Old 03-02-2012, 03:19 PM   #4756
Fatallybitten
Oddometer: 108
Gerbings Dual Controller, HDB Billet, Luggage and Auxillary Gas Cans
Today I finished up a number of mods that I have had underway over the winter.
I wired in my Gerbing's dual controller using the Highway Dirt Bikes' billet for the switches. It is a nicely finished and functional way of handling the switches.
Then I mounted my Happy Trail Mojave soft panniers and loaded them up to see how they worked. These are going to be my everyday panniers for day/weekend trips, as well as more serious off-road excursions. They come with waterproof inner liners and hold about 25 liters a side.
Right Side
Left Side
Next, I swapped the Mojave soft bags for my Happy Trail aluminum panniers that hold a combined 70 liters of gear. I have two waterproof bags that strap to the back rack, one holds 70 liters and the other 50 liters. All or some combination of this luggage will handle my gear for longer trips
Right Side
Left Side
Lastly, my solution for carrying extra fuel is to strap a 5 liter plastic gas can to each passenger foot peg and pannier. I haven't road tested it yet, but the gas cans are securely attached and I don't expect them to move. The location doesn't interfere with my riding position and has the added benefit of being situated low down near the center of the bike.
Right Side
Left Side
Now I just need winter to end so I can road test both of these luggage configurations and the auxillary gas cans in preparation for this year's trips.
Cheers, David
Fatallybitten is offline   Reply With Quote
Old 03-02-2012, 07:32 PM   #4757
Hobbes950
Darth Kitten
Hobbes950's Avatar
Oddometer: 1,712
Mended the wiring rats nest and started on the water pump rebuild. Tried to tap out the seal with the shaft but it just bent the cir-clip and tore the rubber seal in half.
I am going ttake that as a sign that the work needed to be done.
Pried at it bit, but decided to put off finishing for tomorrow. Time to try out the new heat gun!
When in doubt, take it as a compliment.
Lost Coast ride report
Nevada Desert ride report
Campoaventura
Hobbes950 is online now   Reply With Quote
Old 03-02-2012, 07:48 PM   #4758
bikepsych
Oddometer: 107
Had it dyno'd yesterday (sorry its a day late) and the PCV dialed in. Hopeing to pump up the MPG's back to 40+. Cranking out 102 ponies and 64 ft/lbs of torque. Now time for a new rear tire after the dyno run.
Bruce
Camarillo, CA
2011 KTM Adventure 990
2009 Harley Road Glide
bikepsych is offline   Reply With Quote
Old 03-02-2012, 08:52 PM   #4759
rinho
Rinho Féroce
rinho's Avatar
Oddometer: 971
Chain and sprocket replacement... and spend some time on the 2nd fan project
I use 0.050 aluminiun, because I did not have carboard to built the first pattern... finally, I guess it's stiff enough to be the final version.
Just have to add a bracket on the top, I did a mistake and cut it by accident
'06 950 LC8 Adv S
'02 F650GS (wife's bike)
'99 LandCruiser
'92 KTM 400 LC4 (the first 400 LC4 produced, pre-serie unit)
rinho is offline   Reply With Quote
Old 03-02-2012, 08:53 PM   #4760
rinho
Rinho Féroce
rinho's Avatar
Oddometer: 971
To be continued...
'06 950 LC8 Adv S
'99 LandCruiser
Old 03-02-2012, 10:24 PM   #4761
SierraJeep
It's toast
SierraJeep's Avatar
Oddometer: 564
Took a mild plunge into the next depth of the KTM lighting woes. Last year I bought the Euro light, today I ordered an HID 35w 5000 lum H7 low beam upgrade.
I did swing by a KTM shop down in Roseville and actually took a look at the KTM remote tripmaster switch. (I know, I know, I know, there's a ton of other cheaper do-it-yourself options out there.) What I really wanted to know was will that switch REALLY work with the newer style speedo units on the 990s (2009 to current). The KTM Twins site says it works with both the 950s and 990s, but the first two 990s used the older style computer. We looked at the instructions and it shows it only working with the earlier units up through 2005. The key thing (aside from accessing the Mode button remotely) is that the switch does NOT appear to allow the Trip 2 odo to be adjusted in flight - something that works on the EXCs and some of the older computers. So I didn't bother trying it. Bummer.
As such, I left the store with only a new die-cut KTM decal for my truck window.
Tod
2010 KTM 990 Adventure
2010 KTM 450 EXC
SierraJeep is offline   Reply With Quote
Old 03-03-2012, 01:55 AM   #4762
Autostream
Gravity flailer
Autostream's Avatar
Oddometer: 5,828
Developed a new power retardation system
Examined the undercarriage... more than once or twice...
You only need two tools in life: WD-40 and Duct Tape.
If it doesn't move and should use the WD-40, if it moves and shouldn't, use the Duct Tape.
Autostream screwed with this post 03-03-2012 at 01:41 PM
Autostream is offline   Reply With Quote
Old 03-03-2012, 09:17 AM   #4763
SidewinderX
Hey, watch this!
SidewinderX's Avatar
Oddometer: 893
Arrived home and was greeted by a nice package from Hontri..... Installed my underseat storage tray in just a few minutes. Well worth the $$. Nice finish and great fit.
Daniel
What would you attempt to do in life if you knew that you could not fail?
SidewinderX is offline   Reply With Quote
Old 03-03-2012, 10:09 AM   #4764
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 1,721
It works well on the 2008. You want to try it? I might sell it but you're welcome to try it first.
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 03-03-2012, 02:16 PM   #4765
TheMuffinMan
TheMuffinMan's Avatar
Oddometer: 3,718
Put CJ's plate on w/a Rotopax mount
2 Gallon Rotopax
"Civilize the mind, but make savage the body."
To the house of a friend the way is never long.
"Show respect to all, but grovel to none."
'12 690 Enduro // 690 Wiki
TheMuffinMan is online now   Reply With Quote
Old 03-03-2012, 02:50 PM   #4766
Supahflid
Wheelieless
Oddometer: 2,903
2 Gallon Rotopax
I just did that too. Are you going to leave it on when you are doing close to home or day rides? I'm thinking I might remove the tank and the bolt that holds it on when just tooling around.
Supahflid is offline   Reply With Quote
Old 03-03-2012, 03:02 PM   #4767
TheMuffinMan
Oddometer: 3,718
I'm going to remove the tank and bolt for around town stuff too.
Old 03-03-2012, 04:01 PM   #4768
Ladukebob
lost in hood river
Ladukebob's Avatar
Oddometer: 1,143
This-
Added the new ADV sticker today
2011 Dakar 30th Ann. 990
Never, ever, be in the wrong place at the wrong time
findLadukebob
Ladukebob is offline   Reply With Quote
Old 03-03-2012, 04:13 PM   #4769
southernADV
southernADV's Avatar
Oddometer: 81
In Argentina cost 35000 US dollars for the standard version!!
Never enough.......
southernADV is offline   Reply With Quote
Old 03-03-2012, 04:23 PM   #4770
Supahflid
Wheelieless
Oddometer: 2,903
Even though I haven't made the 10 plus gallon club, I am chuffed as monkeys to have an extra couple of gallons of go juice!
Times are GMT -7.   It's 09:47 PM.
