Old 03-07-2012, 06:06 PM   #4846
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,836
Originally Posted by BELSTAFF View Post
3) First farkels----BDCW skid plate & BDCW sidestand relocator----(you'll thank me later,--your welcome)
+1
I have a big dent in my BDCW skid plate, how in the world I did it I have no idea. It's thick steel. I know I would have just shattered the stock one with that hit.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 03-07-2012, 07:20 PM   #4847
MP5
MP5's Avatar
Oddometer: 253
Got into my carbs for the first time. Cleaned and inpected jetting as per H2W. All were correct based on my setup, but the mixture screw was off a 1/4 turn. Measured float heights and all were good. Installed my Uni Filter, buttoned her all back up, put on tank....and Bang....fired up w 1/2 choke. I dumped a little gas in the bowls b4 putting them back on carbs. Was hoping that would help starting the bike....seemed to. ....NOTE TO SELF...Don't turn left fuel tap on before connecting right fuel tap
Next on list....
Front wheel bearings
Clutch Jet
Front and rear brake bleed
Be another week b4 I get my things from CJ
'08 950 Super Enduro
'10 RMX 450Z
'09 Ultra Classic
MP5 screwed with this post 03-08-2012 at 05:32 AM
MP5 is offline   Reply With Quote
Old 03-07-2012, 08:56 PM   #4848
bikepsych
Oddometer: 210
Heidenau Scouts showed up at my front door today. I've got about 1000 miles left on the ol' Pirellis. They're already at 5k so I'm pretty pleased with their longevity.
BG
Bruce
Camarillo, CA
2015 Triumph Tiger 800 XCx
2009 Harley Road Glide
2006 Buell Ulysses
bikepsych is offline   Reply With Quote
Old 03-07-2012, 09:02 PM   #4849
Hobbes950
Darth Kitten
Hobbes950's Avatar
Oddometer: 3,893
Fork oil changed, headset bearing greased up, engine ice in, forgot to buy oil.
Slowly but surely I am getting it all done.
Tomorrow I tackle the front tire. Hope it goes easier than the first time.
Having a shop cat can be entertaining, but I wonder how much cat fur is now in my engine, clutch, forks, bearings....
When in doubt, take it as a compliment.
My Ride Reports
Hobbes950 is offline   Reply With Quote
Old 03-07-2012, 09:25 PM   #4850
Qwik
Adrenaline Addict
Oddometer: 6,738
Originally Posted by Katoom119 View Post
+1
Geek took a hit on his in Moab that if he had the stock setup he would've lost his clutch cover(I think) it was a HUGE dent from what I remember.
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 03-08-2012, 03:32 AM   #4851
The Bigfella
Big Adventurer
The Bigfella's Avatar
Oddometer: 2,471
Rode the SE through Tengger Semeru National Park. Through the big caldera, up Gunung Penanjakan, back down through the caldera again (on volcanic sand), up Gunung Bromo and so on. Had to rescue two soldiers at one stage. They went across a river in the caldera and hit soft sand - I got my feet stuck...sunk into the sand over the top of the boots getting their bike out. I'll get some photos up eventually. The net maxes out at about 5kps here.
A man should only do the work that is required of him. To do more is a form of greed.
Ride through Oz and Asia
The Bigfella is offline   Reply With Quote
Old 03-08-2012, 12:31 PM   #4852
jvg
jvg's Avatar
Oddometer: 37
Replaced Oil Pressure Regulator
2003 Adv -S
50 000km (~31000mi)
Had some problems removing the big M22 nut, but with a borrowed impact driver it was a piece of cake to get it off.
Regulator Spring is just below the min length 42mm.
Basket is in good shape, only slight wear.
Clutch Booster looks relative good, yes?
Not the best picture.
Discs looks almost like new, only the inner clutch disc has a groove from the spring washer.
/Joakim
KTM 950 Adventure S
| NorthCape 2010 | Geiranger 2011 | South Norway 2011 | Blh/Trontoppen 2012 |
jvg screwed with this post 04-25-2012 at 09:34 AM
jvg is offline   Reply With Quote
Old 03-08-2012, 03:38 PM   #4853
Narsisco Lopez
Addlepated
Narsisco Lopez's Avatar
Oddometer: 2,207
Installed the new Moto-Tuner LED tail light/turn signal combo unit today. An eBay find... perfect fit (brake light/tail light connector was a dead match) and super-simple to install. Has 2 extra leads (blue/left and yellow/right) for the turn signals. Tapped into the purple (left) and black (right) leads at the molex connector for the signals. Worked like a charm... nice bright tail light and super bright brake light. Half the light flashes yellow with the signals and the whole unit flashes yellow with the emergency flashers. Very cool!
My new set of Heidenau K60 Scouts showed up today, too...
Narsisco Lopez is offline   Reply With Quote
Old 03-08-2012, 06:59 PM   #4854
offworlder
Oddometer: 256
Replaced the front pads - again !
I had put EBC blacks on a mere 300km ago, and they're completely done. I was quite surprised, then again I spend 99.9% of my time on the beast in the dirt, sand, mud, sliding, spinning, etc...
Thankfully, a local dealer had a pair of EBC FA2092HH, slapped em in, and they feel much better (not as soft), and more importantly provide adequate braking/stopping. The stock (Toshiba) pads are obviously worth their weight in gold as they lasted nearly 5K ! I'm curious to see how long these EBCs last, and if not comparable - will revert to stockers...
Summary: for the monster (and me) - sintered pads are a must.
offworlder is offline   Reply With Quote
Old 03-08-2012, 07:09 PM   #4855
Qwik
Adrenaline Addict
Oddometer: 6,738
Installed My drain line for the Oil. Had to Buuy a new dremel because my old one died), Removed the Neduro Tank and shiped it off to SS in Vzla.
Then took it for a ride!
Old 03-08-2012, 07:55 PM   #4856
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,177
Finally!!!
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 03-08-2012, 08:18 PM   #4857
Qwik
Adrenaline Addict
Oddometer: 6,738
Ha!!!. Going to post my stock tanks and upper fairings on Ebay tomorrow too.
Old 03-08-2012, 08:24 PM   #4858
rinho
Rinho Froce
rinho's Avatar
Location: back in France but Soul still in North America
Oddometer: 1,117
2nd fan done !
Under seat boxe started
And new Acc fusebox
Sans un sou mais plus riche qu'avant
rinho is offline   Reply With Quote
Old 03-08-2012, 09:36 PM   #4859
Grayjet
Ride on!
Grayjet's Avatar
Oddometer: 450
one more technique
I just straightened out a paper clip, and then bent a small U in the end. Then I slipped the U past the metal end cap of the filter, hooked it on the back side of the end cap, and pulled it right out. No force needed, popped right out.
Try it, you'll like it!
Lance
Originally Posted by the cavalier View Post
I did my first oil change on my 950.
I spent over half an hour just trying to get my oil filter out!
I did not expect that to be so tuff. I was using some needle nose pliers, flat head screw drivers, I even pulled with a magnet and it wouldn't budge.
Then a friend wanders by and using the needle nose pliers pulls it right out!
does any one here have some slick trick to getting the stock oil filter out. there was not much room to work the pliers around and edge, and no lip of any sort to get a grip on it.
[the oil had been drained weeks prior do to a small wreck in which the bike caught fire below the carbs and above the engine. does it usually pop out with the oil coming out?]
I don't know how my buddy did it.
but thank god he did.
'93 Honda XR650L
'09 KTM 990 Adventure
Putting miles on the tires!
Grayjet is offline   Reply With Quote
Old 03-09-2012, 05:40 AM   #4860
SidewinderX
Hey, watch this!
SidewinderX's Avatar
Oddometer: 1,134
-Installed my new Leo Vince pipes. Very nice. Can be subtle but under a hard load has a nice bark!
-New air filter
-Installed Powerlet/ BMW plug into the glove box
-Installed a Wolfman bag on the rear.
I need a set of stock rear grab handles if anyone has some laying around for cheap.....
Daniel
What would you attempt to do in life if you knew that you could not fail?
SidewinderX is offline   Reply With Quote
Times are GMT -7.   It's 11:03 AM.
