Old 03-31-2010, 03:29 PM   #16
Dagofast
Full giggety ahead.
Dagofast's Avatar
Oddometer: 1,328
Originally Posted by kdxkawboy
+2
The wife has an Odyssey in her KLR and I am completely impressed. No mater how long the bike has been sitting it always cranks over and it has been in her bike going on 6 years. When the current old tech battery dies in mine I will put an Odyssey in my bike as well.
It was your sweetie who showed me on her bike how the Odyssey would fit in a KLR! Tell her Joe said howdy!
Dagofast is online now   Reply With Quote
Old 03-31-2010, 04:43 PM   #17
welder
welder's Avatar
Oddometer: 1,320
Odessey batteries are a pain as you have to extend the battery cables and mount the battery on its side. just get a agm replament and be done with it. no mods,no fluid to check. its just easy.
Anything is possible if you don't know what your talking about!
welder is offline   Reply With Quote
Old 03-31-2010, 04:53 PM   #18
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,546
Mike S.
'09 Bonneville Black
AMA MSTA STOC
http://autos.groups.yahoo.com/group/...orcycleriders/
tbirdsp is offline   Reply With Quote
Old 03-31-2010, 04:55 PM   #19
Twin headlight Ernie
bar napkin engineering
Oddometer: 1,282
battery
I'm suprised that guys are cooking a KLR battery. I have a FJ that I have to keep a eye on but my KLR has never been a issue. I use the cheap walmart battery too and get four years out of them at least. I have five bikes and use the same model YB14LA2 in all of them. I downgrade the oldest battery to my kickstart bike. Ernie
Motorcycles are my life.
Not my lifestyle.
My Smugmug:
http://twinheadlighternie.smugmug.com/
Dakota Motorsports
Twin headlight Ernie is offline   Reply With Quote
Old 03-31-2010, 05:14 PM   #20
Kevinhooa
Pitch pine slalom
Kevinhooa's Avatar
Oddometer: 420
Deka worked (and has been working) well for me. No way I'm going to worry about filling up a battery with distilled water on a trip. Especially without a kickstart.
There seems to be less and less garden in this state.
Kevinhooa is offline   Reply With Quote
Old 03-31-2010, 05:16 PM   #21
CA Stu
CA Stu's Avatar
Oddometer: 42,603
Originally Posted by tbirdsp
Well - riding consecutive long days at high temps (July), low humidity (NM desert), high rpm (14 t sprocket on front). I had to refill it once in the middle of the trip then it was dry again when I got home.
Stock electrical system with no extras except a GPS ( hardly any draw).
You've got other problems, I reckon.
I live in Riverside, it gets over 100 regularly all Summer long, I've ridden lots and lots of miles in the heat, I run a 14t sprocket, too, and every time my battery has needed replacing, it has been from sitting in my garage at home.
I'm sorry, but it's a total non-issue.
Rode to Baja a couple of times in the heat, Utah half a dozen times in the hotter heat, and a couple of times to Mammoth, once in the hottest heat of all hotness through Death Valley, never a battery problem.
CA Stu
CA Stu is offline   Reply With Quote
Old 03-31-2010, 05:17 PM   #22
CA Stu
CA Stu's Avatar
Oddometer: 42,603
The voice of KLR reason.
I slapped a new battery in the GS 1100 E I had for sale, same as the KLR battery.
CA Stu A13
Old 03-31-2010, 05:18 PM   #23
MotoBoss
Tundra Thumper
MotoBoss's Avatar
Oddometer: 2,226
Three years on this one Odyssey and never, ever an issue of any kind. Being a deep cycle it starts easier, charges stronger and runs add on's easily.
DONATE TO ADVRider
sidestandup.com ridedualsport.com
motoboss-terlingua-bound.blogspot.com
MSF Rider Coach-Rider's Edge Instructor-Track Coach
MotoBoss is offline   Reply With Quote
Old 03-31-2010, 05:21 PM   #24
CA Stu
CA Stu's Avatar
Oddometer: 42,603
In all honesty, KLRs are pretty easy on batteries. The motor spins over very easily, they are low compression, and they even have the KACR to assist in starting.
A replacement battery would be way down near the bottom of the list of stuff a new KLR needs in my book.
CA Stu
Old 03-31-2010, 06:41 PM   #25
subybaja
subybaja's Avatar
Oddometer: 2,874
Originally Posted by OP
Motorcycles owned currently:
04 Suzuki DRZ 400S, 05' KLR 650
Another happy Odyssey user here. Extending the wire is easy, and the bullet-proof battery is great.
We had part of a Slinky. But I straightened it.
subybaja is offline   Reply With Quote
Old 03-31-2010, 09:03 PM   #26
kdxkawboy
Mr. NVKLRGirl
kdxkawboy's Avatar
Oddometer: 2,631
Send a message via AIM to kdxkawboy
She remembers and says howdy back.
How hard can it be to install an Odyssey? With minimal mechanical background or experience my wife figured it out. While the old tech lead/acid batteries are easy to maintain and they are inexpensive and the KLR does use a common enough unit, I've had too many fail internally at the most inopportune times, like as the sun is going down and I'm halfway across the Lolo Motorway with no viable headlight and needing to bump start.
When the going gets weird, the weird turn pro
kdxkawboy is offline   Reply With Quote
Old 03-31-2010, 09:50 PM   #27
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,546
CA Stu
I don't know what to tell you - There's nothing wrong with my bike. How many other guys in this thread have reported the same thing? And it's certainly an issue if you've ever had to download all of your gear in the middle of a 15-day trip, remove side panels, seat, and battery, and spit bottled water into the fucker through a drinking straw in the parking lot of a convenience store.
A decent replacement battery would be way up near the top of my list of stuff a new KLR needs.
Mike S.
AMA MSTA STOC
tbirdsp screwed with this post 03-31-2010 at 10:07 PM
Old 03-31-2010, 09:52 PM   #28
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,546
The Deka AGM battery is pretty high tech, only half the price, works great, and is a direct bolt in.
http://www.eastpenn-deka.com/assets/base/0278.pdf
No brainer for me
Mike S.
AMA MSTA STOC
tbirdsp screwed with this post 03-31-2010 at 10:03 PM
Old 04-01-2010, 06:16 AM   #29
leon kawasaki
leon kawasaki's Avatar
Oddometer: 101
Odyssey
I put an Odyssey in mine 3 years ago and have forgotten I have a battery. I have dropped mine off road from time to time, and had issues with the stock battery leaking on the frame. My bike once sat for 3 months after a wreck and the Odyssey fired it up instantly. It is NO maintenance, and thats worth the cost. To its credit, the stock one lasted 4 years.
The install is no problem. It fits perfectly into the battery box sideways, as in the photos in other posts, and I didnt have to do anything but reroute some cables. Dont recall having to add any length to wires.
Travis
leon kawasaki is offline   Reply With Quote
Old 04-01-2010, 06:20 AM   #30
Iron Horse
I Make Shit Up
Iron Horse's Avatar
Oddometer: 8,448
Send a message via Yahoo to Iron Horse
STOP!
This is probably the best motorcycle battery I have ever bought. Cranks the engine faster and holds a charge longer than any others I've tried. Here is the right one for the KLR. $66.95 with free shipping.
DEKA PowerSport Battery (ETX15L)
http://www.tristatebattery.com/produ...roducts_id=977
+10000000
Wandering Wapiti
Iron Horse is offline   Reply With Quote
Times are GMT -7.   It's 03:24 PM.
