Old 12-03-2010, 04:08 PM   #91
chorizo
Oddometer: 195
Yah what model and year CBR? Also it looks like the chain would grind on the swing arm. Are you replacing the chain guard frequently?
chorizo is offline   Reply With Quote
Old 12-03-2010, 04:15 PM   #92
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,217
Originally Posted by ktmklx View Post
Sanjo, do you have any details on the shock. Like where are you getting it? Is it a bolt in (other than the muffler bracket mod)? What features does it have?
Yes bolt in but you will need to remove the stock muffler and part of the bracket that holds the muffler. Shock is fully customizable. No remote res.
http://www.motocd.com/
email Rick the owner raceparts@motocd.com
Tell him I sent you
John
Old 12-03-2010, 04:16 PM   #93
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,217
I think it is an 02. Swingarm guard is in good shape after 13k miles with the shock.
Old 12-03-2010, 04:18 PM   #94
jdrocks
Gravel Runner
Oddometer: 4,516
Cogent Dynamics
jdrocks is offline   Reply With Quote
Old 12-03-2010, 05:06 PM   #95
ktmklx
ktmklx's Avatar
Oddometer: 696
When do you expect to get your shock? I am anxious to see it on the bike.
ktmklx is offline   Reply With Quote
Old 12-03-2010, 06:17 PM   #96
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,217
Not sure at the moment. I'll post up when I have it installed.
Old 12-03-2010, 07:28 PM   #97
Truckin_Thumper
low profile
Truckin_Thumper's Avatar
Oddometer: 28,890
Did you paint that Givi tail box you got from the Asshat?
Yes I have been lurking here..... and Migitizing the capo
gimmie the button!
Truckin_Thumper is offline   Reply With Quote
Old 12-03-2010, 07:39 PM   #98
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,217
Not yet, won't fit on the 650 as the racks I made are a bit too close. I was thinking about burying my dead cat in it or renting it out as garage space.
Migitizing or Midgetizing? Just get a step ladder I can see why you like the engine, just traded for a Futura.
Hope you are somewhere south and warm.
Old 12-03-2010, 07:55 PM   #99
Truckin_Thumper
low profile
Oddometer: 28,890
I am in Houston....
Hand built some Pelican racks and some other custom mods......fucker still sits to low, I need it higher....32" seat height means less ground clearance, I need a 37" seat and 12" of clearance
gimmie the button!
Old 12-03-2010, 08:14 PM   #100
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,217
I am in Houston....
Saw your handy work over in the CAPO thread
You need a dirt ninja
Old 12-03-2010, 08:24 PM   #101
Truckin_Thumper
low profile
Oddometer: 28,890
I need to build a mutt.....KTYammy
gimmie the button!
Old 12-04-2010, 08:46 AM   #102
chorizo
Oddometer: 195
Oh what fun. So what years work best for this project? Im seeing some cheap Ninjas. Also what dirt bike works best? Im guessing the forks are the the most difficult part. Actually it all sound too easy. And fun.
Old 12-05-2010, 04:46 PM   #103
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,217
06-08 are all the same and plentiful.
Old 01-15-2011, 08:13 AM   #104
dentvet
Oddometer: 1,369
allright i have my front end apart so i'm trying to figure out the stem bearing issues. the ninja has 35x55mm bearings. your R1 stem had a 30mm stem, so you turned a 35x30 spacer on your lathe?
i have a stem with 30 and 28 id bearings. i have found a 30x55 bearing (honda) but can't find a 28x55mm bearing. anybody know of one?
i just bought a lathe so maybe a 28x35 spacer is a doable learner project
this is a cool website for conversion info revealing that aprilia and ducati use the same steering tube dimensions as kawasaki fyi
https://www.allballsracing.com/index.php/forkconvertion
dentvet is offline   Reply With Quote
Old 01-15-2011, 12:05 PM   #105
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,217
That is an awesome site
Back when I did the front end I remember buying the race/bearing set with 55mm od (headstock id on 650r) with the smallest id I could find.
You are on the right track with the spacer. That would be a great first project for your lathe. You do need to be very accurate as it is a press fit so the tolerances are rather tight.
Times are GMT -7.   It's 11:24 AM.
