Thread Tools Search this Thread Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
Old 03-28-2010, 05:13 PM   #1
Lumi OP
Lumi's Avatar
Oddometer: 17
Question Music on Zumo 660
I just got a 660 and the only directions were the "Quick start up manual".
This doesn't give any info on how to get songs on the unit.
Does the music need to be on a SD card or does it load into some internal
memory?
96GS w/sidecar "Batcycle"
03GS "Sport"
Lumi is offline   Reply With Quote
Old 03-28-2010, 05:34 PM   #2
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,656
memory?
I would never dream of listening to music on the bike, but this is how to do it:
Look at your Nuvi in Mass Storage Mode, navigate to either the Garmin\media\music on the 660 or the SD card, in X:\Garmin\media\music and add your MP3 files there.
Note you can also add podcasts too if they're stored in MP3 format. We love to get the Friday Night Comedy podcasts from BBC and listen to those in the cage.
Old 03-28-2010, 06:29 PM   #3
blackmamba
blackmamba's Avatar
Oddometer: 389
SD card ( micro)
2011 TRIUMPH Speed Triple
Couple of pedal bikes
blackmamba is offline   Reply With Quote
Old 03-28-2010, 08:00 PM   #4
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,755
Actually the correct folder (directory) for your MP3 music files on your ZUMO is:
\Garmin\anything you want to call it\
I would strongly recommend using as large a microSD Card as you can afford. You will not get very many MP3 files into the zumo internal memory before running out of room. I recommend that you put all of your data only on the microSD Card and leave the internal storage for the zumo's use.
Cheers,
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK screwed with this post 03-28-2010 at 08:06 PM
DRTBYK is offline   Reply With Quote
Old 03-28-2010, 08:13 PM   #5
DRTBYK
DRTBYK's Avatar
Oddometer: 5,755
The ZUMO 660 is much faster in how it Indexes your music and does not have to do a complete Index to your music every time you boot/turn it on like the zumo550 does. I have over 1500 tracks on mine and it takes less than a 50sec. to index when I rename the directory (worst case).
EDIT: Just noticed I had said 5sec and should have been 50sec.
Cheers,
Dan
All Things GPS
DRTBYK screwed with this post 04-04-2010 at 08:21 PM
Old 03-28-2010, 10:05 PM   #6
katego
katego's Avatar
Oddometer: 556
Originally Posted by DRTBYK
The ZUMO 660 is much faster in how it Indexes your music and does not have to do a complete Index to your music every time you boot/turn it on like the zumo550 does. I have over 1500 tracks on mine and it takes less than a 5sec. to index when I rename the directory (worst case).
that's good to know. i get some weird flaky behavior from my 550 when using large sd cards.
-k
Squaring off tires and tipping over bikes since 2005.
katego is offline   Reply With Quote
Old 03-29-2010, 03:24 AM   #7
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 13,093
And you can't download a manual from the Garmin site?
http://www8.garmin.com/manuals/zumo660_OwnersManual.pdf
dunno.....
Old 03-30-2010, 06:41 PM   #8
Lumi OP
Lumi's Avatar
Oddometer: 17
Thumb Thanks
Thanks for the replies.
I'll go shopping for a large micro SD card.
I did try searching the Garmin site for a manual without success.
I'll try the link provided.
03GS "Sport"
Old 04-04-2010, 02:57 AM   #9
Kiwirich
Kiwirich's Avatar
Oddometer: 179
Wink Micro SD Card
Apparently the 660 will only handle a 8 GB card maximum
Kiwirich is offline   Reply With Quote
Old 04-04-2010, 08:43 AM   #10
DRTBYK
DRTBYK's Avatar
Oddometer: 5,755
You don't have to search for Manuals on Garmin products. Just go to the product page and look at the right hand column -> Manuals
Cheers,
Dan
All Things GPS
Old 04-04-2010, 08:45 AM   #11
DRTBYK
DRTBYK's Avatar
Oddometer: 5,755
Hmmm, I've been quite pleased with my SanDisk 16GB microSD.
Cheers,
Dan
All Things GPS
Old 06-09-2010, 06:03 PM   #12
Pete O Static
Adventure Seeker
Pete O Static's Avatar
Oddometer: 584
$800 for a GPS and they don't even provide a proper manual?
Pete O Static is offline   Reply With Quote
Old 06-09-2010, 06:23 PM   #13
bombarde
DL650AK7 - K75
bombarde's Avatar
Oddometer: 260
The 16GB Adata card works fine as well.
bombarde is offline   Reply With Quote
Old 06-09-2010, 06:42 PM   #14
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,656
Define "proper".
I can't begin to count the number of "dead tree" manuals I have which I can never find when I need them, so I'd rather have the "E" version which I can download if I can't find it locally, on my computer.
Of course you can't read the "E" version in the tub, but that's a minor setback.
Old 06-10-2010, 04:20 AM   #15
Pete O Static
Adventure Seeker
Oddometer: 584
Yes I would agree with you regarding the dead tree thing. So they do produce a manual, it is just an electronic version.
Times are GMT -7.   It's 03:25 PM.
