Old 06-07-2014, 07:53 AM   #3586
JRWooden
Oddometer: 4,313
Originally Posted by Bleemus View Post
You can use ICloud to find your phone or wipe your phone clean if stolen.
I've been waffling on setting up an iCloud account ... maybe this is the push I need ...
It would be cool if Apple added a feature that said:
"Allow Siri from the lock screen, but only for music" ....
JRWooden screwed with this post 06-10-2014 at 10:30 AM
Old 06-16-2014, 09:01 PM   #3587
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 5,004
So I'm playing with a Cardo BTA-II (HFP bluetooth transmitter) to try and get sound from my Garmin 2610. I got the BTA-II paired with my SMH-10 and it works to play sounds from the GPS for about a minute, after which the BT flashes still show connection but the sound is cut off and cannot be restored except by turning either the Cardo or SMH-10 off and back on. This is obviously not terribly useful.
The GPS simply puts out sound, there are no related settings. I have not found any programmable settings on the BTA-II although, according to the manual, it stays connected for up to a minute after a call is ended (when it's used to enable BT for a non-BT phone). I therefore wondered if there is anything else I should be trying with the SENA?
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast screwed with this post 06-16-2014 at 09:13 PM
slartidbartfast is offline   Reply With Quote
Old 06-17-2014, 07:00 AM   #3588
lmychajluk
Oddometer: 2,119
Sounds like what is happening is that the Cardo may be dropping the connection when it doesn't get any input from the GPS for a minute or two. Not sure how to get around it, though. I use an SR10 and it works pretty well with my Montana.
-Lee
NE ADV Event Calendar (Request Additions here.)
2013 Triumph Tiger 800
2008 Suzuki SV650n (Sold... I miss that bike...)
lmychajluk is online now   Reply With Quote
Old 06-23-2014, 04:09 PM   #3589
disconnected
rider
disconnected's Avatar
Oddometer: 7,461
I'll keep searching, BUT...can you hard wire an older iPod, or is it blue tooth only?
I'm kinda old fashioned still
Greg
IBA # 47004
disconnected is online now   Reply With Quote
Old 06-23-2014, 04:16 PM   #3590
TowPro
Lets ride
Oddometer: 3,298
Greg
i think the shm10 has 1/8" audio input jack don't it?
TowPro is offline   Reply With Quote
Old 06-23-2014, 04:19 PM   #3591
disconnected
rider
Oddometer: 7,461
I'm still looking, but haven't found a hard answer yet. N. My friend has unlimited data and he just runs pandora, but I don't think there is much cell coverage on my typical routes
IBA # 47004
Old 06-23-2014, 04:25 PM   #3592
disconnected
rider
Oddometer: 7,461
Originally Posted by Wingspan View Post
If you have an iphone (3G or 3Gs), you won't need a cable because the Iphone will link to the Sena via bluetooth for both music and phone functions. The input socket is for listening to music over non-bluetooth equipped devices through a wire.
IBA # 47004
Old 06-23-2014, 04:30 PM   #3593
TowPro
Lets ride
Oddometer: 3,298
yes the mp3 jack is on the helmet mount, not the actual SMH10
but the jog dial will still adjust the volume of this input.
See directions on sena website.
Old 06-23-2014, 04:36 PM   #3594
disconnected
rider
Oddometer: 7,461
Found the link too.
Greg
IBA # 47004
Old 06-23-2014, 04:38 PM   #3595
sorebutt
Oddometer: 1,998
You can plug an I-pod in directly to the unit on the side of the helmet. A better alternative is to buy Sena's unit that you can plug anything into it and it sends it to the headset by bluetooth.
sorebutt is offline   Reply With Quote
Old 06-24-2014, 05:10 AM   #3596
mwood7800
Oddometer: 611
Boon doggle and I phone
What pairing method do I use with just my iphone and a boon doggie, when I updated and use old method ( like I pair the phone) it doesn't stay connected.
mwood7800 is offline   Reply With Quote
Old 06-24-2014, 07:04 AM   #3597
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,403
Is the "boon doggie" a A2DP transmitter? How do you want your iPhone paired, just as a phone with no music?
If the above is correct.
- Pair your iPhone as (HFP) Phone only
--- Hold Phone Button for 5 seconds
--- within 2 seconds tap the phone button again (LED turns blue flashing)
--- You will hear "Phone Selective Pairing"
- Pair your A2DP dongle as (A2DP) Media only
--- within 2 seconds tap the jog dial (LED turns red flashing)
--- You will hear "Media Selective Pairing"
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is offline   Reply With Quote
Old 06-24-2014, 08:12 AM   #3598
disconnected
rider
Oddometer: 7,461
Just ordered one from Revzilla. Will be nice.
Greg
IBA # 47004
Old 06-24-2014, 10:27 AM   #3599
mwood7800
Oddometer: 611
Dongle is a2dp, i would like phone as phone and or music, and dongle as music only, I use to just turn off dongle when using phone for music
Old 06-24-2014, 10:40 AM   #3600
BlueLghtning
Oddometer: 5,403
In that case, its going to be the phone and the dongle both fighting over the single A2DP connection so the order you power them on and allow them to connect will become important. You can pair your iphone using the normal phone pairing method and pair the A2DP device as Media only. The SMH10 should remember both connections.
If you want to use the dongle, you'll need to make sure you turn it on first and let it grab the A2DP profile first. When you turn on your iPhone next it will only have the HFP connection to grab. It may be okay with that, but it may keep disconnecting trying to connect the A2DP profile too? It will just be trial and error to see how it works.
When you power off the dongle, the iPhone may automatically grab the A2DP profile or you might have to just cycle the BT on the phone to get it to reconnect with both.
That setup isn't exactly the best, but with some patience and trial & error, you might get it to work well enough to suit your needs.
Times are GMT -7.   It's 01:32 PM.
