Old 05-18-2012, 05:43 AM   #5671
tomdubz
getting there
tomdubz's Avatar
Oddometer: 509
Originally Posted by Peanuts View Post
Or take the rear wheel out and press the rear end down...
This.
This is my signature: TD
tomdubz is online now   Reply With Quote
Old 05-18-2012, 06:17 AM   #5672
Tangai
Oddometer: 593
Originally Posted by Yascher View Post
same procefure for all liquid cooled twins, to make sure you purge the air trapped in the rear cilynder cooling jacket, as the coolant outlet is below the head gasket. Therefore there is a pocket created and the only way to get theair out is to make sure this pocket is shifted towards the coolant outlet pipe! ant to do this you have to lift the front high enough to make sure air eskapes from pocket..
Well it is arguable if you do it without lifting and then do a hill climb or willie to let the air eskape and then refill the rads, but I play safe to make sure I dont overheat locally at head gasket before air will escape on it's own
Now, that makes perfectly good sense.
Tangai is offline   Reply With Quote
Old 05-18-2012, 09:12 AM   #5673
The Bigfella
Big Adventurer
The Bigfella's Avatar
Oddometer: 2,471
Took a photo of it while I was laying down underneath it
Wet clay and a bald tyre will do that.
Rode part of the Xtrim Sumatra 2012 II eXpedition in Indonesia (as a non-entrant.... bike was too big to enter).
Fabulous day... lots of tight stuff, a bit of mud, lots of rocks and gravel.
A man should only do the work that is required of him. To do more is a form of greed.
Ride through Oz and Asia
The Bigfella is offline   Reply With Quote
Old 05-18-2012, 09:46 AM   #5674
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,308
Originally Posted by CharlieFox View Post
Tangai asks "What makes you guys think you have to lift the front of the bike up so high to get the air out of the radiators? Just asking where that idea came"
The owners manual (at least on my 2008) instructs to lift the tire 50cm to bleed the system.
I had not heard of this procedure, until after I had changed my coolant a couple of times. I have now checked my manual (early '04,) and couldn't find any reference to it.
In the past, I have just filled the radiator until coolant ran out the left vent, squeezed the hoses a few times, and topped up/vented if necessary.
The system seems to operate properly, but just in case, maybe I will try elevating next time to see whether I find more air.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 05-18-2012, 03:08 PM   #5675
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,058
Originally Posted by 75monza View Post
Let me know how you do this if you go for it. I am afraid that if I just bend the bars, they won't line up with the mounts anymore.
It worked out great. I just used a long prybar between the lower bolt and the tab on the battery box cover (where the tank bolts). I just pushed it out a bit and it now has about 1/4 inch clearance from where the tube was touching the tank.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is online now   Reply With Quote
Old 05-18-2012, 03:55 PM   #5676
the foolish fellow
UP FOR IT
the foolish fellow's Avatar
Oddometer: 140
Fitted my newly fashioned cajasachel "neduro" racks.
These racks are designed not to interfere with either the neduro adventure tank or the standard direction indicators.
What's the verdict ?
[IMG]
990 adv
850 Le mans
Gl 1000
X5 3.0d
FE 450 BERG
the foolish fellow screwed with this post 05-18-2012 at 04:02 PM
the foolish fellow is offline   Reply With Quote
Old 05-18-2012, 04:03 PM   #5677
Ladukebob
lost in hood river
Ladukebob's Avatar
Oddometer: 1,829
New 45 tooth and the G2 throttle tamer. Rode it around the orchard for about 5 minutes and I think I'm going to like the change in gearing. On the throttle tamer I chose the 400 cam and the jury's still out on that until I get a little more saddle time in. I did notice a wee bit more slack in the throttle cable and I'd like to take it to the dealer and have them remedy that. Too bad that's not something that came be done without having to re-tune it.
While I had the back wheel off I applied anti seize to the adjusters, thanks OC
2012 wr250r
You don't know what you don't know
findLadukebob
Ladukebob is offline   Reply With Quote
Old 05-19-2012, 01:37 AM   #5678
bigkuri
bigkuri's Avatar
Oddometer: 745
What am I missing?
To take out the slack, just use the cable adjusters - this has nothing to do with engine tune?
Current Bikes: 2006 Honda XR650R & 2007 KTM 950 SMR
bigkuri is offline   Reply With Quote
Old 05-19-2012, 07:26 AM   #5679
Ladukebob
lost in hood river
Ladukebob's Avatar
Oddometer: 1,829
Originally Posted by bigkuri View Post
What am I missing?
Funny how there seems so much confusion on this. I've been told both. A ktm mechanic told me that it will mess up the tune. On this site a few have said it's no big deal. Very confusing, it is temping but the bike is running so well right now that I would hate to mess it up.
2012 wr250r
findLadukebob
Old 05-19-2012, 09:04 AM   #5680
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,178
What am I missing?
It's a hit or miss. I have seen bikes where you could do it manually while others required a reset. Depending on how much slack and where the stepper motor is at
It might need to be fully retracted to get the cable slack adjusted.
There is a function in Tuneecu to do that.
Just be cautious. Because once the stepper is out of whack, you can't go back until a reset.
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 05-19-2012, 03:42 PM   #5681
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,464
It was clogged
Sent from iPhone using Tapatalk
Old 05-19-2012, 03:43 PM   #5682
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,464
New centerstand... Compare length
Old 05-19-2012, 03:44 PM   #5683
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,464
Finally solved my steering head mystery
Old 05-19-2012, 03:45 PM   #5684
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,464
Sorry.. not sure why iphone is suddenly posting tapatalk photos in a huge format
... getting the bike ready for a 5 day offroad ride
Old 05-19-2012, 03:49 PM   #5685
Narsisco Lopez
Addlepated
Narsisco Lopez's Avatar
Oddometer: 2,207
Doe this mean Dinosaur is a GO?
FYYFF!
http://www.youtube.com/watch?v=NtpUv4VBDhA
Bikes: 2013 BMW K1600GT
A Few Past Bikes
: 2003 Suzuki DRZ400E | 2012 BMW K13S | 2009 KTM 990 Adventure
Narsisco Lopez is offline   Reply With Quote
Times are GMT -7.   It's 02:29 PM.
