05-24-2010, 05:33 PM
#241 | |
Crash-Resistant
Oddometer: 123
![]() Maybe if your bike is on fire...
05-24-2010, 07:10 PM
#242 | |
PsyKotic Waterfowl
Oddometer: 9,966
93 K1100LT, 94 K1100RS, 86-97 K75F (K75/100/1100 Frankenbrick), 91 K1, 05 KTM 450 SMR IBA #17739 (SS1K, BBG, 50CC) http://home.comcast.net/~smithduck/BMW_Tours.htm |
05-25-2010, 01:05 AM
#243 |
Oddometer: 5
"Until you've made eye contact assume they haven't seen you"
The very first lesson my instructor taught me
2001 Black and Gold XRV750 Africa Twin or "Black Betty" as I like to call her
05-25-2010, 02:17 PM
#244 | |
GS Rider
Oddometer: 6
I installed and use a pair of hella fogs during day for extra lighting, vs using the high beam. my reasoning is that fog lights have a much wider dispersion of light so they look bright from all angles in front of the bike not just where your headlight is aimed. makes for a better chance for cages to see you. also, 3 lights are suppose to be better for other drivers to determine your speed on approach (all trains now have 3 lights so drivers/pedestrians can tell approach speed quicker.) I suppose you could argue that on a bike it would be pretty hard to get the lights far enough apart to help. but at any rate, the extra lights can't hurt.
Msport |
05-25-2010, 02:58 PM
#245 | |
Oddometer: 17,983
"Be who you are and say what you feel, because those who mind don't matter, and those who matter don't mind." — Dr. Seuss “Watch out for everything bigger than you, they have the "right of weight" Bib |
05-25-2010, 07:28 PM
#246 | |
PsyKotic Waterfowl
Oddometer: 9,966
05-25-2010, 07:33 PM
#247 | |
PsyKotic Waterfowl
Oddometer: 9,966
05-25-2010, 07:51 PM
#248 | ||
Oddometer: 17,983
05-26-2010, 11:13 AM
#249 | |
Oddometer: 101
It just blinds oncoming motorcycle riders and generally pisses off people in cars.SPD included I'm sure, those Silverstar bulbs are freakishly bright. Back on topic..As for stuff I wish someone told me about bikes. Thre simple adjustments that make all the difference in the world with handling. #1 Tire pressure. I always followed the psi molded into the tire. Wrong, try different pressures for different conditons front and rear and note the difference. #2 Suspesnion settings. Again middle is just a starting point. Spring preload, rebound and dampening all have profound affects on handling. #3 Chain tension. Often overlooked or simply neglected. At least on my dual sports it affects shifting and drivetrain noise. Something I often struggled with when I first rode on pavement was stopping in gear and searching in vain for neutral. 1st,3rd,1st,3rd on and on. Figured out the rolling "N" click pretty quick but nobody ever told me to do it, learned the "hard way". |
05-26-2010, 11:45 AM
#250 | ||
Oddometer: 3,667
Close your eyes, picture yourself sitting at a stop light. Now imagine behind you the SCRRREEEEEEEEEEECH of car tires, locked up and not stopping. Betcha wish you were in gear... |
05-26-2010, 12:10 PM
#251 |
Oddometer: 532
People like to say to stay in gear to keep from getting rear ended, but I am quite sceptical that by the time you hear brakes you could react fast enough to prevent a crash. You may be able to see someone coming too fast as long as you are willing to be on a hair trigger...
05-26-2010, 01:04 PM
#252 |
Oddometer: 532
I addressed the question of mirrors in my reply, and I am just as sceptical that you can always make a decision that someone is coming too fast and do something about it. I admit that you MIGHT.
05-27-2010, 02:44 AM
#253 |
Oddometer: 2,024
Until they look you in the eye assume they haven't seen you.
You can be sure of this! Addressing someone's concern that this might suggest that once they've looked at you, you're safe: After they've looked you in the eye, assume there's still a good chance either they haven't seen you or they consider motorcyclists targets. Where I live, you're required to dip your headlight for oncoming traffic and traffic you are following, regardless of the time of day. On the other hand when I started riding, we had dismal pre-focussed headlights which had a pretty hideous low beam pattern anyway. Low beams were more glary than modern halogen lights and high beams were pretty dismal. Riding on high beam in the day made you a bit more conspicuous without causing undue glare. This is the downside to modern decent headlights. Hopefully the super bright LED running lights appearing on European prestige cars will trickle down to bikes. Ride with headlights and/or LED running lights on in the daytime, reserve your high beam in daytime for getting attention. As for complete newbies braking; I remember very clearly riding my first bike (which makes it my first 3 months), approaching downhill a complex double intersection on a wet highway and realising very late that I needed to stop RIGHT NOW, not at the second half of the intersection. With just a few weeks experience, I hauled on the brakes and watched in a strangely detached way as my front wheel stop turning, several times, while I modulated the brake force, knowing I needed as much braking as I could get but that a stopped front wheel was a BAD THING(tm). I was well aware that the only reason I was getting away with it at all was that I was travelling bolt upright in a dead straight line. I stopped just short of the crossing traffic. This incident made a very strong impression on me. I learnt that in a dead straight line, I could brake to skidding if necessary. As a newby with just a few weeks experience and NO training whatsoever (just a multi-guess test for my learners permit), I would have been very poorly served by any advice other than: Use both brakes. Carefully. Especially on bends. |
05-29-2010, 04:07 PM
#254 | |
(Negativus Supersonicus)
Oddometer: 19,407
You shift from 1st to 3rd?
"If your mindset is that nothing was wrong, you will not demand new models." "System change is not for the conceptually or interpersonally fainthearted." - Sarason |
05-29-2010, 05:14 PM
#255 | ||
I'm a Believer
Oddometer: 356
If your riding is THAT dangerous, why do you do it?
2002 Suzuki DL1000 V-Strom - blue 2001 Honda Reflex NSS250 scooter - silver Real men wear boots. God is good. "Liberalism is a philosophy of consolation for Western Civilization as it commits suicide." - Dr. Jerry Pournelle http://jerrypournelle.com |
