01-08-2013, 08:30 AM
#2191 |
Dunkin Donuts Crasher
Oddometer: 781
I dunno.
Sent from my iPhone
2004 Suzuki DL650 Weestrom/2007 BMW F800ST 1998 Suzuki DR350SE 1978 GS 1000 "Those who would trade security for a little temporary safety deserve neither liberty nor safety." |
01-08-2013, 10:49 AM
#2192 |
Oddometer: 19
I'm back
So....My gear will be here this week so I figured I'd get a head start and read the manuals. I seem to be getting myself all wrapped around the axle on this BT stuff and making it more complicated than it really is maybe. I'd like to run some stuff by you guys to verify my (mis)understanding of this.
Available pairing profiles, my understanding: HFP - phone functions A2DP & AVRCP - media functions Headset - SMH10 to SMH10 My profile questions: 1. Am I right? 2. The SR10 pairs to the SMH5 as HFP. It's not capable of A2DP/AVRCP. Correct? 3. The SMH5 is capable of having 2 HFP(phones) devices attached of which only 1 will be able to use the A2DP/AVRCP profiles SMH5/10 Pairing options, my understanding: "normal" - HFP and A2DP/AVRCP are available here. Only one device can be paired with this method. Selective - This is actually a sub-option of the normal procedure. You can restrict the device being paired to only the HFP or A2DP/AVRCP profiles. This will allow 2 devices to be paired to the "normal" slot - 1 to each profile. Multipoint - allows a 2nd HFP only pairing. A2DP/AVRCP is not available. Only one device can be paired with this method My options questions: 4. Am I right? 5. In theory you could have 3 devices (not counting other Sena headsets) paired to the SMH5/10. 1-A phone (selective HFP), 2-an MP3 player (selective A2DP) and 3- another phone, gps, SR10 (multipoint HFP). If you have a phone that functions as a media player, you would pair it normally and it would aquire the HFP and A2DP profiles. In this scenario you could have ony 2 devices (not counting other Sena headsets) paired to the SMH5/10 - 1-A phone (HFP & A2DP) and 2 - another phone, gps, SR10 (multipoint HFP). Correct? SR10/SMH5/smartphone pairing strategy: 6. Is there a specific order these devices should be paired? My phone (HTC Android) will require HFP,A2DP/AVRCP. If I pair the phone first to the SMH5, using the normal procedure, I'm assuming it will aquire these profiles. This will leave a 2nd HFP profile which will be used by the SR10 that I'll pair next with the multipoint option. If I pair the SR10 first would I do it using the multipoint procedure and then do the phone normally? Does the order not matter as long as the phone is always paired normally and the SR10 always paired with the multipoint procedure? What will happen if I pair the SR10 using the normal procedure? Would I need to pair the phone with multipoint and then I would have no A2DP ability? Same thing would happen if I paired the SR10 with Selective HFP, correct" Pairing with other Sena headsets: 7. The SMH5 is capable of pairing with 3 other Sena headsets. Say you have a group of guys, A,B,C,D that are paired up. These guys ride together every weekend for 3 weekends. When they re-convene their group each weekend and turn on their headsets, they automatically reconnect and the intercom order remains the same. Right? 8. Same group of guys as above, except the next weekend, driver C can't make it but Driver E shows up with his own Sena headset. They want to include him in the BT group so do they all need to clear/reset their devices and run through the entire pairing process again? Including re-pairing to their phone/MP3/GPs/SR10? Any way to selectively delete specific pairings? Headset pairing topology: Many have provided scenarios where they show that they paired in a chain topology: A-B-C-D. The book shows pairing in a star/hub topology: A-B,A-C,A-D. 9. Reading between the lines, I'm assuming the star/hub method is actually more of a mesh topology: A-B,A-C,A-D,C-D,C-B,B-D but they don't show it for simplicity's sake or is it that when paired as a star/hub there are inherited pairings? So if A is paired to B and A is paired to C, C inherits the pairing to B so it's unecessary to pair C to B. 10. Is the chain pairing only valid if the headsets have intercom conference abilities? Being that the SMH5's don't have conferencing, the chain pairing doesn't pertain. Correct? Whew! I really need to learn how to shorten posts. Thanks for any and all opinions and advice. |
01-08-2013, 11:31 AM
#2193 |
Oddometer: 184
Wow! I have to run to an appointment, but in general, yes, you are over-thinking it. Intercom pairing is not as convoluted as the manual makes it sound, but also not quite as automatic "next week" as you are saying.
SR-10 is a mono, HFP-only device. It doesn't do selective or multiple pairing. Be aware that for selective you need the other (non-SMH-10) device to be capable of it too. This is where the zumo 660 is a big fail: you can't shut off A2DP and pari selectively using only HFP. That's why I turn off its BT and hardwire it to my SR-10. I'll try to answer point by point when I get to the keyboard again, later, but with some luck BlueLghtning will bail me out first [g]. -dan
2009 BMW F800 ST Never let your motorcycle take you where your brain hasn't been five seconds earlier. |
01-08-2013, 11:38 AM
#2194 | |
Riding is my passion
See in Red
BlueLghtning - Follow me on my SPOT Messenger Mine: 09 DL650, 01 FZ1, 08 WR250R, 98 DR650 Hers: 06 F650GS, 12 Duc 696, 13 CRF250L, 06 XT225 Smugmug Pics - Save $5: Y2l43o9LVBERU |
01-08-2013, 11:50 AM
#2195 |
The easy way to think about headset pairing is.
You have Dan & Sarah (husband & wife), & John. John is joining in for the day and wants to pair up. Dan & John pair their headsets and both become rider #1 on each others headsets. Dan however doesn't want John to be #1, he wants his wife Sarah to be #1. So even though Dan & Sarah were already paired before this and Sarah had moved down to #2, they pair again. Now on Dan's headset, Sarah is back in the #1 slot and John is #2. On John's headset, Dan is #1 and he's not paired to Sarah (although he easily could be). At any time during the ride, both Sarah and John can connect to Dan, but John & Sarah can't talk unless they both are connected to Dan at the same time. The manual doesn't make a good point of this, but anytime 2 people are talking and you want a 3rd or 4th person to join, those people have to join in by connecting to someone already in the conversation. If I'm in a conversation with Sarah and we want John to join, I can't double tap to get John. Now if I can't get John's attention, I could tell Sarah, hey I'm going to disconnect and connect to John, then you come back and connect to me. Now we have a 3-way conversation going on. Easy way to remember pairing process of headsets. * Hold down both jog dials of each headset until they both start blinking red/blue * Quickly press only 1 of the two jog dials again. * headsets pair and go to double blue flashing meaning they are actively talking * Press one of them again to go to standby. One rule we usually come up with is the person that started the conversation is the one that ends it. If both people try to end the conversation at the same time, you end up connecting again.
01-08-2013, 12:03 PM
#2196 |
If you want to setup a larger ride and try the daisy chaining effect like was outlined on a previous post, I think for simplicity sake, you should pick an order you are riding in and pair backwards to that. You could obviously make it more complicated than this with many more pairings, but this keeps it simple and straight forward as long as everyone stays in order.
So start with the last person in the group and pair forward. 6 -> 5-> 4 -> 3 -> 2 -> 1 6 pairs to 5 5 pairs to 4 4 pairs to 3 3 pairs to 2 2 pairs to 1 This way the rider in front of them is always their number 1 rider. Connect to each other from front to back in logical order. 2 connects to 1 - raise hand when connected 3 connects to 2 - raise hand 4 connects to 3 - raise hand 5 connects to 4 - raise hand 6 connects to 5 - Everyone is connected as long as no one drops or gets out of range
01-08-2013, 12:28 PM
#2197 |
Oddometer: 19
Thanks BlueLightning! That helps tremendously.
Dodged a bullet danham I don't believe they gave the SMH5 the conferencing capability. It will pair to 3 additional units but you can only talk to one at a time. This is my understanding at this point anyway. It would be nice if they had conferencing ability though With regards to that, are your responses to questions 7,8,9 (and your Dan, Sarah, John post) above based on conferencing ability? If I'm understanding this correctly,unless they're directly paired with each other, the only way 2 units can talk is in a conference. So if the SMH5 cannot conference, we need to follow the mesh pairing -all pair to all- in order to have the ability for everyone to talk to everyone - 1 at a time though. Am I getting there? Thanks |
01-08-2013, 12:35 PM
#2198 |
Oddometer: 19
Hmmm......... your daisy chain example is predicated on conference ability I assume. If the unit is only capable of 1-1 communication that system becomes ineffective. Right?
That being said, if all the units were SMH10's with intercom conferencing, you show 6 devices in the conference. Does this method overcome the 4 device conference limit that Sena states? Thanks |
01-08-2013, 01:04 PM
#2199 | |
Correct, but sort of. If its all SMH5's yes, then the daisy chaining won't work. You'd have to paired with anyone you want to talk to. However, just one SMH10 in the mix would allow two SMH5's to connect to it and basically join in on a 3 way conference because only the SMH10 is bridging two different connections.
01-08-2013, 01:07 PM
#2200 | |
Yes, forgot the posters name, but he posted that they had 5 riders connected together in the UK by using the daisy chain effect. If the two units on either end of the daisy chain were SMH5's, they could still be connected, but obviously no one could join into them to start a 3 way conferenc. Also of course the distance would be cut down to the limit of the SMH5's also. Maybe you'll end up with an SMH10 after all.
01-08-2013, 01:15 PM
#2201 | |
So tbenzie, you are correct. The SMH5 doesn't have any 3 or 4 way conferencing ability on its own. I guess that is the biggest thing going for the SMH10 these days other than distance, battery, and MP3 port on the mount.
It still technically can be involved in a 3 way by connecting to an SMH10 or say that 2 riders on a motorcycle both have SMH10's and both passengers have SMH5's. With the two SMH10's linked in the middle, there could be a 4 way between the 4 of them. The SMH5 recently got the multipoint upgrade in v1.2, but that was it. Quote:
01-08-2013, 02:14 PM
#2202 |
Oddometer: 184
Procrastination pays off, again! Thanks BL!
An easy way to think of the 5 vs 10 issue is that only the 10 can act as a bridge. A 5 can participate in a "conference" but cannot act as a bridge to enable that. The only other small point to add is that the "how many taps" question can seem complicated, but it's really just like a stack of dishes. The very last dish put on the pile gets the "address" of one tap for intercom. Next dish down -- the headset you paired to before Mr. One-Tap -- gets assigned the address of two taps, etc. Seems backwards, but the newest guy is always One Tap. I can't recall if the 5 and 10 have different numbers of intercom pairing slots available, but I do know that when they fill up it bumps the oldest one, so no need to erase or do a reset to get rid of old ones. As for pairing order, I agree that it's not an issue, BUT, power-up order can be fussy with some systems. I find the most reliable sequence is to turn on my iPhone first, then the SR-10, then put on my helmet and power up the SMH-10 (so I can hear it acknowledge finding both phone and the SR-10), then turn on the devices wired to the SR-10 last so that I can also hear them join the party and verify they are working. Have fun! -dan
01-08-2013, 02:15 PM
#2203 |
Oddometer: 19
It's all becoming clearer. Thank you so much!
I fully expect to be upgrading to more capable units if the SMH5/SR10/VHF thing works out for us. We're just starting out with a couple units for a trial run. The big test -and big difference from the Collets from a usability standpoint - will be the PTT switch manipulation and potential delay when first opening the audio channel. I expect advantages of the 2-way range, no persistent vox keying, quality, robustness, less finickyness (I hope), etc of the Sena equipment far far outweigh that minor inconvenience. The safety factor of communication ability is much greater when snowmobiling than motorcycling, I believe - tight, twisty trails in the woods with hills, rocks, logs, deer and other sleds approaching you at 50 mph on a 12' wide trail so reliability and range are key.A few in our group don't ride motorcycles so if the SMH5's work out with the 2-ways, they'll become proud new owners of SMH5's and I will be upgrading to the next best thing. I think the BT conferencing intercom will be great for motorcycling. Again, I truly appreciate all the effort and time you've spent educating me. Hopefully I can do in kind some day. |
01-08-2013, 02:57 PM
#2204 |
Oddometer: 781
Turns out yes it does have a 2 year warranty and I now have a RMA number for my unit.
Sent from my iPhone
01-08-2013, 04:32 PM
#2205 | |
I want to ride
Oddometer: 1,760
2010 F800GS Stone Road Touring bike! |
