Old 03-23-2012, 06:54 PM   #5101
hontri
Global Bummer!
hontri's Avatar
Oddometer: 305
Originally Posted by Narsisco Lopez View Post
The Brown Truck delivered my fork guards (So, Geek can now find something else to pick on me about )
Had to do a bit of Dremel mods to the ABS sensor-side of the guards to get them to fit. I also drilled 4 holes to zip-tie the sensor line to the guard.
I also opted to 86 the Acerbis universal SM fender for the KTM 690 fender. Just looked like it would offer more coverage and like it was meant to be on this bike. I did have to chop off about 4" of the rear so it wouldn't rub on the radiator guard.
Looks great! I gotta do this. I see you have a 990,so what guards did you use? Part #? Thanks
hontri is offline   Reply With Quote
Old 03-23-2012, 07:26 PM   #5102
Narsisco Lopez
Addlepated
Narsisco Lopez's Avatar
Oddometer: 2,207
The guards: KTM Fork Protector Set (Black) 85 SX (KTM part#:4700109400030)
The fender: KTM Front Fender (Black) 690 Enduro (KTM part#:7650801000030)
Hope that helps
Narsisco Lopez is offline   Reply With Quote
Old 03-23-2012, 10:01 PM   #5103
StevefrmGV
MotoBro's RetroCycle's
StevefrmGV's Avatar
Oddometer: 413
What did I do to the Beast today
I installed Cj,s footpeg extensions and a set of bar end mirriors I got off of ebay. Next project is the KTM clutch kit also procured from CJ.
Steve
May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.
Edward Abbey
StevefrmGV is offline   Reply With Quote
Old 03-23-2012, 10:20 PM   #5104
SierraJeep
It's toast
SierraJeep's Avatar
Oddometer: 630
Steve
I'll be interested in seeing how those footpeg extensions look up close. Time for a ride?
Tod
2010 KTM 990 Adventure
2010 KTM 450 EXC
SierraJeep is offline   Reply With Quote
Old 03-23-2012, 11:04 PM   #5105
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,193
Looks really clean!
If I may, the routing of your abs sensor line is not in a good spot. It should be routed on the inside of the fork leg. Even though your install is clean, if you fall (like I do!!), it will damage your sensor line. It's too exposed to side impacts/contact. Fwiw.
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 03-24-2012, 06:23 AM   #5106
Mr Pete
Dude
Location: Split between Philip Island and Prahran, Victoria
Oddometer: 51
Yesterday I installed the Hella FF50's.. Today I redid some of the wiring because I wasn't happy with the quality of the parts that come in the kit. Yesterday I had the battery disconnected while messing with wires..
Today I forgot and accidently did some nice spot welding on my frame while simultaneously shitting my pants!
'99 Yamaha FZX250' - The Learner bike (sold)
'02 Honda VFR800' - The REAL bike (sold)
'08 Triumph Street Triple' - The FUN bike (sold)
'08 KTM 990 ADV' - F* that, let's get a REAL FUN bike
Mr Pete is offline   Reply With Quote
Old 03-24-2012, 05:45 PM   #5107
BykBoy
Meshuganeh
BykBoy's Avatar
Oddometer: 558
Since I converted to the 2 into 1 Remus ROXX, I decided to turn the LHS exhaust can into a nifty little tool box.
Here it is open:
Here it is closing:
Here it is closed:
The cap holds in place with a push pin.
I used a metal dryer duct to form a slave that I glued inside the cap. The sleeve fits snug in the can and the push pin prevent's it from sliding back out.
The can is connected to the bike in two points: the strap around the can (visible in the first photo) and the middle pipe mount just behind the can (where the pipe connects to the can with 3 bolts).
Many thanks for tunp for sharing his experiences
Save $5 when you open a SmugMug account. Use the following coupon: 4l1hicJzWvYNE
BykBoy is online now   Reply With Quote
Old 03-24-2012, 06:47 PM   #5108
Lycan1
Grizzly herder
Lycan1's Avatar
Oddometer: 989
Home made Decal
I refer to my 990 as the "Orange Dragon", so today I hand cut some decals and branded it.
I've learned so much from my mistakes. I'm thinking of making a few more.
09 KTM 990 Adv
Lycan1 is offline   Reply With Quote
Old 03-24-2012, 06:48 PM   #5109
Lycan1
Grizzly herder
Lycan1's Avatar
Oddometer: 989
Here it is open:
Here it is closing:
Here it is closed:
Very slick, I like it!
09 KTM 990 Adv
Old 03-24-2012, 06:54 PM   #5110
Beema Killa
Beema Killa
Beema Killa's Avatar
Oddometer: 816
And high fender kit in too.
Parts keep a rollin' in! 690 fender installed and fork guards. Had to Dremel the left side to fit due to speedo.
Photobucket
Beema Killa is offline   Reply With Quote
Old 03-24-2012, 06:56 PM   #5111
Lycan1
Grizzly herder
Lycan1's Avatar
Oddometer: 989
Photobucket
Lookin' Good. Was that you picking up parts at Blackfoot this Morning? Chilly day for a ride.
09 KTM 990 Adv
Old 03-24-2012, 06:59 PM   #5112
Beema Killa
Beema Killa
Oddometer: 816
From this:
Before pic
To this in 2.5 weeks. Still waiting on headlight guard, CJ, folding mirrors, Wings exhaust and my FRIGGIN graphics!!
Photobucket
Gotta sort out heated grips too. Suggestions fellas?
Old 03-24-2012, 07:02 PM   #5113
Beema Killa
Beema Killa
Oddometer: 816
Originally Posted by bikyto View Post
looks really clean!
If i may, the routing of your abs sensor line is not in a good spot. It should be routed on the inside of the fork leg. Even though your install is clean, if you fall (like i do!!), it will damage your sensor line. It's too exposed to side impacts/contact. Fwiw.
+1
Old 03-24-2012, 07:06 PM   #5114
Beema Killa
Beema Killa
Oddometer: 816
Yup that was me. I did 95 kms yesterday too starting at 7 AM from Fish Creek Park End of Bow Bottom to Crossiron Mills.Yesterday was waaaaay colder.Had a safety coarse. Had to stop on airport turnoff to put my hands behind the exhaust to thaw my hands/blocks of ice..
Old 03-24-2012, 07:11 PM   #5115
Lycan1
Grizzly herder
Lycan1's Avatar
Oddometer: 989
Heated grips make all the difference. Mine had them when I bought it, first bike that I have had with them, now I can't imagine not. I will be out tomorrow after lunch, probably won't go too far, but next week every day!
09 KTM 990 Adv
Times are GMT -7.   It's 03:28 PM.
