Old 05-24-2010, 09:38 PM   #46
usgser
Oddometer: 2,133
Originally Posted by sanjoh
As of 4-19-10
[IMG]
My goals for this project:
<350lbs wet
fuel injected
6 speed
Reliable
Plenty of travel
200mi range
Slanted toward dirt
Minimum of 2 cylinders
<$3000
I like your goals except for "Minimum of 2 cylinders" for me it'd be max 2 cyl.
Ok, I'm curious what did the wet weight turn out to be?
usgser is offline   Reply With Quote
Old 05-25-2010, 06:25 AM   #47
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,920
Originally Posted by Scribe
I'll take one. Where do I send my deposit?
Get your tools out. Cheap 650r
I'm down to 2 bikes as this one does everything well.
Dry weight is just under 360lbs.
It does need some protection Last week in Va
Old 05-25-2010, 04:24 PM   #48
jdrocks
Gravel Runner
Oddometer: 4,269
when you order a new cover and gasket, get the two small alignment dowels also. sometimes you can wiggle them loose and reuse them, but sometimes not.
jdrocks is offline   Reply With Quote
Old 05-26-2010, 05:47 AM   #49
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,920
Bought used one from ebay for <$20. I'm going to add some al or ss plates to the side cases. The side case is structurally sound but susceptible to punctures.
We were able to get the side cover off for repair without damaging the gasket.
No leaks
Old 06-03-2010, 07:45 AM   #50
Scribe
£Bob£
Scribe's Avatar
Oddometer: 7,168
When did you shave your head?
"Do or do not. There is no 'try.'"
— Yoda
Man Ball Rolls Through Coloutahrado 2014!
Scribe is offline   Reply With Quote
Old 06-03-2010, 05:55 PM   #51
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,920
Thats one of my minions hard at work.
Old 06-06-2010, 08:33 PM   #52
crspep
Circling the drain
crspep's Avatar
Oddometer: 166
build report
Right on, nice build report. I'm glad to hear that she's working out for you, I'm really starting to enjoy mine as well...... It should be nice once all of the details regarding setup are worked out, and the refinements are done [if ever]...... Do you ever plan to head out west ?
Me: Gear on and waiting for my race partner to hand off the bike. 8yr old kid: Hey, you race'n ? Me: (looking around to see if he"s talking to someone else).. Ummmm, yeah. 8yr old: What kind of bike you ride'n ? Me: KX 500. 8yr old: (looking puzzled for a second.) Ohhh, you're riding that OLD bike.
crspep is offline   Reply With Quote
Old 06-08-2010, 12:12 PM   #53
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,920
Probably be next year but yes.
Old 07-19-2010, 08:50 PM   #54
Hatch
PAR OG
Hatch's Avatar
Oddometer: 3,140
dang man, one of the baddest build threads ive seen! sweet scoot!
Hatch is offline   Reply With Quote
Old 07-21-2010, 02:31 PM   #55
Michelangelo
2 wheel rider...anytime..
Michelangelo's Avatar
Oddometer: 1,669
I like your idea on this bike.
Very similiar to this SV650 modded.
Michelangelo is offline   Reply With Quote
Old 08-16-2010, 07:53 AM   #56
dentvet
Oddometer: 1,345
what CBR shock is that?
did you figure out the peg solution?
where did you source your Universal Top clamp?
i'm in the kitchen, following your recipe
dentvet screwed with this post 08-16-2010 at 08:53 AM
dentvet is offline   Reply With Quote
Old 08-16-2010, 12:26 PM   #57
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,920
The shock is off a cbr 600, pressed the bushing/bearing out of the ninja shock and shaved a bit off the trunnion to make it fit.
Recent update:
Added topcase mount which now holds givi racks. Rox risers
Old 08-22-2010, 07:24 PM   #58
dentvet
Oddometer: 1,345
well i picked mine up today:
woodswizard said "you'll be riding it this afternoon" he was right
i put some dirt handle bars on but still wasn't close to good for any kind of standing position. do you guys stand at all? i would need about 8-inch higher bars or 4 inch lower pegs
off topic but i guess the speedo runs of tranny sensors? where is the bike's odometer data stored? a brain or in the clocks? my clocks are dead
Old 08-23-2010, 08:23 AM   #59
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,920
Great pic with the grinder n bike
Yes on standing, 2" rox risers are no problem with stock cables stock KTM Magura bars, MFW lowered footpegs.
The stock speedo runs off a pickup on the counter sprocket shaft. Running the stock gearing (15/46) an 18" rear with knobs it is +-1mph per GPS.
Not sure on ODO storage, I'd say it's in the gauge pod.
What plans do you have for your new beastly?
Old 08-27-2010, 05:33 AM   #60
dentvet
Oddometer: 1,345
i got it to follow your recipe, i already have most of the ktm stuff off my other bikes. I need to get it salvage inspected first so i think i'll do a bare minimum and go piece by piece. i need to ride it around to see if i like the motor etc.
i see the other mutants trying to go with 19 inch fronts and i'm just wondering what the ideal wheel setup is. 18/21, 18/19, 19/19?
the bulbous fuel tank bothers me, maybe i can grind it down...
ps i had never been to a horrible freight store before that day, i was giddy and disgusted at the same time trying to resist the mini lathe urge now
Times are GMT -7.   It's 12:28 AM.
