Old 01-09-2013, 08:12 AM   #256
modeselector
Common as muck
modeselector's Avatar
Oddometer: 489
Originally Posted by Mudguts View Post
Very nice Mudguts
modeselector is offline   Reply With Quote
Old 01-09-2013, 03:55 PM   #257
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 824
Send a message via MSN to Gros Buck
They are acerbis unit you can get them at mxwest 1 this are KTM rally tanks they have always use these but use the hard parts gas cap
Well, I rather meant what's UNDER the gas cap. Sorry. I know these are acerbis. I wish we could see better the bolted-on aluminium filler neck ...
Paul Jr
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 01-09-2013, 10:49 PM   #258
Mudguts OP
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 1,668
Ooooooooh. Alu filler neck , rubber gasket , tank .
Mudguts is offline   Reply With Quote
Old 01-10-2013, 02:30 PM   #259
Gros Buck
Gros Buck's Avatar
Oddometer: 824
Euh !?!?!? Yeah ... ok ... alright ... but A Closer Picture of That Aluminum Filler Neck Please !!!
Paul Jr 8
KTM690r 2011
Old 01-10-2013, 02:43 PM   #260
Mudguts OP
Mudguts's Avatar
Oddometer: 1,668
Ooh bloody hell make work why don't you. Yeh NP coming right up
Old 01-10-2013, 03:19 PM   #261
Mudguts OP
Mudguts's Avatar
Oddometer: 1,668
Here's my little helper getting it into position for you
He is a certified areo space engineer likes to make sure things are spot on . Very fussy one of those micro management types
Old 01-10-2013, 07:01 PM   #262
Gros Buck
Gros Buck's Avatar
Oddometer: 824
Here's my little helper getting it into position for you.
Say thanks to your helper ...
There's an "O" ring underneath the flange ??? I'm asking because I know previous tanks (let's call EVO 1), while they had this flanged aluminium neck filler type (very early models), were leaking. However, the plastic base this aluminium filler neck is bolted today on seems more rigid.
Thanks.
Paul Jr
KTM690r 2011
Old 01-20-2013, 11:17 PM   #263
Mudguts OP
Mudguts's Avatar
Oddometer: 1,668
So i did not work today cause they have not paid me Soooo i thought it was a good day to work on the rally .
So first off I striped the RRUK tanks off and started the mocking up the tanks positions , It all went very easy due to the Scotts steering damper clamp , just
had too re-drill the hole out too 8mm and bolt on the the rubberised bolts they are sitting about 5mm to hi but they will squash down over time , Unfortunatly
i cant to the the key with some mods , Ill just cut down the plastic off the key and extend it , should work a treat .
Then on with the fairing it was all to easy just un-bolt one side panel and bolt on the the new one ,
Here is the side with the new fairing ,
Old 01-21-2013, 02:48 PM   #264
Mudguts OP
Mudguts's Avatar
Oddometer: 1,668
Ok Its time for me start thinking about the fuel pump situation ,I'm thinking the KISS method and that would a be a vacuum pump as used on the 640 ,660's and 690 rallys to pump it in to the rear main tank and let the eletric pump take it from there .
I'll have to use the same method as used with the RRuk tanks and let the rear tank drain a little then switch it over to all tanks
then i will let it gravity feed from full untill the fuel light then use the vacuum
pump to drain the front tanks in the rear as a reserve this is the simplest way i can think of , a bit of messing around with two peacocks one for vacuum and the other for fuel but it should work anyway if I'm that low on fuel in the outback i might walking anyway
I'll just have to use a peacock on the vacuum line for the last 2-3L or so of fuel in the front tanks .
Oh And thanks to Lukus who mentioned this a while back .
So i guess the reserve will be about 6L or about 100km only time will tell.
Old 01-29-2013, 10:46 PM   #265
Mudguts OP
Mudguts's Avatar
Oddometer: 1,668
Ordered some more parts , white plastics front and rear gaurds
More photos
Starting to mock up exhuast
Skinny mini about 2" skinnier at the knees then RRUK evo 1 tanks
Old 01-31-2013, 04:48 PM   #266
Mudguts OP
Mudguts's Avatar
Oddometer: 1,668
Tanks are fitted ( good enough to ride ) just need to cut out rear frame mount and weld it on , remake the front seat mount so the next big job is the exhaust I have made the first half which i will be done again but for now I take it up to the local exhaust shop and get some thing made up for now .
Fairing all fits nice that will be updated with a Carbon fibre 450RR fairing
painted the low gaurd black , Order all new white plastics as the 690RR fairing needs to be painted to mach the tanks .
Also made up some gaskets for the fuel filler as they were missing , Another little project is there is a ton of room under the
seat so i will make a plug from expanding foam then a carbon fibre tool box \ glove box . ( i will get a photo of how much room there is )
so that leaves
exhaust
bash plate ( pete640 I like you carbon one )
reg\rec bracket just needs abolt
krank case beather need to be re-routed up on top of the air box venting to atmosphere ( with a filter of couse )
New tyres
fit my other Ico
and last but not least a fully sick sticker kit as every one know a bike is not fast with out stickers
Mudguts screwed with this post 01-31-2013 at 04:53 PM
Old 02-04-2013, 04:07 PM   #267
Sol Erzenberg
Lost somewhere
Sol Erzenberg's Avatar
Location: Adelaide - South Australia, (near the T.T.G. Pub).
Oddometer: 1,015
so that leaves
exhaust
New tyres
fit my other Ico
Good work Mudders..
2009 KTM 690 R
"Thats A Sweet Noise You Got There Man, I Had You Picked Clear Across The Mallee"
2006 KTM 625 SXC
2005 Honda XR400R.
1998 Yamaha DT200.
1981 Maico 490M.
1979 Honda CR125R Elsinore.
1978 Suzuki RM 100.
ARIEL MCC
Sol Erzenberg is offline   Reply With Quote
Old 02-06-2013, 04:05 AM   #268
Knackers
Polishing Turds
Knackers's Avatar
Location: Drinking Vic, Qld & NSW Sewerage, Adelaide SA
Oddometer: 4,551
Been talking to Camo about this and the consensus is
GAY
How the hell did you get all this together?
It just happened, Max, you know?
A p-p-p-p-piece from here and a p-p-p-piece from there.
Knackers is offline   Reply With Quote
Old 02-06-2013, 04:07 AM   #269
Knackers
Polishing Turds
Knackers's Avatar
Oddometer: 4,551
Originally Posted by mudguts View Post
so that leaves
ability
Old 03-19-2013, 06:19 PM   #270
Peekey
Oddometer: 2
690 seat troubles
Hi
Has anyone had these problems with there KTM 2011 690E seats
The 1st is that it has cracked laterally between the 2 rubber supports above the battery. I have "fixed" this with fibreglass and by moulding a solid rubber support which sits on the battery bracket , straddles the wiring and fully supports the seat.
The other seat problem, which is baffling me, is the next set of rubber supports either side of the airbox that sit on the frame. The seat has spread apart and is now wider than the frame. The rubber supports no longer are on the frame.
Both these problems have occured with the stock seat and KTM power parts all day seat I purchased
Have anyone else heard of this?
Does anyone have a solution?
Has anyone or no anyone who might have a solution?
Peekey is offline   Reply With Quote
Times are GMT -7.   It's 09:33 PM.
