Old 01-05-2014, 07:50 AM   #1381
planemanx15
planemanx15's Avatar
Oddometer: 1,007
Originally Posted by orangebear View Post
not sure if thats right.?
as i was told to lean with the bike so if you come in to hot for a corner just lean the bike over more and you will be fine
Not sure if I'm doing it right, but if I feel like I am going into a corner too hot, I will lean it as far as I feel comfortable, then add more throttle. The bike will go lower into the lean, it will tightens the turn, and the turn feels more controlled. I still consider myself a noob, but this tip has worked for me.
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 01-05-2014, 05:30 PM   #1382
JohnCW
Oddometer: 1,252
What you have been told is fine, to a certain level. However, the next level is rather than lean your body and bike as one, practice leaning your body into the corner and keep the bike as upright as possible (the bike will be still lent over, but not as far). The more upright the bike the bigger the tire patch in contact with the road, and the less likely to catch a peg or your feet on the road. That's the main reason racers do it. For road riding a perhaps even more important reason is that it is much easier to alter a line going through a 'hot' corner with your weight out the side and pushing the bike upright, than being in a tight tuck greater lean angle position. You have much greater control to avoid that massive pot hole, loose gravel, or tightening radius corner that you didn't expect.
I'm at work right now (obviously not working) and when I get home tonight I'll post up some links that explain it far better than I can.
JohnCW is offline   Reply With Quote
Old 01-06-2014, 02:15 AM   #1383
JohnCW
Oddometer: 1,252
Here's a couple of video's that explain the concept of keeping the bike as upright as possible in a turn. While at least one for certain is part of a track day course, the basic idea is still applicable to road riding. The only difference is how much of the technique you apply. Not for a second is anyone suggesting you should scrape your elbow let alone your knee going around a corner on an adventure bike like Marc Marquez on a MotoGP bike. But there is value in understanding the concepts and applying then to some degree where applicable.
As I indicated in the previous post, I think the ability to more easily alter a line in a corner is worth it alone.
http://www.youtube.com/watch?v=znU_fyFZBRQ
http://www.youtube.com/watch?v=-ODL2iqVG9Q
Go try it yourself and decide. Find a sweeping corner and ride around it at a safe fast pace staying upright to the bike and just leaning. Take note of what your speed was. Ride around the same corner at the same speed but this time shifting your weigh across and forward dropping your shoulder and knee into the turn and trying to keep the bike as upright as you can as you give it some gas. If it doesn't go around much easier either (a) your probably not doing it correctly, or (b) ever pro racer in the world is doing something that doesn't work.
Like anything it takes a fair bit of practice to become fluid at it. Remember, lot easier to do if you keep the balls of your feet on the pegs. Good luck with it whatever you decide.
Even if the above is not helpful, perhaps there's a lesson for everyone in this lot. Every one of the front end wash-outs looks like it has one thing in common.
http://www.youtube.com/watch?v=55HaKeDDqT4
JohnCW screwed with this post 01-06-2014 at 05:39 AM
Old 01-06-2014, 05:15 PM   #1384
DAKEZ
DAKEZ's Avatar
Oddometer: 19,703
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 01-13-2014, 09:45 AM   #1385
DAKEZ
DAKEZ's Avatar
Oddometer: 19,703
Dare to be Aware
Use everything at your disposal, including vision, hearing, feel, and smell.
http://www.cycleworld.com/2014/01/13...src=SOC&dom=fb
Bib
Old 01-13-2014, 04:43 PM   #1386
Stens25
Back in the saddle..
Oddometer: 19
Hand and Arm position...
I'm getting back into riding again after 20 years away from it. Purchased a dual-sport a couple months ago and have been riding a little in the past week.
I have noticed that my hands are 'falling asleep' when I ride more than about 15 minutes. I'm not squeezing my hands or have some type of weird riding position. I'm 6-2 and riding a stock height Honda XR650L, so it seems to 'fit' me fine.
Any advice? My brain has me going in the direction of bar risers to lift my hands and arms a little higher. I seem to be pressing down into the bars at the current angle of setup.
Input would be welcome...
Stens25 is offline   Reply With Quote
Old 01-13-2014, 04:48 PM   #1387
geolpilot
geolpilot's Avatar
Oddometer: 117
Some beston grips from eBay might help a lot.
Sent from my SCH-I535 using Tapatalk
geolpilot is offline   Reply With Quote
Old 01-13-2014, 06:01 PM   #1388
fast1075
Fasterizer
Oddometer: 200
May want to work on your core strength a bit. Your arms should be loose. Stiff arming the bars can cause problems with control input, as well as fatigue. Practice, practice. You should be able to "chicken flap" your elbows at all times. Also practice not having a death grip on the bars.
It is a natural "survival instinct" to grip the bars tightly. Doing so impedes the bikes ability to handle properly and creates hand problems. It is something you do not think you are doing.
Remember that the natural action of the bike is to be stable. Inputs cause the bike to turn. Good practice is to go somewhere and do figure eights. You will soon find insight into the dynamics.
The older I get, the faster I was.
fast1075 is offline   Reply With Quote
Old 01-13-2014, 06:12 PM   #1389
JohnCW
Oddometer: 1,252
I'm the same height as you and ride a smaller XT250 as a commuter. I'm surprised that you would find the bars of this style of bike to low. A natural position is a feature of this style of bike.
The plank seats of dual-sport bikes can create problems. There are often very hard which means you tense up right up your spine, and the other problem is they make you slide forward. As a bigger person you probably need to sit back on the seat to fit properly, but the seat is always fighting against you in doing this. These problems can be corrected with a seat cover or change of seat. Not saying this is the problem, just something to think about.
Old 01-13-2014, 09:23 PM   #1390
sineti
luv2ride
sineti's Avatar
Oddometer: 20
wear your helmet and keep your finger on the horn when passing cars weaving through lanes-which your technically not supposed to do, but will have to do anyway.
sineti is offline   Reply With Quote
Old 01-18-2014, 09:06 PM   #1391
Stens25
Oddometer: 19
Thanks for the ideas...
Thanks for the ideas everyone. I'm going to try the risers and some Pro-Tapers.
Originally Posted by DAKEZ View Post
2" risers. You can thank me later.
Old 01-18-2014, 09:08 PM   #1392
Stens25
Oddometer: 19
Seat position...
Thanks for the ideas. My seat has been recovered, so I think I'm going to tear it apart in the next couple weeks and rebuild it. We have an upholstery shop pretty close, so maybe I'll go buy some high-quality, firm seat foam and give that a shot.
Old 01-21-2014, 06:01 PM   #1393
fast1075
Fasterizer
Oddometer: 200
I had a DRZ400 for a while. The seat was a pure torture device. It wasn't because it was HARD (which it was hard), it was that it was narrow, giving no support. I would be in agony after 40 or 50 miles. It was fun to ride, but I ended up selling it because of the horrible ergos.
I had a Buell Blast once that suffered the same problem with a horrible seat. I ended up with a Corbin on it. Nice wide seat pan for support. The Corbin was hard as stone too, but the added support made it a 500 mile seat.
The stock seat on my Buell XB12s was horrible too. Really thick soft foam, but was miserable. I put on a factory "low" seat that has far less padding, but makes the seat effectively much wider. Much better support, good for a few hundred miles without much trouble.
You results may vary.
Old 01-23-2014, 03:20 PM   #1394
usgser
Oddometer: 2,135
Sorry, didn't read the entire 100 pages of replies and not going into learning skills/motorcycle maint etc. IMHO number one survival rule is SITUATIONAL AWARENESS. #2 is: Don't put yourself into a scenario you're not skilled/capable of getting out of. Riding over your head is on parr with learning into a punch...never a good offense or defense. #3: Pain sucks.
usgser is offline   Reply With Quote
Old 01-24-2014, 04:54 AM   #1395
JohnCW
Oddometer: 1,252
Don't disagree....but! I'm currently teaching my 20 year old daughter to drive. She is up to a point of adequate driving technique, and a reasonable understanding of the road rules. But..... she lack appropriate SITUATIONAL AWARENESS. I keep constantly keep telling her to keep a greater distance, slow down approaching a heavy traffic spot, etc. But is seems without the potential situation having some real meaning due to a near miss or actual accident, goes in one ear and out the other.
Sort of a chicken - egg situation. How do they get situational awareness without actual situations making real the need to have situational awareness. While that experience may be an expensive trip to the panel shop in a car, it may be the hospital or worse on a bike.
Dunno the answer.
Times are GMT -7.   It's 03:28 AM.
