01-07-2013, 08:16 AM
#2161 | |
Riding is my passion
I don't use a radar, but I do sometimes hook up the GPS to the SR10. I may have to try that with my wife. My biggest issue with using the SR10 & GPS is that it does cut the music which gets annoying if there are lots of turns. I put in a ticket about keeping the music channel open also by choice, but so far they haven't said they would do that.
BlueLghtning - Follow me on my SPOT Messenger Mine: 09 DL650, 01 FZ1, 08 WR250R, 98 DR650 Hers: 06 F650GS, 12 Duc 696, 13 CRF250L, 06 XT225 Smugmug Pics - Save $5: Y2l43o9LVBERU |
01-07-2013, 08:20 AM
#2162 | |
I was a late adopter to the SMH10's, as I started with the Scala Q2's but couldn't be happier with our decision to come over to them last year. I'm very technical though and do software testing for a living, so I like to dive into this stuff. I've turned a lot of people on to the SMH10's and Rocket Moto since we got our sets. Just curious, what Collett models have you used? Like I said, I've used the 900mhz 2-way radio one. The later more rounded silver ones, not the old black brick looking ones. I know there at one time I read about some BT ones, but never looked into them more. Not sure if they had both BT & radio or what, can't remember now without looking them up.
01-07-2013, 08:25 AM
#2163 |
Oddometer: 19
(This was my prior post that's still in limbo somewhere (I create my long posts in Word). Sorry if it gets repeated)
Wow - Great information! Thank you so much guys! With regards to the simultaneous BT intercom and 2-way radio via SR10 scenario....this is a quote from the comments on the Webbikeworld.com review of the SR10 (User "MH", bottom of the page): --------------------------------------------------------------------------- "All devices connected to the SR10 will mix the audio to the SMH10 when an ongoing intercom connection is in progress. Even all 3 inputs will mix to the SMH10 simultaneously. This may sound like it could be confusing, but it's really not. In other words, if I'm in intercom conversation with another SMH10 user, and my RADAR detector activates (which is audio connected to the SR10), that audio is "mixed" into the current ongoing intercom connection to the SMH10. This allows me to pass along that info to the other rider(s) immediately. With v 3.3 (and earlier) firmware, the SR10 would take full control of the SMH10, disconnecting the ongoing intercom connection. This was unacceptable. If I am not in an intercom connection, but listening to media via my smartphone, and a device connected to the SR10 actives (RADAR detection, GPS instruction, 2 way radio signal), the SMH10, drops the media connection, opens the channel for the SR10, for it to pass that data. Once the device connected to the SR10 has ceased passing audio, the SMH10 restarts the media from the smartphone. This in my opinion is perfect! One other discovery made was being able to simultaneously use the intercom connection to another rider(s) and to use the two-way radio. This is absolutely great. I do not have to disconnect from an ongoing Bluetooth intercom connection to make a two-way radio call. The other SMH10 only users will not hear the incoming 2 way radio conversation from my SR10, but they can hear the rider with the SR10/SMH10/two-way radio side of the conversation." ------------------------------------------------------------------------------- -I've read a bit about noises in the headsets with an active intercom session as the users start approaching the fringes of the BT range. Any experiences with this? With the Collets is that there's always 1 or 2 riders with their VOX mis-adjusted and their mics are constantly keying creating static in the headsets. Trying to figure out who the culprits are is sometimes challenging. Also there's frequently strange noises from interference from who knows what. What I'm trying to say is all the frequent sounds in the headsets, other than talking, drives us nuts -With regards to any delay between pushing the PTT switch and the SR10 "waking up" and reconnecting to the SMH10/5, I read that a "double-tap" of the PTT will keep the SR10 from disconnecting from the headset. Any experiences/thoughts on this? You think this would significantly affect battery life of either the SMH10/5 or SR10? (another double-tap will allow the SR10 to disconnect and sleep) A few of us already have dual band VHF/UHF 1w/5w radios with good range that would be good to use with the SR10. Any experience with the Uclear WT300 BT hub as compared to the SR10? I like the wireless PTT option. I think I'm leaning toward the cheaper SMH5 option due to it's "better" mount and wire connection and smaller size and using the SR10 and 2-way radios - No BT intercom. Only concern is battery life in the cold. No big deal to carry a backup external reserve battery used for cellphones etc. and plug it into the headset if needed I guess. Our snowmobile season looks like it might be a little short this year. No good snow yet (Central MN). Fingers crossed! Thanks again for your wisdom fellas! |
01-07-2013, 08:51 AM
#2164 | |
Oddometer: 184
If you care to drop by and shovel me a path to my driveway I can get out and test this [g]. -dan
2009 BMW F800 ST Never let your motorcycle take you where your brain hasn't been five seconds earlier. |
01-07-2013, 08:59 AM
#2165 | |
01-07-2013, 09:10 AM
#2166 |
Oddometer: 19
Well guys, not sure of the criteria surrounding whether or not my posts show immediately or need to get approved. I re-posted my previous missing post thinking that since I had 2 back to back posts immediately published, my background check came back clean and my missing post was circling the internet never to be found. But the re-post hasn't become visible yet either. So.....you're (hopefully) going to see 2 duplicate long(er) posts. Sorry.
On topic....We started with the bulky, squarish Collets many many years ago and now have the smaller, non-bluetooth units. They are starting to fail and I really don't want to continue down the Collet path. Their range is terrible in the woods - 100 - 1000ft. In addition, I've had to deal with their service several times over the years and found it very frustrating. The owner- Les Collet - is pretty arrogant. They've gotten expensive as well. I've been waiting for the communicator technology to improve over the last several years and it never seems to quite get there. Always some compromise. However, the BT hub connected to a 2-way radio technique seems to be about there. I think I'll venture down that path and see where it takes me. Any of you guys familiar with the PrymeBlu BT radio devices? They have a wireless (BT) PTT switch that talks to their BT radio adapters. Looks interesting |
01-07-2013, 09:15 AM
#2167 |
Oddometer: 19
danham - might be showing my ignorance here but do you think the radar detector alert could have been picked up by your mic from the sound out out of your speakers and transmitted to your intercom partner? Maybe that specific frequency travels within a helmet environment well.
01-07-2013, 09:19 AM
#2168 | |||
01-07-2013, 09:23 AM
#2169 | |
01-07-2013, 09:31 AM
#2170 |
Oddometer: 184
@tbenzie & BlueLghtning:
Yes, it is entirely possible that the beeps make it from speaker to mic better than the zumo's voice. But that would fail to explain why it only works with a 2-way conversation, not 3- or 4-way. However, see my previous brain cells disclaimer on that one [g]. Just to keep this all interesting, another variable in how the SMH-10 performs seems to be the state of the contact pins. I have had some rare but nasty static/interference/distortion problems that I thought were all BT issues and a nice cleanup with DeoxIT made them vanish instantly. -dan
01-07-2013, 09:35 AM
#2171 |
Oddometer: 19
OK - since my post and re-post from a while have yet to make it on here, I'm going to regurgitate some of the pertinent items. (The only difference it seems is that the posts that show up immediately are ones that I type directly to the board. The missing ones are copy/paste from Word? It's a mystery.)
Anyway - If you read the SR10 review on webbikeworld dot com, there's a comment at the bottom by "MH". He states simultaneous BT intercom and SR10 audio mixing including the 2-way radio. With regards to the double-tap on the PTT to keep the SR10/SMH10 link alive - do you think this will have a significant affect on the battery? Any experience with the Uclear WT300 BT hub? Would you say that the mounting system and the pin connection scheme are betterwith the SMH5? |
01-07-2013, 09:44 AM
#2172 | |
Oddometer: 184
SMH-5 has better pins than older SMH-10 but 10 has been improved. 5 clamp/mount may be more robust though. -dan
01-07-2013, 09:53 AM
#2173 |
Oddometer: 19
Is it safe to assume dbl tap will also put more drain on the headset battery?
01-07-2013, 10:07 AM
#2174 |
I want to ride
Oddometer: 1,760
I have ridden all day with my rider/passenger intercom fully connected all the time and have never had the battery go dead.
I bet there has been times when I had two 6 + hour days without recharging (forgot to recharge) but I have never had a SMH10 have the battery run down.
2010 F800GS Stone Road Touring bike! |
01-07-2013, 10:09 AM
#2175 | |
I'm not sure though that you'll find that leaving the SR10 BT channel open all the time is really necessary? I'll do it if I'm in an active conversation on the Ham Radio in order to keep the SR10 from going to sleep, but if I'm just scanning or such, I usually don't worry about it. The SR10 does stay open for about 30secs or so once it opens up too so usually that is sufficient to wait for the reply. As long as people are good about pausing 1-2 secs before speaking the first time they key up (which most Ham guys are since they are already waiting for the repeater to key up also), you really shouldn't have much issue there.
