Old 03-11-2013, 08:21 PM   #181
lamotovita
Ageing Adventurer
lamotovita's Avatar
Oddometer: 1,495
Originally Posted by jonnyc21 View Post
The more I ride my 4RT the more I love it! However I was wondering what upgrads are worth my time?
I see things like the V-Mar Suspension Upgrade, Fender Spacers, V-Mar & Jitsie Brake Pedal options.
Not sure I will do any upgrading but would love to hear what others have done or like and why?
I assume you ride in some mud from time to time so the fender spacers are a good idea.
Other than that you should provide more info.
What class do you ride?
How big are you, what size boots?
The first rule of motorcycle modification is: If you don't screw with it, you won't make it any worse.
Beaten paths are for beaten men.
lamotovita is offline   Reply With Quote
Old 03-11-2013, 08:23 PM   #182
brianjonesphoto
Single Track Noob
brianjonesphoto's Avatar
Oddometer: 1,559
I haven't done much as far as upgrades, but some sort of fender spacer is a must around here. Instead of spending big money I went to my local good hardware store (not big box type) and found some nylon spacers and longer bolts. Same effect total cost $7
I have thought about doing the suspension links, but I'm still holding off. at my level a more stable and planted bike is a good thing.
When the time comes you and you need to replace your brake lever get the vmar one. it's worth the extra money as it nicely tucks out of the way.
Brian
Mine: 07 DL650 ABS, 99 DR350SEx, 05 Montesa 4RT Her's: 02 KL250 Super Sherpa
www.PhotoSupportNW.com
brianjonesphoto is offline   Reply With Quote
Old 03-11-2013, 10:05 PM   #183
jonnyc21
Trials ninja
jonnyc21's Avatar
Oddometer: 923
Eh? didn't think about extra info.
I am riding novice right now, however my friend riding with me has indicated that I am getting close to intermediate so maybe able to jump to the next level soon.
I am 5' 9-1/2" and am 80KG/175lbs, euro boot size 45.
jonnyc21 is online now   Reply With Quote
Old 03-12-2013, 12:05 AM   #184
Ross Brown
One AU out
Ross Brown's Avatar
Oddometer: 70
Try these:
S3 Hardrock Aluminium footpegs. I found that these make a significant change to the feel of the bike over standard as they are lower and more rearward.
Jitsie DB killer. don't notice any drop in power but the 'bark' is taken out of the exhaust. Much easier to ride in your driveway without annoying the neighbours.
Renthal Fatbars -
AjP shorty levers - luv 'em and make riding with a finger on the levers soo much easier.
Magnetic kill switch. Fall off and the engine dies - as it should.
Then add bling.
Also, there is a good case for not changing the rear shock linkage.
Ross Brown is offline   Reply With Quote
Old 03-12-2013, 01:59 AM   #185
jonnyc21
Trials ninja
jonnyc21's Avatar
Oddometer: 923
Originally Posted by Ross Brown View Post
Try these:
Renthal Fatbars -
Then add bling.
And the case for not changing it? (not that I was going to...)
Old 03-12-2013, 06:56 AM   #186
lamotovita
Ageing Adventurer
lamotovita's Avatar
Oddometer: 1,495
Moving into the intermediate class I'd think a heavy duty skidplate might be a good investment.
Old 03-12-2013, 07:00 AM   #187
lamotovita
Ageing Adventurer
lamotovita's Avatar
Oddometer: 1,495
The 4RT has a tip over switch that kills the engine if the bike is on it's side.
It would be helpfull to explain that case.
Old 03-12-2013, 02:58 PM   #188
jonnyc21
Trials ninja
jonnyc21's Avatar
Oddometer: 923
Intresting that you indicate it should kill itself. Tiped mine the other day and it didn't stop running, I had to hit my kill switch. (mine is a 2007 4RT)
maybe they didn't have that feture yet in 2007?
Old 03-12-2013, 03:10 PM   #189
brianjonesphoto
Single Track Noob
Oddometer: 1,559
my 05 has a tip over switch. it takes a good 30 seconds for the bike to shut down, but it does shut off.
Brian
Old 03-12-2013, 03:26 PM   #190
jonnyc21
Trials ninja
jonnyc21's Avatar
Oddometer: 923
That would explain it, I was able to press the switch right away so wouldn't have seen it stop by its self. Thanks.
Old 03-12-2013, 07:08 PM   #191
LowPSI
Oddometer: 272
If the bank angle sensor is working properly the bike should shut off after 7 seconds after it tips over.
LowPSI is offline   Reply With Quote
Old 03-13-2013, 12:23 AM   #192
jonnyc21
Trials ninja
jonnyc21's Avatar
Oddometer: 923
Prior owner put a heavy duty skidplate on already. (checked off!)
Old 03-13-2013, 03:48 PM   #193
jonnyc21
Trials ninja
jonnyc21's Avatar
Oddometer: 923
On the list.
I had a few on the list and after this here is what I think I am going to do...
1) S3 Hardrock Aluminum foot pegs
2) AjP shorty levers
3) Magnetic kill switch (Anyone know a good place to get one?)
I like the thought of the Renthal Fatbars, not sure the best place to get them, and looks like I would need upgraded clamps as well?
Old 03-16-2013, 09:26 PM   #194
mud
I just wander.....
mud's Avatar
Oddometer: 1,755
Originally Posted by LeShaghal View Post
> At $6-10K for a bike (used) over here. Figure the guy would make $800-1800 on each bike for his trouble provided he could sell them.
Is that really what these are going for over here these days????
Maybe it is time to get mine out of the shed....
2007 Factory Husaberg 380FE
2007 Montesa 4rt
1984 Husqvarna 500AE
mud is online now   Reply With Quote
Old 03-16-2013, 10:22 PM   #195
jonnyc21
Trials ninja
jonnyc21's Avatar
Oddometer: 923
I picked up my 2007 4RT for $5K about 4 weeks ago. so depending on year 6k - 10k doesn't seem out of range.
Times are GMT -7.   It's 04:37 PM.
