09-06-2012, 03:19 PM
#196 |
when in doubt GAS IT
Oddometer: 1,667
Your local tuner should able to do it ,he just needs to get 3.3mm more on the shaft and the linkage ratio takes care of the rest, the seat height only goes up 3.3mm . Theres word of an ohlins TTX shock from RR-UK or Wilber's can make a custom
I have also ordered the new tanks and seat Then there's aust safari next which is 100% booked in so need to get this together ASAP . We have a bit of a team Lined up |
09-10-2012, 03:59 PM
#197 |
Oddometer: 1,667
So i need to build a custom exhuast and some brakets for the new kit ,So i have gone and got my self a STEL multi Multi/TIG and ARC I figure this would be the best for Rally racing being a small compact unit , for any emergency were i need to glue things back togetther ,
I have a cople of small projects first , New Custom DB killer for the akro bigger then standard New frame brackets for the tanks Repair Alu suspension linkage Then the big project is the custom under slung exhaust . Now i'm off to pick up stainless wire TIG tips and gas |
09-10-2012, 04:47 PM
#198 |
Guns are for pussies
Oddometer: 13,783
Why don't you put a carbie on that welder and ride it more..... uh, wrong thread
Really looking forward to your build guts!
Just say'IN |
09-10-2012, 05:36 PM
#199 |
Oddometer: 1,667
09-10-2012, 05:44 PM
#200 | |
Oddometer: 13,783
http://www.millerwelds.com/products/...p?model=M00361 I'm 99% sure I'm grabbing one in a few weeks.
Just say'IN |
09-10-2012, 05:54 PM
#201 |
Oddometer: 1,667
Very nice , just about spec a little more power as mine
http://www.stelgroup.it/scheda.aspx?...=multi&LAN=ENG just got to wait for the TIG torch to come in tomorrow .
09-10-2012, 06:02 PM
#202 | |
Oddometer: 13,783
Just say'IN |
09-10-2012, 11:20 PM
#203 |
Oddometer: 1,667
So out for my afternoon blast getting use to the new Suspension ,
Hmmm someone did not tighten the preload lock ring (I'm a dick )may have back its self off a bit , need to check sags when flat mate gets home A part from that man it's plush sooo nice nothing like the bone jarring back breaker that it was , I did a couple of tracks and it soaked up the ecellarating bumps like my 500 so nice , I wanted to find some fast chopped out tracks but being by my self and i didn't tell ant one were i was I left it at that . Had a play with the vortex as well I have not realy played with it at all , but with today little play around I have it on map 9 ( standard SM map ) with the fuel trims set 556 nice big mid range power stands from 70kph to 110kph love it , |
09-11-2012, 02:59 PM
#204 |
Oddometer: 1,667
I'm off to pick mandrel bend and exhuast tube
09-12-2012, 12:54 AM
#205 |
Oddometer: 733
Where are you getting your stainless from? Whats the grade?
If ignorance is bliss, why arenīt more people happy?????
09-12-2012, 01:38 AM
#206 |
Oddometer: 1,667
09-12-2012, 02:02 AM
#207 | |
Oddometer: 733
http://www.geordi.com.au/ They sell tube and pipe, 45 and 90 degree bends similar to to stuff that "sakurama" (950 ktm engine swap fame) used. They are pretty helpful when you drop in to. Although from a quick look 1 7/8 may be as you have found pretty hard to find. Maybe commit to changing the size.
09-12-2012, 02:25 AM
#208 |
Oddometer: 1,667
Thanks , I want to keep it 1,7/8 as much as possible so I can keep it tight to the motor but if I want to use my Akro I,ll have to flare it at the end , we're 2" would be fine , but I have a back up wings muffler .
09-12-2012, 03:30 AM
#209 | |
Oddometer: 733
http://www.ebay.com.au/itm/MV-AGUSTA...ht_1201wt_1180 For what I have done the first time I just used old exhaust tubing I had around. Any idea what bikes use the similar size tubing?
09-12-2012, 04:06 AM
#210 |
Oddometer: 1,667
Price been working next to Victorian motor cycle wreakers I have been in there a few times over the last couple of weeks
But thank for reminding me might head out the tomorrow when I pick up the TIG torch |
