08-27-2010, 06:28 AM
#61 |
Purveyor of Light
Oddometer: 3,665
Wheel size follows what kind of riding you plan on.
The motor/gearbox is the highlight of the bike. I will install a 48t rear sprocket so 1st gear is more in the power. You will need a lathe or a friend with one:)
Model 60 LED 3600 lumens . . LED thread in Vendors Dualsport Fairing w LED...Dirt Ninja Build...TAT 08... |
09-16-2010, 06:45 AM
#62 |
Oddometer: 126
Very nice build! When can I expect to see a Sanjohsaki dealer in my area? Their product line is rather small but very interesting.
I have a couple of questions for you if you don't mind. First, unless I'm wrong, you are reducing trail when you swap to a leading axle fork. Did this have any adverse effects on handling or is this being compensated for by having the bike raised more in the front than in the back? Did you sit down and calculate the suspension geometry you wanted to attain or did you just do it by feel? If you did have a target would you mind sharing it? Secondly, I'm curious what you've done with your footpegs following the break. Did you replace with stock parts or work out a way to drop the pegs while you were at it? Any pics? Thanks for sharing the fruits of your innovation with us.
Bikeless bum |
09-16-2010, 07:03 AM
#63 | |
Purveyor of Light
Oddometer: 3,665
The main measurement I was interested in was the rake. I didn't have any control over the trail, without big changes, it is what it is. The rake is between 25 & 26 degrees. I had modified (grinder) the previous footpeg mounts to fit the buell pegs, I bought another set of peg mounts with pegs for $16, added the vario MSW adjustable pegs and all seems ok, just stay away from the big air The bike retains a lot of it's sportbike handling, I'm currently on a multiweek trip, just rode the Cherohala and Dragon. Damn close to sportbike performance (sans luggage) with the Shinko 700s.
09-16-2010, 07:33 AM
#64 |
Oddometer: 347
rake, trail, two cents
one thing to remeber when playing around with offset, rake and trail and such: for a given offset/rake/head angle, changing wheel diameters will have an effect on trail. decreasing wheel diameter will reduce effective trail, while increasing wheel diameter will increase effective trail.
i haven't crunched the numbers on that to verify exactly how much change is effected, but going from a 17 to a 21 front wheel then slapping an offset axle front fork on there actually makes some sense. also explains why certain mx bikes converted to supermoto with no change in fork offset or geometry tend to be a bit squirrely on the brakes... |
09-16-2010, 08:07 AM
#65 |
Oddometer: 126
Thanks for the feedback, that's great to hear. And yes, it makes sense that changing the front wheel diameter and also presumably raising the front suspension a bit more than the rear would help offset the loss in trail. I'm glad to hear that you didn't have to be a super-engineer to build a great handling bike.
What did you cook up for a windscreen (in that last pic)?
Bikeless bum |
09-16-2010, 08:41 AM
#66 | |
Purveyor of Light
Oddometer: 3,665
09-16-2010, 09:53 AM
#67 |
Oddometer: 982
in comparison to regular dirt bike ergonomics, the pegs aren't all that high, they are just too far back away from the grips, like 5-6 inches. this causes me to be tilted forward when standing, having to lean across to the bars.
i can see how a riser would help some but either the bars have to be moved rearward or the pegs have to be moved forward. i see that rox makes a pivoting 6 inch bar riser moving the pegs forward looks difficult as the shifter and linkage presents a serious problem, more so than the brake setup on the right side. here's mine so far, its kind of limbo until i get the inspection out of the way. i have a yamaha wr roller that i might scavenge for the frankenbike mods. so many options but i might like it as-is...
09-16-2010, 09:57 AM
#68 |
Purveyor of Light
Oddometer: 3,665
Ideally the peg would be up around the swingarm pivot for front to back location, height is another discussion.
09-19-2010, 06:37 PM
#69 | |
Riding is my passion
I'm really thinking I want to do one of these. My wife had owned an 08 Ninja 650R that we had bought salvaged and fixed it up for her that was her touring bike before her current F650GS. That was a great bike. We ended up selling it though, but it would have been a great platform. I've also owned a few 1st gen SV650's. I can't decide which bike would make the better platform to start with. The Ninja 650R is FI, but I could go with a 2nd gen SV, but I think the 650R's are cheaper to pick up. My hesitation with the 650R is the under bike exhaust (but you found a pretty good solution), and the weird rear shock. The SV650 (like the DL650 has the front oil filter out there, but bash plates are pretty easy to find for it.
BlueLghtning - Follow me on my SPOT Messenger Mine: 09 DL650, 01 FZ1, 08 WR250R, 98 DR650 Hers: 06 F650GS, 12 Duc 696, 13 CRF250L, 06 XT225 Smugmug Pics - Save $5: Y2l43o9LVBERU |
09-19-2010, 07:41 PM
#70 |
Purveyor of Light
Oddometer: 3,665
Yep that was me. I was on looong conference call otherwise I would have come out to say hi. It is a do it all bike, the ninjas are so inexpensive to begin with, I just bought the wife a brand new 09 er6n for<4k. Just turned over 17k miles riding in Missouri today. SE Missouri is sweet, great twisties, gravel, dirt, best of the temp was < 80
great change from FL.
09-20-2010, 09:26 AM
#71 | |
Yeah, the Ninja 650R's are dirt cheap and such great engines. We bought my wife's 08 salvaged with 1k miles on it for pretty cheap (all minor cosmetic damage). She put 17k miles on it before we sold it for $2500 and that ended up being pretty cheap as my phone blew up from the calls. I thought the rebuilt title was going to hold people back, but they jumped all over it. I owned a KLR for awhile and I really wasn't a fan of it. I think I'd much enjoy turning a bike like this into a fun DS. The Vstrom is my ideal bike for general riding, but I don't like to get it in too serious off road and the 17/19 tires don't have the tire options a 18/21 would. I think the Ninja 650R (or SV) turned DS bike would make a nice dual sport that is way lighter then a Vstrom, more capable off road, but can easily eat the miles up in between too.
09-24-2010, 06:42 PM
#72 |
Oddometer: 982
still waiting for a stupid state inspection! in the mean time i had a random question.
when (not if) i take my bike into the national forest, will i get hassled for a spark arrestor? does the stock ninja muffler have a spark arrestor? do most street bikes (gsxr)? mine has a 2 brothers exhaust that is more like "2 loud" and probably doesn't have a usfs approved sa. there is a local ohv place in the national forest that is patrolled |
09-27-2010, 09:18 PM
#73 |
Purveyor of Light
Oddometer: 3,665
You may get hassled for the spark arrester. I put a screen over the end cap on my GSXR 1k muffler.
11-20-2010, 03:12 PM
#74 |
Purveyor of Light
Oddometer: 3,665
I actually installed the swmotech crash bars today
![]() and measured for a shock. Looks like about 10.4" of available travel, although the swingarm is at an extreme angle. Low ride er ![]() Gettin High ![]() The swingam will bottom on the stock muffler, if that's gone then it will bottom on the muffler hanger which is now 1/2 original size.
11-20-2010, 04:31 PM
#75 | |
Gravel Runner
Oddometer: 2,773
crash bars? is that what they're for? did you happen to see my review of those folding mirrors? |
