have experienced as part of the price of admission for 'cutting the cord'.
=Adam=
Like us on Facebook -- Follow us on Twitter
PM us for your *personal* ADVRider discount code to use at RocketMoto.com
Autocom | TPX Radar/Laser | Sena Bluetooth
| Hi-Power LED Lights
Shorai Battery | Techmount | Powerlet | Rowe PDM60 | Skene Design
RocketMoto is offline   Reply With Quote
Old 06-04-2012, 02:27 PM   #1623
lindavy
Oddometer: 22
Originally Posted by danham View Post
I've had roughly the same experience, only in my case it drops the HFP connection to my SR10. I can always get it back by power cycling the SMH10 (slightly easier to do while riding than the zumo 660), but sometimes I can do it even more easily by placing one single (or as you called it "point to point") intercom call, then ending that manually and the HFP connection comes back.
It also makes a difference whether you are the "bridge" for the 3- or 4-way intercom (paired to two other SMH10s). If you are merely a single client in that conversation (paired to just one of them), it tends not to drop the HFP connection. So if I'm the leader, I get someone else to be the "bridge."
-dan
Not sure if this helps at all but 4 of us are paired almost permanently to each other for intercom (we even see each other without re-pairing after days of being in separate locations), then each phone is paired to their Sena, not the Zumo, and my Zumo is also paired to my Sena, and we never seem to have any major issues with dropping out, and all it takes is a switch off and a switch on of the Sena if anything does go weird. We each have one or other of iPhone 3's and 4S's. Maybe the Sena copes better than the Zumo with the Bluetooth connections.
"I asked God for a bike, but I know God doesn't work that way. So I stole a bike and asked for forgiveness."
08 BMW R1200GS
lindavy is offline   Reply With Quote
Old 06-04-2012, 03:01 PM   #1624
danham
danham's Avatar
Oddometer: 268
Much as I agree with Adam about flakiness of Garmin BT, I don't think that's the culprit in this case. Like you, I do not pair my phone to my 660 but rather do it direct to my SMH10. But unlike you I turn off my zumo BT and have it hardwired to a Sena SR10, which also is wired to my Valentine 1.
-dan
2009 BMW F800 ST
Old 06-04-2012, 07:21 PM   #1625
JRWooden
Oddometer: 4,249
Originally Posted by JRWooden View Post
I'm winding down a 2K mile trip durning which the Sena has performed very welll..........
Last night I noticed that my baseplate was cracked all the way thru from the front back to the contact area.
I'mpending doom for sure ... this is how my first one failed as well...........
I'll have to check warranty status when I get home, but in the mean time I headed to Lowes and got a bottle of crazy glue to heal the crack, and also found a product by Loctite "Multipurpose repair putty" it's like JB Weld for plastic. If you look at the back of the base plate there is a void in the pointy front part of the base. After the crazy glue set I filled in this void with the putty and wrapped some putty around the front of the "nose" of the base to reinforce it. I think it may hold up OK.
If / when I get another base I think I will do the putty trick as a preventative measure ....
Y'all might want to consider it...
Ok here's a picture of what I did:
On the back side of the bracket there is a large void that can be completely filled in with the putty,
then I continued on around the sides of the "bullet nose". Note that the putty can not extend beyond the surface of the bracket on the upper half (above where the bottom of the unit fits into the slot) as it will interfere with the headset snapping in the headset -
I had a bit too much putty there and waited for it to start to harden (about 5 minutes) then trimmed back the excess with a knife.
The putty is made by Locktite and is called Multi-purpose repair putty, I picked up my stick of it at Lowes.
I think it is a worthy reinforcement of the bracket which seems to be a weak-link for many of us....
I should have been a bit more generous with the putty and made it a bit thicker.... and smooth it out better ... the instruction say you can use a wet finger to get a smoother surface.
I will likely build out a second layer of putty and then color it with a black sharpie to blend in better ... unless I find my receipt and am still under warranty.
It looks like the SMH5 uses a different mounting system ... that the speakers/mic. just plug directly into the unit with all the electronics, instead of the arrangment the SMH10 uses ... I haven't seen one in person, but think this is likely a more robust and more reliable design... not to mention a bit less expensive to manufacture.....
JRWooden screwed with this post 06-05-2012 at 10:55 AM
Old 06-05-2012, 07:04 PM   #1626
kcieslicki
kcieslicki's Avatar
Oddometer: 300
Hi. I just received the SMH-10 yesterday. Should I upgrade to the new firmware before I pair with any devices?
kcieslicki is offline   Reply With Quote
Old 06-05-2012, 07:23 PM   #1627
TowPro
Lets ride
Oddometer: 3,165
I would. The latest firmware is the best they have had yet. Why not start out with the latest.
2015 KTM 690 Enduro R
2014 R1200GS - My Naked Street Touring Bike
2000 KTM LC4 640 E - currently up for adoption with 3200 miles
TowPro is offline   Reply With Quote
Old 06-06-2012, 04:38 AM   #1628
danham
danham's Avatar
Oddometer: 268
Won't hurt anything to pair first, but if memory serves me, you'll have to do it again after the update anyway.
Even if the update does not erase existing pairings, I found it worked better to do a factory reset after the update (fairly standard practice when updating firmware on these kinds of devices -- hello zumo owners), and that definitely does erase any pairings.
-dan
2009 BMW F800 ST
Old 06-06-2012, 07:02 AM   #1629
kcieslicki
kcieslicki's Avatar
Oddometer: 300
Thanks for the good info. I'll update the firmware first then start pairing.
Old 06-06-2012, 02:16 PM   #1630
NeedForSpeed
Nitron Shocks USA
NeedForSpeed's Avatar
Oddometer: 1,375
FYI- Sena is running a promo on the SMH5's and SMH10's
We have the 5's and 10's in stock and ready to ship
http://www.cobraheat.com/Bike-Communications_c_92.html
CobraHeat LLC
PAK-MEISTER.COM- Motorcycle Adventure Gear
NITRON RACING SHOCKS USA
(801) 663-7436
NeedForSpeed is offline   Reply With Quote
Old 06-07-2012, 09:19 AM   #1631
kcieslicki
kcieslicki's Avatar
Oddometer: 300
FYI I have a brand new boom mic clamp for sale. I opted for the earbud clamp from the start. $20 including shipping. PM if interested.
Old 06-07-2012, 11:43 AM   #1632
wyomingriviera
Ghostface Killah
wyomingriviera's Avatar
Oddometer: 260
Anyone have experience using these without helmets? My brother and I do car rally's about twice a year, and I'd love to get a communicator that did double duty.
Can I mount a sena to a normal pair of noise reducing Earmuffs? Kinda like These Peltors: rally com
"For initiation you have to terify a yard sale. You know one of those yard sales you see all over vermont. You blow by it at 100 mph and make people scream."-Tom T
'99 CR250
'01 XL1200
'07 DL650
wyomingriviera is offline   Reply With Quote
Old 06-07-2012, 12:15 PM   #1633
radon222
1150GS-ADV
radon222's Avatar
Oddometer: 356
Check out the SPH10's
http://www.senabluetooth.com/product..._menu=overview
'05 R1150GS Adv
'12 R1200RT (Wifey's bike)
radon222 is offline   Reply With Quote
Old 06-07-2012, 12:26 PM   #1634
wyomingriviera
Ghostface Killah
Oddometer: 260
How are those for blocking out road, wind, and engine noise? The car we use is waaay louder than my mc...
'99 CR250
'01 XL1200
'07 DL650
Old 06-07-2012, 12:50 PM   #1635
scootertrog
Oddometer: 299
Is there a reason my SMH-10 continuously wants to "connect with intercom" while listening to the ipod touch, even though there's no other Sena around? I tried turning both the ipod and Sena off, but every few minutes the Sena lady blurts out that it is trying to connect to intercomom. Then I get the "failed" message. This will go on for hours while listening to music, lol.
scootertrog is offline   Reply With Quote
Times are GMT -7.   It's 01:32 AM.
