Old 07-04-2010, 12:15 AM   #106
Mudguts OP
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,128
Mudguts is offline   Reply With Quote
Old 07-04-2010, 05:23 PM   #107
tileman
tileman's Avatar
Oddometer: 884
Originally Posted by rosscoact
Part numbers would be great if its not too much trouble.
rossco
If your not in to much of a rush I'll be back in OZ in 2 months time and I have a near new set that will be for sale, part numbers listed below.
HL68151 Headlamp 90mm H7 Low-beam, ECE.
HL68152 Headlamp 90mm H7 Main-beam, with city light ECE
If ignorance is bliss, why aren´t more people happy?????
tileman is offline   Reply With Quote
Old 07-04-2010, 05:40 PM   #108
rosscoact
need constant supervision
rosscoact's Avatar
Oddometer: 5,503
That's fantastic, that would suit my timing perfectly, big thumbs up
thanks
ross
Stupidity got us into this mess, then why can't it get us out? Will Rogers
www.transaustraliatrail.com.au
rosscoact is offline   Reply With Quote
Old 07-04-2010, 05:48 PM   #109
tileman
tileman's Avatar
Oddometer: 884
thanks
ross
Cool, since I have a few things to do before I get home (organise 2 weddings, learn a language, move house, find a new place to name a few), can you PM in 7 or so weeks and I'll get onto it.
Old 07-04-2010, 06:07 PM   #110
rosscoact
rosscoact's Avatar
Oddometer: 5,503
no worries
Old 08-02-2010, 03:29 PM   #111
Evil Invader
Evil Invader's Avatar
Oddometer: 697
Thumb
And how goes...
690 "DIY" thread (incl. "Rallybike build"): http://advrider.com/forums/showthread.php?t=708813
M Motoadventures
Evil Invader is offline   Reply With Quote
Old 08-10-2010, 11:17 AM   #112
Grump
Grump's Avatar
Oddometer: 64
690 R Suspension
I am finding that the suspension on my new 690 R is not very compliant. In an effort to soften it I have backed out all damping settings completely ( apart from some fork rebound )and it still is very solid. I can live with the Shock action but not the forks. I note that the forks are supposed to have 275 MM of travel, yet after marking the lowest point of the seal travel on the fork (after braking sufficiently hard on a tarmac surface to break front wheel traction) I can only measure 185 MM of travel with the fork again fully extended. That equates to about 90 MM of missing travel. I previously had a 950 Adventure that used all of its travel and was very plush. Anyone got any ideas ?
Grump is offline   Reply With Quote
Old 08-10-2010, 11:26 AM   #113
Para504
Spam, Spam, bacon & Spam!
Para504's Avatar
Oddometer: 560
silly question, but do you bleed the air out of the forks regularly and if yes, have you checked the oil level in the forks? That said, the 690's (at least the "e" model) has much stiffer springs than is typical on a KTM off roader. My 690 forks are much stiffer that my 950A (which were overly soft), but seems to work pretty well when setup about 20 clicks out on compression - I forget the rebound settings off the top of my head.
Para504 is offline   Reply With Quote
Old 08-10-2010, 12:01 PM   #114
DirtJack
DirtJack's Avatar
Oddometer: 1,600
I increased the size of the air chamber (lowered the oil level to the lowest level recommended in the manual) and installed bleeder valves. That helped quite a bit. Also I found that some of the harshness disappeared after the bike chassis was broken in by riding off road. Mine had pre-load spacers which I removed to get a proper sag.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 08-10-2010, 01:27 PM   #115
Grump
Grump's Avatar
Oddometer: 64
Thanks for the advice.
Many thanks for the advice . Yes I have air bleeders installed and they are used regularly. However the increase in the volume of the air chamber makes perfect sense. I will check out the spacers also.
Old 08-15-2010, 03:19 PM   #116
clarky
05' 640 Adv
clarky's Avatar
Oddometer: 460
How are you going with it now Mudders? Got her finished yet?
cheers
Northern NSW
AUSTRALIA
clarky is offline   Reply With Quote
Old 08-16-2010, 06:30 PM   #117
mxbundy
mxbundy's Avatar
Oddometer: 954
Originally Posted by notmybikemodelname
That's actually modeling plastic for the beginning of composite bash plate mold.
I would like some more info on this stuff, where do you get it?
Bundy
mxbundy is offline   Reply With Quote
Old 08-16-2010, 08:46 PM   #118
Mudguts OP
Mudguts's Avatar
Oddometer: 2,128
More updates to come on the weekend , Getting the nav tower cut out this week
Old 08-17-2010, 03:44 AM   #119
PilbaraGoat
PilbaraGoat's Avatar
Oddometer: 218
Difficulties be Damned
PilbaraGoat is offline   Reply With Quote
Old 08-17-2010, 08:44 PM   #120
Mudguts OP
Mudguts's Avatar
Oddometer: 2,128
jUst ordered Vortex ECU it will be ready this afternoon
should only take 10 min to install.
http://www.vortexcdi.com/Mounting-%20KTM690.htm
lucky for me Vortex in only a 15 minute drive have had a vortex cdi on one of my old 525EXC i know how good they are , Speaking with richard he sudgested we go for two different map pro files
1st profile is stardard air box & slip on muffler with 5 other maps
2nd is opened airbox & slip on muffler with 5 other maps
As i have added 4 airvents into the snokle part of the air box but not in creased the actual mouth of the airbiox my theory is this will act like a ventury \ velocity stack .
Times are GMT -7.   It's 01:48 AM.
