Old 02-28-2014, 10:08 AM   #1441
DAKEZ
DAKEZ's Avatar
Oddometer: 19,747
Originally Posted by MotoMusicMark View Post
I don't quite get what you mean by "Why be a target?"
Loosely Translated he likely means that you should always ride slightly faster than the general flow of traffic. (for safety)
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 03-01-2014, 01:33 PM   #1442
sailorninja
sailorninja's Avatar
Oddometer: 138
So, after I signed up for the Msf course, all was good until yesterday, get into the garage and attempt to crank my bike and realize she is having trouble starting/idling...AGAIN. The man I bought her from said she had cold start issues but they are nothing like the pain in the butt this has become. I'm wanting to practice and take the course and start riding and my bike is just like NO. Took out the carbs, cleaned them, replaced the oil filter and changed the oil and quite a few other things and she ran fine, started right up and everything was dandy, next morning she is at again. Not wanting to start or when she does, idle is a no no, unless you baby the throttle. I was so excited to get her but it's becoming a downer that every time I go to do ANYTHING with her, I can't. : right now my carb is taking a pine sol bath in hopes that it cleans out whatever I possibly missed. Lots of little black stuff down in it, so I'm hoping that was the issue? As someone who knows pretty much nothing of motorcycle mechanics, I'm not too trusting of anything I THINK is going to work. I'm between bring sad and getting REALLY frustrated. ghead:
I'm open to suggestions.
Sent from my DROIDX using Tapatalk 2
sailorninja screwed with this post 01-17-2015 at 10:01 AM
sailorninja is offline   Reply With Quote
Old 03-01-2014, 02:02 PM   #1443
Big Bamboo
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,952
The "Lots of little black stuff down in it" is most likely the fuel line disintegrating. That would explain why it keeps showing up and plugging your idle jets even though "boyfriend took out the carbs, cleaned them". One of the first things I do on any new to me vehicle is replace the fuel lines (belts, hoses, etc) ASAP.
Big Bamboo is online now   Reply With Quote
Old 03-01-2014, 02:11 PM   #1444
flei
cycletherapist
Oddometer: 1,093
could also be crap in the tank...
A clear conscience is usually the sign of a bad memory.
Steven Wright
flei is offline   Reply With Quote
Old 03-02-2014, 10:52 AM   #1445
ER70S-2
ER70S-2's Avatar
Oddometer: 6,938
The pilot jet is very small, if you don't have an inline fuel filter, get your SO to install one while he's replacing the fuel line (mentioned above).
From ProCycle
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 03-02-2014, 11:49 PM   #1446
Pecha72
Oddometer: 4,261
Originally Posted by jimearhart View Post
No matter the situation ALWAYS ALWAYS have an exit or emergency escape plan in your mind, you have no idea what can happen unexpectedly in the next second or two - Car in wrong lane, flat tire, animal etc etc etc.....
Couldn΄t agree more. What΄s written above here, is one of the most important things that you need in order to survive. Always stay one step ahead, that means you have an alternative plan, if (or when) something unexpected happens.
And I΄m not saying you should always go very slowly, but do remember that your options (or alternative plans) are reduced, as speed increases.
Countries ridden • FIN • SWE • NOR • DK • EE • LV • LT • POL • SK • HU • RO • BG • GR • IT • AT • DE • CZ • CH • SMR • LIE • NL • BE • FR • AND • ES • GBR • LUX • SI • HR • BIH • SRB • MK • TR • IR • PAK • IND • TH • KH • LA • MY • ID • AUS • CR • USA • ZA • LS • SWZ • MZ • NA • BW • ZM • ZW
Pecha72 is offline   Reply With Quote
Old 03-03-2014, 02:42 AM   #1447
JohnCW
Oddometer: 1,363
Originally Posted by geolpilot View Post
Don't tailgate. It is recommended to keep 2 seconds behind the vehicle ahead. I prefer 4 or more seconds. Just watch the vehicle ahead pass a landmark and count one thousand one, one thousand two and so on. If you get passed and that vehicle takes up your cushion space, slow and open it up again. I do the same in cars.
When following a vehicle on a two way street or one with intersections, the distance a motorcycle should leave to the vehicle ahead should be much more than if you're driving a car. If you ride at a normal car distance, a car coming in the opposite direction wanting to turn across the traffic, or waiting at a side intersection to enter or cross the traffic, can really only see the larger vehicle in front of you. If it is a truck you are following you will definitely be totally hidden. They will think there is nothing there and turn across straight into you.
Traffic lights are particularly problematic where cars want to hot-foot it turning across a break in the traffic. You should leave a large enough gap so that you are clearly visible to vehicles ahead without the car or truck you are following hiding you in anyway what so ever. Behind a large vehicle this can be quite a gap you need to maintain, anything up to 3 or 4 normal car distances back.
JohnCW is offline   Reply With Quote
Old 03-04-2014, 06:08 AM   #1448
jimhaleyscomet
Oddometer: 96
Limit your time riding when you first start out.
When you are a new rider limit the duration of your rides for a few months. Initially, after 30 minutes your concentration will start to slip. Later, after an hour or two your concentration will start to slip.
Actually, I have been riding for years and I still don't like road rides that last more than 3 -4 hours. I often make 1 stupid mistake after I ride for 3 hours. Even if I take a short break every hour, the ability to ALWAYS compensate for others' stupid moves seems to deteriorate after a few hours.
One time I missed a red light and almost ran it. Another time I passed stopped vehicles on the right to go ahead and turn right…. I should have waited till the light turned green.
jimhaleyscomet is offline   Reply With Quote
Old 03-05-2014, 09:12 AM   #1449
tommysmothers
Flamesuit equipped
Oddometer: 195
Originally Posted by sailorninja View Post
Anything I should know/consider before buying gear? I want safe but budget friendly, not sure if those go hand in hand but we'll see.
Price out everything before you start buying. Visit your local shops and look through their clearance racks. Some shops offer a discount for having taken MSF course. Try things on before buying.
Your riding style and conditions should influence your purchasing decisions. Leather provides the best protection, but isn't as comfortable as textile or mesh in the heat. Also think about the visibility of the gear. Textile often comes in Hi-Viz and leather does not, but you can always throw on a $10 reflective safety vest.
Do some searches on the web for "gear crash reviews" and "leather vs textile".
tommysmothers is offline   Reply With Quote
Old 03-05-2014, 07:02 PM   #1450
1911fan
Master of the Obvious
1911fan's Avatar
Oddometer: 3,252
Go to the Flea Market.
1911fan
Read The Patriot Post -- It's Right. It's Free.
http://patriotpost.us/subscribe/
Sometimes the light to see your way forward is provided by the bridge burning behind you.
1911fan is offline   Reply With Quote
Old 03-09-2014, 08:58 AM   #1451
JRWooden
Oddometer: 4,289
Sign up for these guy's emails: http://www.motorcyclegear.com/
Old 03-09-2014, 07:13 PM   #1452
brakedw
brakedw's Avatar
Oddometer: 67
When in doubt fill up the tank! Or your msr fuel bottle is no help in the garage!
So last Sunday I went for a group ride through the mountains and covered about 220 miles. By the end my fuel light had been on awhile and I was in a hurry to get home so I pushed my range limit and got home without a problem. At the time I had a msr fuel bottle on me in case I ran out. Well I had not ridden all week and decided to ride to work just to pick something up. I left my panniers and fuel bottle I the garage because my first stop was going to be a gas station a half mile away. I briefly thought of dumping my fuel bottle in the tank but really how much gas to you need to go 1/2 mile? Well apparently more than I had because I ran out at the bottom of a small hill 1/4 mile from my fuel bottle:(
My wife was kind enough to bring me my fuel bottle without calling me stupid ( but I could see it in her eyes) so when gas is all around don't push your range
brakedw is offline   Reply With Quote
Old 03-11-2014, 10:43 AM   #1453
SgtDuster
SgtDuster's Avatar
Oddometer: 3,418
What were the odds?!
2010 Buell Ulysses
1984 Suzuki GR650 "Tempter"
SgtDuster is offline   Reply With Quote
Old 03-12-2014, 09:42 AM   #1454
Newbee21
Oddometer: 45
1) The first year of riding is when 90% of bike crashes happen.
With a safety course the point is to get you into the 10% that
never crash .
2) If you have a 10.00 dollar head buy a 10.00 dollar helmet.
Newbee21 is offline   Reply With Quote
Old 03-12-2014, 10:22 AM   #1455
davenowherejones
short guy
Oddometer: 36
I would have quietly walked back for the gas and told no one.
davenowherejones is offline   Reply With Quote
Times are GMT -7.   It's 09:31 PM.
