Old 07-26-2010, 05:30 AM   #151
soph9
Bike Addict
soph9's Avatar
Oddometer: 2,333
Totally Water proof!
Although we have been in rain with our Safari's we have never hit rain like we did last week in Milwaukee. Record rainfall for that area in 3 - 4 hrs. they got 4 inches of rain. We were in that storm and i am PSYCHED to report our Jesse luggage kept everything 100% dry!
And you have to understand the rain was something we have never seen before and we are from the vancouver area of BC. 100% satisfied and living proof these boxes are water tight!
soph9 is offline   Reply With Quote
Old 07-26-2010, 07:02 AM   #152
lmclamore
Citation Collector
lmclamore's Avatar
Oddometer: 412
But there isn't a cloud in the sky in that picture.
lmclamore is offline   Reply With Quote
Old 07-26-2010, 07:09 AM   #153
soph9
Bike Addict
soph9's Avatar
Oddometer: 2,333
we could not take a pic of the rain....would have damaged our camera....it was so hard that day. Just wanted to show you our bags.
Old 07-26-2010, 08:00 AM   #154
Tor
Native Viking
Tor's Avatar
Oddometer: 803
Sooo,,,,when are you sellin' the Rev'it's and buying a Darien set? I mean since it was raining ....
"Be Always Sure You Are Right - Then Go Ahead"
2005 Honda ST1300 / 2010 BMW F800 Gelände-Straße
Tor is offline   Reply With Quote
Old 07-26-2010, 11:47 AM   #155
soph9
Bike Addict
soph9's Avatar
Oddometer: 2,333
I am retracting my opinion of the Revit...not sure any gear would have survived that amount of rain...
soph9 screwed with this post 07-26-2010 at 12:26 PM
Old 07-26-2010, 12:21 PM   #156
Tor
Native Viking
Tor's Avatar
Oddometer: 803
Originally Posted by soph9
I am retracting my opinion of the Revit...not sure any gear qouls have survived that amount of rain...
..just pulling your leg, Leslie,,,,,,,enjoy your trip...
Old 07-26-2010, 02:27 PM   #157
Spinalcracker OP
former redriderofma
Spinalcracker's Avatar
Oddometer: 1,083
All the cases are on and work great
Unless we change direction, we are likely to end up where we are headed.
It's county Fair time in New England
TET MA to NC
Vermont Covered Bridges
Spinalcracker is offline   Reply With Quote
Old 07-26-2010, 08:05 PM   #158
KnuckC
F8er
Oddometer: 199
I've straightened Jesses and racks a couple of times. Best way to straighten them is with a 6 to 8 inch tall hydrolic jack (2 to 6 ton jack). One secret is to use a piece of wood to make contact with the metal, and slowly pump the jack as you watch the straightening
Won't that pull the bolt right out of the crank in the bag or at the very least strip it?
KnuckC is offline   Reply With Quote
Old 07-27-2010, 08:50 AM   #159
CrazyMike
***42***
CrazyMike's Avatar
Oddometer: 908
Bluhduh Puddles in my Jesse Top Case
Rode home in the rain yesterday... Not really a problem for me as I keep a rain suit at work just for such situations and I personally don't have any issues riding in the rain. (Actually, it was the first time I used the pair of Frogg Toggs I purchased over a year-and-a-half ago, but that's another story.)
When I got home and opened up my top case, I found a pretty about a half-a-cup of water in there. This has happened periodically to me but I haven't yet figured out why. Luckily I wasn't transporting my laptop and the only other electronic device was not affected.
Anybody out there figured out why this occurs and know what to check to prevent it from happening again???
Any help is greatly appreciated!
Mike
1999 BMW R1200C
2009 BMW F800GS
WANTED: Kawasaki ZRX 1200R
CrazyMike is offline   Reply With Quote
Old 07-27-2010, 10:20 AM   #160
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
Assuming that your bike hasn't taken a nap on your top case and bent it out of true, I'd check to see that the rubber gasket is seated correctly all the way around first. Then I'd check to see that the bolts that pass through the case wall are tight and waterproof. Both were sources of leaks on my old Jesses. And as with all aluminum panniers, once you whack them hard enough, they'll never be water/dust proof again. That's the main reason I went with Caribous this time.
David
David
I'm tryin' ta think, but nuttin' happens!
--Curly
WoodWorks is offline   Reply With Quote
Old 07-27-2010, 12:26 PM   #161
CrazyMike
***42***
CrazyMike's Avatar
Oddometer: 908
Thanks David.
I'll check the gasket more closely (haven't seen any issues in the past) even though sometimes it happens and sometimes it doesn't.
Apparently I'm not riding hard enough because in 18K miles, my top case still hasn't been whacked.
Mike
1999 BMW R1200C
2009 BMW F800GS
Old 12-05-2010, 04:45 PM   #162
Tor
Native Viking
Tor's Avatar
Oddometer: 803
The lid latch on the Jesse topbox is mounted in oblong holes for up/down adjustments. I used clear silicone on the oblong holes (the lower part of the hole that was not covered by washer/nut) inside the box. This should take care of your leak in the topbox,,,,,other than lid gasket leaks.
Tor screwed with this post 12-05-2010 at 05:44 PM
Old 12-31-2010, 08:43 AM   #163
Tor
Native Viking
Tor's Avatar
Oddometer: 803
I'm still trying to figure out where to bolt my two 33oz MSR bottles. I've got two TT racks for them, but it's hard to find a decent mounting place on the Jesse Safari 9" bags. They need to be out of the way of the latch, and I don't want them to hang outside of the edges of the bag anywhere in case of a spill. I'll see what I'll do.
Old 12-31-2010, 08:56 AM   #164
soph9
Bike Addict
soph9's Avatar
Oddometer: 2,333
try the inside area of the panniers by the passenger pegs....like this....they do hang a bit lower than the bottom but there as far as options they are limited with this luggage.
Old 12-31-2010, 12:37 PM   #165
Tor
Native Viking
Tor's Avatar
Oddometer: 803
I don't know, Leslie, I just don't care for anything hanging below the bags :-)..
I really like the bags though. Outstanding quality.
Times are GMT -7.   It's 01:29 PM.
