Old 03-13-2012, 08:46 PM   #4951
Hobbes950
Darth Kitten
Hobbes950's Avatar
Oddometer: 3,860
Forks and front tire on. Almost all done.
When in doubt, take it as a compliment.
My Ride Reports
Hobbes950 is offline   Reply With Quote
Old 03-13-2012, 10:57 PM   #4952
rinho
Rinho Féroce
rinho's Avatar
Location: back in France but Soul still in North America
Oddometer: 1,098
Underseat extra box
Rear shock taken apart, all the dimensions are ok with the wheel being up at the maximum (and pretty forward, because of the 17x45 gear and brand new chain) ...
But with a trail Attack... I'll see if it's ok
Sans un sou mais plus riche qu'avant
rinho is offline   Reply With Quote
Old 03-13-2012, 11:19 PM   #4953
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,220
I finally got around to putting on a sidestand bracket, Weld86.
I did the get-those-damned-bolts-out-of-my-engine mod.
A 3/4" countersink is not quite big enough to get a 10mm screw to fit flush, but that is just as well, because I didn't want to get any closer to the edge of the bracket. I just made the screwhead a a few thousandths smaller to let it drop down into the smaller hole.
The mod seems to work very well. I rocked the bike back and forth on the sidestand while holding my fingers on the bracket and the engine case, and felt no flexing.
Another thing I had worried about turned out to not be a problem: I had thought that moving the stand that 1/4" might make the bike stand up straighter, but it actually seems to lean over a little farther.
At least my case that is good, because more often than not my bike seemed at risk of falling over because of too little lean.
I have an early bike, so I did have to grind the web on the frame, but other than that the fit was perfect.
All buttoned up.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle screwed with this post 03-13-2012 at 11:26 PM
MortimerSickle is offline   Reply With Quote
Old 03-14-2012, 04:51 AM   #4954
Remmie
Remmie's Avatar
Oddometer: 95
SE Rally Kit
Mounted my flashers and some extra lights under my SE Rally kit
Remmie
I recycle, I sniff my own farts
Remmie is offline   Reply With Quote
Old 03-14-2012, 06:35 AM   #4955
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 9,860
Remmie
Nice
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 03-14-2012, 06:47 AM   #4956
ktm950se
ktm950se's Avatar
Oddometer: 1,385
Remmie
Can you share more pics of your fairing, like from the side and cockpit views?
ktm950se
ktm950se is offline   Reply With Quote
Old 03-14-2012, 07:23 AM   #4957
Bannisdale
....snowing now!
Bannisdale's Avatar
Oddometer: 209
Template
Originally Posted by rinho View Post
Underseat extra box
Would you be willing to make an electronic or paper template of your storage box so others could copy your hard work?!
I think this is a great solution to utilise all that wasted space.
Cheers
Tim
If you can keep your head when all about you are losing theirs, it's just possible you haven't quite fully grasped the situation...
Bannisdale is offline   Reply With Quote
Old 03-14-2012, 07:48 AM   #4958
henryroten
Oddometer: 250
Which one?
Originally Posted by Narsisco Lopez View Post
Added a remote MODE switch... got the sweet waterproof switch and boot from Paul at Highway Dirt Bikes here in Erie, Colorado! Thanks Paul!
I went to HWD but can't find a 'mode' switch. Which one did you use?
henryroten is online now   Reply With Quote
Old 03-14-2012, 07:54 AM   #4959
Remmie
Remmie's Avatar
Oddometer: 95
Here you go.
This is the latest status.
Almost ready, still some small thing to do.
And with working tachometer.
Remmie
Old 03-14-2012, 08:16 AM   #4960
Supahflid
Wheelieless
Oddometer: 3,704
Here you go.
Remmie
Check out all those buttons on the left side! What do all those do?
Supahflid is online now   Reply With Quote
Old 03-14-2012, 08:52 AM   #4961
rinho
Rinho Féroce
rinho's Avatar
Oddometer: 1,098
Cheers
Tim
Already done!
I'm not the designer of this box shape (credit JMS74), I only did some change to adapt it to my 2006 950, trying to be sure the tire won't hit the box even with a 17x45 gear (shorter wheelbase)
0.06 (1.5mm) is thick enough and is not so hard to bend and provide the possibility of manual adjustment "on the bike" before cutting/bending the side (advice: cut the side once your done and follow the shape, not the template)
Old 03-14-2012, 11:17 AM   #4962
ktm950se
ktm950se's Avatar
Oddometer: 1,385
Thanks for the pics Remmie!
ktm950se
Old 03-14-2012, 11:45 AM   #4963
offworlder
Oddometer: 256
Does this switch cycle through the display modes, ie: trip 1, trip 2, temp, etc... ?
I bought the KTM tripmaster switch thinking it would do this, but doesnt.
Would be great to have on of these switches to (more conveniently) disable ABS....
HDB switch linky:
http://www.highwaydirtbikes.com/HDB_...=perchswitches
Thanks.
offworlder is offline   Reply With Quote
Old 03-14-2012, 12:53 PM   #4964
Narsisco Lopez
Addlepated
Narsisco Lopez's Avatar
Oddometer: 2,207
HDB switch linky:
Thanks.
Yep... hooked it to the empty Molex connector (behind the headlight, hanging near the Molex for the headlight connection) that's for the OEM Tripmaster. Simply hook brown (ground) and brown-yellow (mode) to any momentary switch and it will cycle through odo, trip 1, trip 1, temp.
Since I'm not gonna be following Roadbooks any time soon, I didn't see the need to be able to advance/retard trip 2.
As far as a switch to disable ABS, rgmax posted his solution here...
http://www.advrider.com/forums/showp...42&postcount=3
Narsisco Lopez is offline   Reply With Quote
Old 03-14-2012, 01:27 PM   #4965
jvg
jvg's Avatar
Oddometer: 37
Rebuilt my fuelpump with a Dr_Bean kit.
KTM 950 Adventure S
| NorthCape 2010 | Geiranger 2011 | South Norway 2011 | Blĺhö/Trontoppen 2012 |
jvg is offline   Reply With Quote
Times are GMT -7.   It's 12:13 PM.
