Old 05-03-2010, 11:13 AM   #61
AngryScot
AngryScot's Avatar
Oddometer: 18,321
Originally Posted by Oni
Don't order those!
When you take your light apart, you will see there is only 1 bulb...and it is right in-between the two lenses. You need a regular bulb or one of those LED lamps that have LED's facing all directions. The one you posted doesn't give off enough light...ask me how I know
The complete LED rear light replacement is nice though. Plan to get one someday. Nice and bright!
Oh yeah, I also run my 60CSx on battery. 1 set of NiMh lasts all day easily. I use a RAM mount for my dual sport, but just use the cheap Garmin handlebar mount on the scoot. Works fine and was only like $15 or 20.
Scrapped the bulb idea, didn't know about the location, I will do the LED version eventually, nice to have a bright tail light in commuter traffic for sure.
So far I have done the same for the garmin. Only issue is the one I caught will power off if I hit a large bump. Not a huge deal but kinda annoying, need to see if there is a easy fix for that other then wire it for power.
I seem to like to stretch out and not use the floor board too much, so I cut out some of my fav rubber diamond plate and stuck it on so it has some more grip and doesn't look so messy with all the scuffs etc on the smooth plastic.
(very klr I know!)
mileage update now 83mpg as of last fill up with 2/3 throttle and a small amount of WOT and a whopping 51.7 mph gps indicated
now to figure out the rear rack thingy since they are on back order from Japan.
Might go the welding route O'Hooligan mentioned
but I need to find a damn welder first that is local
⊕R1200GS⊕ For sale soon, snap it up and contact me.
⊕Zuma 125⊕For sale soon, snap it up and contact me.
Save $5 on Smugmug "so9RUAXlMm0bE"
AngryScot is offline   Reply With Quote
Old 05-08-2010, 08:41 AM   #62
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,783
If you want a really bright brake light, and I mean really bright, it's a fairly simple mod to add a Whelan LIN3 LED brake light. You can see it in the pics below--it's that little rectangular thing mounted above the strip of red conpiscuity tape and below the license plate.
If you go to the page linked above, there's a warning that sa
ys "NOTE: This lighthead cannot be used as a Brake/Tail/Turn lighthead." They are not saying you can't use it as a brake light. What they're saying is that there's only one intensity level, so you can't use it as a combined brake light and running light.
For my install, I carefully cut a rectangular hole in the fender then epoxied the light into place. I used masking tape on the outside so that once the epoxy was set up, I could pull off the tape and have a nice neat looking appearance. The light comes with a bezel, but using the bezel only works if you're surface-mounting the light to a horizontal surface. This light is fairly directional vertically, while wide-dispersed horizontally. If you surface-mounted it to the Zuma fender, the light would shine above the cars behind you. You want to aim it towards their eyes.
WUMPA
Sidecardogs.com
DRONE is offline   Reply With Quote
Old 05-08-2010, 08:13 PM   #63
wanna bECO
wanna bECO's Avatar
Oddometer: 727
Drone, not only the light, but your whole bike looks.. bitchin!
Just cuz my bike is shiny, doesn't mean that I'm a hiny
current stable
'94 Harley .... a blue one
'82 Honda passport
'87 Honda spacy 250
And an E Bike
85 spacy 250
81 passport (in pieces, many parts for sale)
The hit's just keep coming.. bought another 81 passport (11-28-09)
http://tiny.cc/ITgetsBETTER
wanna bECO is offline   Reply With Quote
Old 05-08-2010, 10:19 PM   #64
AngryScot
AngryScot's Avatar
Oddometer: 18,321
very nice.
Fancy telling me about the fender cut? No spray I assume from wet riding. Looks much better then the stuck flipper tail thingy.
Nice rear shocks too!
Old 05-31-2010, 08:48 PM   #65
Poke it w/ a stick OP
Poke it w/ a stick's Avatar
Oddometer: 210
Well, it died.
I went to run some errands and it died at a stoplight. Would turn over, but not restart. Then it would start and run for a few seconds.
It was 95 degrees in town. I pushed it 3 miles back home. I would try to start it and would run for only a few seconds. Then, two blocks from home it fires up and makes it home.
I think it's the fuel pump. '09 with 833 miles on it. Others seem to have a fuel pump problem with low miles, particulary in warmer temps.
You might be on 'B' Squad, but you're the 'B' Squad leader.
Poke it w/ a stick is offline   Reply With Quote
Old 06-01-2010, 01:08 PM   #66
AngryScot
AngryScot's Avatar
Oddometer: 18,321
Originally Posted by Poke it w/ a stick
Well, it died.
that sucks, let us know how it works out
maybe the extend warranty is worth it
AngryScot screwed with this post 06-04-2010 at 02:33 PM
Old 06-04-2010, 01:12 PM   #67
RideandDrive
RideandDrive's Avatar
Oddometer: 35
My fuel pump failed at 4100 miles. At high temperatures, the pump would not run. If I let it cool a few hours I could get it to prime correctly.
I just installed a new one and there seems to be some debate on whether Yamaha changed the design of the pump. It looks the same on the outside, but it had a different number painted on the housing.
RideandDrive is offline   Reply With Quote
Old 06-14-2010, 06:45 PM   #68
ebrabaek
Oddometer: 4,745
It has been re-designed......and old units purged from stock. It was a one way check valve inside the pump that failed in the closed position.....preventing the pump from working.......
Erling
ebrabaek screwed with this post 06-18-2010 at 09:01 PM
Old 06-14-2010, 11:17 PM   #69
redhandmoto
redhandmoto's Avatar
Oddometer: 587
Originally Posted by Cortez
and - finally - the 164 bbk, clutch, gears, and pipe are in. It rips.
On second break-in oil change now. Still keeping it cool for a while yet... but, oh hell yeah...
redhandmoto is offline   Reply With Quote
Old 06-15-2010, 07:58 AM   #70
Cortez
BAZINGA!
Cortez's Avatar
Oddometer: 7,082
Thanks for remembering!
I'm still here for more!
Make sure you do the math at gas stations!
'08 Yamaha FZ6n S2 ABS
SOLD: '03 Peugeot Speedfight2, '07 Kawasaki ER6F ABS, '06 Kymco Agility 125, '12 Kymco Downtown 300i ABS
My Flickr gallery --- My 500px gallery
Cortez is offline   Reply With Quote
Old 06-15-2010, 08:21 AM   #71
redhandmoto
Oddometer: 587
well ya know, Cortez, the thing is all like, ya know, uh, Goodbye, Earth People.
Gas mileage is irrelevant to me, for this bike. Gettin' better mirrors to watch behind for the Rollers, now, that's a concern...
Old 06-15-2010, 08:51 AM   #72
Cortez
BAZINGA!
Cortez's Avatar
Oddometer: 7,082
Well that's a bummer.. since one of the main reasons I went from a
50cc 2 stroke to a 125c 4 stroke was mileage. I do 1 tank in 3 days.
It used to be 2 days.
When you make $500/mo., and use $100/mo for fuel, it becomes a
big luxury, even with the little scoot.
Now I'm closely watching new fuel injected stuff in sub 200cc category.
Old 06-15-2010, 09:15 AM   #73
redhandmoto
Oddometer: 587
Well, you're right - the big bore kit is for performance, and mileage is part of the cost.
Old 06-15-2010, 09:23 AM   #74
Cortez
BAZINGA!
Cortez's Avatar
Oddometer: 7,082
Sometimes it isn't.
I've seen a few cases where 125 and 200cc bikes from same
manufacturers have the exact same MPG figures, and that makes
sense when you consider that the 200cc bike won't need that much
throttle to move.
There's a rather small difference in fuel consumption between my ex 50cc 2 stroke
scooter and my 650cc Kawi.. and no big-bore kit could get that scooter up to the
Kawi performance.
Old 06-15-2010, 09:30 AM   #75
Ken
Ken's Avatar
Oddometer: 57,617
Originally Posted by DRONE
[SIZE=2][COLOR=White]If you want a really bright brake light, and I mean really bright, it's a fairly simple mod to add a Whelan LIN3 LED brake light. You can see it in the pics below--it's that little rectangular thing mounted above the strip of red conpiscuity tape and below the license plate.
Thanks. I just ordered one
"God made hobos to make other men yearn." -Steinbeck
The modern liberal is the stupidest human being to have ever lived!
Ken is online now   Reply With Quote
Times are GMT -7.   It's 12:33 PM.
