Old 04-05-2010, 08:46 PM   #106
WhistlingFool
Dixie!? I know a Dixie...
WhistlingFool's Avatar
Oddometer: 693
Originally Posted by xymotic
By putting wieght on the inside peg you shift the center of gravity to the inside, this allows the bike to corner sharper with less lean. As the bike enters a corner, the bike drops to the sidewall of the tire and starts the turn. If the bike didn't lean into the corner, it would slide off, the lean opposes the centrifugal force. by shifting any weight to the inside of a corner, the bike can make the corner with less lean, meaning less time to get back up straight where full throttle can be applied. The faster a bike goes through a corner the farther it has to lean. By hanging way off the inside racers have increased the speed at which they can traverse a corner, whichs wins them races. . This *is* mostly a racing maneuver, but also adds to stability on road riding. You will see racers shifting their entire bodies to one side or the other as they attack corners. When I use this technique in a corner I am always amazed at how much less lean is needed when I shift my self to the inside. ... (to be redundant the Total Control book goes over this in a clearly understood way)....
and Larry said, "Wow, you really need to run out of gas more often!"
by Northwoods Yeti - "Rubber mallet and Crisco here I come...."
Read My 2005 Trip Report
WhistlingFool is offline   Reply With Quote
Old 04-05-2010, 08:56 PM   #107
xymotic
xymotic's Avatar
Oddometer: 8,367
Yes, but, um.
Weight to inside to get the bike to start a turn, then you shift the weight to the outside through the apex. So, you can certainly argue that the 'weight' is on the outside when you are actually in the turn.
On Dirt, you weight the outside, the bike naturally wants to fall down and you control that with your weight on both pegs actually but the outside predominantly.
At any rate this is not some important piece of wisdom for a "noob." It's a nuanced thing to become far more advanced.
Originally Posted by Just_Sean
Oh for ***k's sake Aaron. Please link us to my fascist, racist or homophobic posts.
"Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either."
Albert Einstein
Baja trip to the tip
6:10 to Yuma
trials and tribulations in the Mojave
Baja Blitz Yard sale
View Current Location via Spot Tracker
xymotic is offline   Reply With Quote
Old 04-06-2010, 03:32 AM   #108
redge
Oddometer: 226
Originally Posted by NEVERLOST
white helmets are more visable
My understanding is that this idea, which has a lot of currency on the internet, is based on a New Zealand study. One of the authors of the study delivered a paper which is available on the internet. The finding is not entirely consistent with what other studies have found about colour in relation to emergency vehicles. In the paper, she says that what they found in New Zealand may be the result of the fact that police officers there are associated with white - can't remember right now whether it's that police cars are white or that they use white helmets. She raised the possibility that in the absence of that kind of social conditioning/recognition, yellow or orange may be equally or more visible.
Shoei (but not Arai or Shark for some reason) makes helmets in solid white, orange and yellow. Having read the paper and a couple on emergency vehicles/school buses, and thinking about the geographic colours where I live, I decided to go with yellow. My bike is white :)
redge screwed with this post 04-06-2010 at 03:57 AM
redge is offline   Reply With Quote
Old 04-06-2010, 06:51 AM   #109
WhistlingFool
Oddometer: 693
Yes, but, um.
Uhm no.. .watch a asphalt race.. the weight stays on the inside until the bike starts to straighten up... in fact in the turn their feet are likely not even touching the outside peg and their entire bnofy (body)is shifted to the inside.....
and yes.. over kill for a noob thread.
WhistlingFool screwed with this post 04-07-2010 at 03:47 PM
Old 04-06-2010, 08:46 AM   #110
Aussijussi
Oddometer: 1,138
Weighing pegs
Uhm no.. .watch a asphalt race.. the weight stays on the inside until the bike starts to straighten up... in fact in the turn their feet are likely not even touching the outside peg and their entire bnofy is shifted to the inside.....
You can actually test this on a straight bit of road by putting your weight on either peg,and feel the bike change direction.
Aussijussi is offline   Reply With Quote
Old 04-06-2010, 05:04 PM   #111
duck
duck's Avatar
Oddometer: 10,403
You can learn a lot about hazards and mistakes by reading the Face Plant forum here.
duck is offline   Reply With Quote
Old 04-07-2010, 06:48 AM   #112
duck
duck's Avatar
Oddometer: 10,403
Parking:
a) In a normal parking lot, park your bike towards the rear of the parking space. If you pull all of the way forward then someone might assume the space is empty and try whipping into the "empty" parking space, not seeing your bike until it's too late.
b) Try to avoid parallel parking behind another vehicle. A motorcycle is harder to see and people will back over your bike.
c) Pay attention to where your wheels are and don't let them sit in puddles of oil/anti-freeze. From my experience this seems to be most prevalent at 7-11s and auto parts stores.
d) Try to avoid parking your bike pointing downhill. It's a pain if you have to back it up to get it out of the parking spot.
e) Always leave your bike in gear when parked, especially on downhill inclines.
Old 04-07-2010, 06:50 AM   #113
abhibeckert
abhibeckert's Avatar
Oddometer: 1,699
Learn your bikes limits. Find out how much acceleration/braking will get you on one wheel, find out how wet it needs to be to change that into a skid. You want to be able to instinctively and instantly adjust your throttle or brakes
to get out of these situtuations.
Keep in mind your position on the seat will change everything, and so will tyres.
abhibeckert is offline   Reply With Quote
Old 04-07-2010, 12:02 PM   #114
NEVERLOST
NEVERLOST's Avatar
Oddometer: 949
without a doubt. I mentioned white, but any hi vis makes more sense than a matte black lid...
NEVERLOST is offline   Reply With Quote
Old 04-07-2010, 02:05 PM   #115
xymotic
xymotic's Avatar
Oddometer: 8,367
Not just for safety either. I had (have) a flat black helmet, because it was too good a deal to pass up. While I've never actually noticed it once you get riding and air in it, it has gotten so hot you literally could not touch it when I've stopped places.
I'm 100% positive it has to be hotter inside as well, but I can't really prove that theory, maybe cuz it's already fried my brain.
Albert Einstein
6:10 to Yuma
Old 04-07-2010, 02:42 PM   #116
xymotic
xymotic's Avatar
Oddometer: 8,367
Originally Posted by DAKEZ
Shaddup you.
Albert Einstein
6:10 to Yuma
Old 04-07-2010, 02:48 PM   #117
dwoodward
dwoodward's Avatar
Oddometer: 5,566
I thought someone did a test on that, and a black helmet with airflow was the same temp inside as a white one. Maybe the shell gets hotter at stops. Then again, a helmet has at least the same level of insulation as a picnic cooler.
I've never let it bother me; I wear an AC-12 Carbon because- well, if I have to explain naked carbon fiber to you, you probably won't get it. When I'm wearing my helmet is as sexy as my head gets! (and with the mohawk on it, it's also as much "hair" as I've had in decades...)
dwoodward is offline   Reply With Quote
Old 04-07-2010, 09:40 PM   #118
kimel
I hit what?
kimel's Avatar
Oddometer: 211
Excellent thread!
As a sometimes driver of emergency vehicles with all manner of bright colors, flashing lights, sirens and the like I can tell you that the cagers are so freaking oblivious that more often than not they do not see emergency vehicles either. I do not care how much hi-viz you are wearing you aren't as big, bright and loud as an ambulance running code so you have no prayer of being seen.
If your bike has a reserve feature, remember to return the petcock to the non-reserve setting BEFORE fueling. Otherwise there is a very good chance you will forget after fueling and next time you need the reserve you won't have it. Been there, done that...twice.
kimel is offline   Reply With Quote
Old 04-08-2010, 03:17 PM   #119
Rider2205
Rider2205's Avatar
Oddometer: 247
These are going to sound dumb and obvious, but taking myself back 31 years ago, this is some of the advice I needed:
1. Riding with no shirt and no helmet isn't cool. Buy the gear and wear it all the time.
2. Check your tires' air pressure regularly (ideally every ride). Replace your tires while they still have some tread.
3. Jersey barriers + construction = sand and gravel spots on highways
4. Watch out for dogs, deer, and other critters.
5. Learn about countersteering and practice it.
6. Get some professional rider training (Your friend's stoner older brother teaching you to do wheelies does not count as professional rider training.)
8. Wet leaves and steel plates are really slippery.
9. If you can't ride at your own pace, don't ride with others.
10. Don't drink and ride, period.
Tom
KTM 950 Adventure
Recommended:
www.ridersworkshop.com (riding smooth)
www.dualsportriding.com (riding offroad)
Rider2205 is offline   Reply With Quote
Old 04-09-2010, 05:36 AM   #120
Blue&Yellow
but orange inside...
Blue&Yellow's Avatar
Oddometer: 754
How to quickly get a feel for a new bike:
Lots of good advice
Some more on how to get a feel for a bike more quickly:
1. Get a feel for the engine and gears: with a warm engine don't use full throttle but s-l-o-w-l-y rev it out in first gear, then in second. Then shift up and down and feel how the engine behaves and responds at different rpm and different gears. Try different gears while keeping a steady speed and so on. A common new rider mistake is to always shift to the highest gear possible since that's what you do in a car, with a motorcycle you will find that it often rides better in a lower gear and with less throttle. The engine will be more responsive and run smoother, don't worry about fuel consumption since bike engines are tuned for higher rpm than cars and sometimes higher rpm will actually improve the gas mileage!
2. Get a feel for the chassis: This is a little exercise that I call "the snake". If you find yourself on a wide straight road with little traffic you want to wiggle the bike from side to side. Keep your vision fixed straight ahead (this is very important!) then start with start with slooowly going from one side of the lane to the other side and back, then do it a little faster, a little faster again, and then a little faster again. Don't ever stop and straighten the bike out just keep on turning back and forth, back and forth.
You will find that to do it slowly you need not even turn the handlebars but merely think about it and you will move. But then the faster you wiggle from side to side the more force you will have to apply at the handlebars, and you are now counter-steering! If you do it really fast (only on good clean asphalt with warm tires) you will find that you are not moving your upper body at all but that your legs and the bike will swing beneath you. This technique of aggressive counter-steering is the fastest way to lean a bike over for a corner or to avoid an obstacle. It is profoundly useful!
3. Get a feel for the brakes: While on an empty road and traveling at the speed limit try getting a feel for the front break. You should squeeze with your knees and straighten your arms and back while at the same time squeeeeeezing the front brake. I recommend also pulling the clutch at the same time if you feel you can manage it. It should take maybe 0.5 second to go from no front brake to maximum front brake, this will allow time for the weight to transfer to the front wheel.
Start easy and then brake harder and harder, be prepared to release the brake if you feel that the front wheel locks up or the rear of the bike is coming up. During this exercise you don't need to use the rear brake at all, the rear brake is the good for small speed adjustments, works well at low speeds and on gravel and can also help stabilizing the bike in a corner. But the harder you need to brake the more front brake you need to dial in and the less rear brake you should use. Pro racers use the rear and front brake under maximum braking but for 99% of road riders it's safer to only rely on the front brake for emergency stops. This does however change a bit if you have a low slung cruiser, then you might have to use both brakes.... so essentially you need to practice braking with your motorcycle.
These three things will help you to more quickly grasp how a motorcycle goes, turns and stops....
Blue&Yellow screwed with this post 04-09-2010 at 04:39 PM
Blue&Yellow is offline   Reply With Quote
Times are GMT -7.   It's 07:30 AM.
