Old 03-27-2012, 10:43 AM   #136
jdrocks
Gravel Runner
Oddometer: 4,554
Originally Posted by pjm204 View Post
Well hopefully mine isn't on there as tight. It is only supposed to be 92ft/lbs. we shall see. I mean at some point the front sprocket needs to come off, they certainly don't last forever.
the nut is on there with at least 300# from the factory. use an inch impact socket rather than metric for a better fit, you can easily split a regular socket with that kind of torque. the easiest way to break the nut loose is with a HD impact, or if that doesn't work, lock the sprocket with a piece of small diameter schedule 40 pipe nipple placed against a sprocket tooth and the swingarm, then use a breaker bar.
the trans should NOT be in gear.
jdrocks is offline   Reply With Quote
Old 03-27-2012, 10:49 AM   #137
pjm204
Oddometer: 2,012
awesome, sounds like I'm in for a treat this weekend. Maybe I'll get lucky. I don't have an impact gun at my house, so I'll either have to go to my parent's or use my 1/2" breaker bar with a cheater on it. The guidance on not being in gear is likely very valuable. I could see someone ruining their trans with those kind of forces. Luckily the trans is super easy to replace with this bike, another huge selling point for me.
Current bikes:2006 DL650
Past bikes: 2008 WR250R, XT225, TTR125, '04 CRF50 '74 DT125,'70 TS250,'85 v45, '89 zx600c, '78 GS400x, '99 GS500E, '01 GS500E '05 Z750s, '77 GS400e, '82 GS1100ez, '97 GSX600, '07 VFR800, '03 KLR650, '03 FJR1300, '06 DL1000, '00 KLR650, '99 WR360, '08 DL650, '05 DR650, '08 EX650r, '96 CR500, '82 GS450T, '06 Ural
pjm204 is offline   Reply With Quote
Old 04-27-2012, 10:49 AM   #138
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,666
I've decided not to pursue the build on my Ninja, and it's up for grabs in the Flea Market.
When they say Harleys are for 1%ers, I don't think they mean guys who sell crank and get in bar fights any more.
Roadracer_Al is offline   Reply With Quote
Old 08-01-2012, 06:32 PM   #139
Danger4u2
'04KX500isDanger4u2
Danger4u2's Avatar
Oddometer: 703
Are you guys still tweeking on the Ninja's ?
Go faster than everyone.
Only worry about what's in front of you.
Danger4u2 is offline   Reply With Quote
Old 08-03-2012, 04:44 AM   #140
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,271
Mostly riding! Just returned from an 1800 mile trip on the Blue Ridge.
I have added a prefilter to the airbox, the stocker couldn't handle sand n dust to my satisfaction.
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 08-03-2012, 06:27 AM   #141
ktmklx
ktmklx's Avatar
Oddometer: 700
That looks like nice riding, i might have to check the Blue Ridge out sometime.
ktmklx is offline   Reply With Quote
Old 10-06-2012, 06:10 AM   #142
ty.zardoz
Oddometer: 63
Cool2
I found this thread a couple of days ago and started reading. Only one thing to say about it... very dam COOL sanjoh! I'm a big fan of "non-stock" and bobbers and such. I'm cleaning up my CBX this winter and putting the finishing touches on my TW, extended swingarm, adding a fan for my radiator.. modding my harley fatbob tank to fit.
I expect this will all be done by spring.. so I'm going to be looking for another project. I think I'd like to build my own "Dirt Ninja"! Or perhaps some other street to dirt hybrid, really it's going to be dictated by price.. so whatever goes for cheap will likely be my victim unless there are mechanical factors that prohibit said conversion.
I'll say it again... your dirt ninja is way COOL!!!
tyz
ty.zardoz is offline   Reply With Quote
Old 11-01-2012, 04:06 AM   #143
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,271
Gonna do some updating on the Dirt Ninja over the winter.
Foot peg relocation - gonna need a new exhaust hanger and luggage rack lower mount as the aluminum footpeg holders are coming off
Swingarm extension - Just a few inches, any suggestions on how to do this? Was going to start with 2 swing arms and join the rear parts with a support splint on the inside made of tubing.
Exhaust reroute
Skidplate
Recently acquired a KTM 950 SE and all I can say is the Dirt Ninja is a very capable enduro
Old 11-01-2012, 05:44 AM   #144
pjm204
Oddometer: 2,012
I regret selling mine, so I'll probably end up buying the next ninja 650 I see pop up for the right price. My buddy just bought a 950SE, after riding it I was strongly considering selling my vstrom for one, had to practice some self restraint.
Old 11-01-2012, 11:11 AM   #145
yokesman
Oddometer: 518
is that earley swingarm rectanglar or not, I was looking at that on another site where they extended it 1 inch, but i was thinking also 1.5-2 by fitting a thick wall rect tube inside, cutting the original at a verticle v for more weld area, fitting the original adjusters but this is all speculation on my part while i am still shopping for the bike. otherwise it looks like it is a complete refab out of rect tubing. and i may not need it for my app.
yokesman is offline   Reply With Quote
Old 11-01-2012, 05:50 PM   #146
ktmklx
ktmklx's Avatar
Oddometer: 700
Sanjoh,
Using a second swing arm works pretty good, that is what I did. The correct size, thickness and alloy how can you go wrong? Just add on to the back. I only did an inch, didn't want to change the length of the bike to much. Absolutely no negatives that I can find from this mod, but a lot of positive. And you can buy them for about $15. The gussets are also from the donor swing arm, the brace sawed in half.
Old 11-02-2012, 11:12 AM   #147
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,271
The SE is a hooligan bike defined, felt like trouble the first time I sat on it.
Originally Posted by ktmklx View Post
Sanjoh,
Why only an inch? Any pics of the swing arm on the bike?
Old 11-03-2012, 06:52 AM   #148
ktmklx
ktmklx's Avatar
Oddometer: 700
Why only an inch, I'm conservative. I was concerned about getting the wheelbase too long and affecting handling. If I remember correctly 1" of length gave me almost a 1/4" of travel. The bike still turns very good so I would not be afraid to try a little more length. If you look back in my build thread a few pages you'll see the the swing arm mods and inner fender changes. These changes really had an impact on the bike, it felt like going from a playbike to an offroad bike. Before it was pretty easy to bottom the tire into the inner fender, now I can't. I recently had a chance to ride this and my KLR back to back. I was hoping this bike would be a more powerful KLR, but what I got is a far superior bike. This rear suspension with the mods and R1 shock works really good and the KLX front is awesome.
You mentioned something about a KTM comparison with your bike, care to share more?
Old 11-04-2012, 05:46 PM   #149
EnduroRdr
Woods Racer & D/S Rider
EnduroRdr's Avatar
Location: Formerly South MS, LR-Ar, Houston-Tx, now BR-La
Oddometer: 778
Nice Job! Share more links and pics -
EnduroRdr is online now   Reply With Quote
Old 11-05-2012, 06:13 AM   #150
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,271
The SE is very planted off road, on road it is a bit sluggish turning but it will turn with the proper inputs. The ninja turns great on road, but off road is a bit more skittish. I think it has to do with the wheelbase and the weight distribution, with the ninja, the weight is rearward oriented. I think extending the ninja swingarm 3" or so would make a huge difference off road and I'm willing to live with the on road handling changes.
KTM 950SE Ninja 650r
Wheelbase:1,570 mm (61.8 inches) 1,410 mm (55.5 in)
Times are GMT -7.   It's 07:15 AM.
