Old 02-03-2013, 10:01 PM   #7216
StevefrmGV
MotoBro's RetroCycle's
StevefrmGV's Avatar
Oddometer: 407
The Trasformation Begins
Doing a major tune up and cosmetic upgrade. Can you say Crispi Design?
[IMG][/IMG]]
Stay tuned for more to come
May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.
Edward Abbey
StevefrmGV is offline   Reply With Quote
Old 02-03-2013, 10:08 PM   #7217
spencergt66
Oddometer: 794
Finally fixed that small yet annoying oil leak... And installed new front txc 80
spencergt66 is offline   Reply With Quote
Old 02-04-2013, 08:42 AM   #7218
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,643
Installed the forks after getting tuned Pro Action valves and a rebuild from the Pro Action suspension franchise at my local KTM dealer in Austin. The difference in the ride was noticeable immediately. The front is plush and planted now, while smoothing out the little bumps. It dives much less and in a more controlled fashion at stops and when entering turns at speed. Simply love the way it feels now, as if I am even more a part of the bike.
Also, while I had it apart I reverted back to the OEM front fender from the tall one that was installed when I bought the bike two years ago. This is in preparation for the upcoming Texas Summer and I am hoping that the airflow to the radiator will be improved.
Lastly, a little brake line work. I cut the stiffening plastic from the two brake lines that went to either side of the tall fender (MX style), and rerouted them so they now flex between the lower triple clamp and the OEM fender. Put a couple of rubber coated clamps on the lower tree to route the lines through. At a glance, I should be able to use this arrangement with either fender installed
I left the speedo wire as is, running straight up the fork leg through the guide, rather than try to strip the stiffening plastic off and damage the wire in the process.
Anyway, I am happy with the looks and the functional changes. The cockpit is a lot neater without having two brake lines moving up and down when I ride.
This is The Internet. Confirm for yourself anything you may see while visiting this strange and uncertain land.
MotoTex is offline   Reply With Quote
Old 02-04-2013, 09:20 AM   #7219
DirtJack
DirtJack's Avatar
Oddometer: 1,531
Spring change? If so, what tension? Hadn't thought of using that shop for suspension work, it would save shipping costs for me.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 02-04-2013, 12:32 PM   #7220
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,643
The previous owner had already upgraded the spring and I was able to set correct sag with it, so didn't have to change that.
I did get a complete rebuild with seals, bushings, fluid, etc. and they had to replace one component that had frozen/corroded into place. Got out for about $420.00. Would have otherwise been about $370.00 for the rebuild with custom valves and seals/bushings/oil.
The Pro Action folks have apparently been in the suspension game for 35 years and have a bunch of shops scattered all over. I couldn't find much information about them in searches, but a call to their headquarters in PA left me feeling that they were well versed and that they supported their network with specs for lots of bike/rider/style combinations. I was told they had done ten or so of 950/990s in the past year or two nationwide, and now had the data for dialing it in.
Old 02-04-2013, 01:11 PM   #7221
amanlikemike
Recoverin speedfreak
amanlikemike's Avatar
Oddometer: 1,018
[IMG][/IMG]]
Yup! Do it - you won't regret it.
'Ave it.
BritKit LLC
US Distributor of Kriega Motorcycle Luggage
www.kriega.us / Facebook / vendors thread
amanlikemike is offline   Reply With Quote
Old 02-04-2013, 01:38 PM   #7222
DirtJack
DirtJack's Avatar
Oddometer: 1,531
Good info. Thanks, Moto. I'll talk to Tom about this the next time I'm up there.
2008 KTM 690 Enduro
Old 02-04-2013, 04:07 PM   #7223
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,806
What did I do to it?
Thrashed it around on a moto track. Kept the bags and GPSs on for the full effect.
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 02-04-2013, 06:18 PM   #7224
amanlikemike
Oddometer: 1,018
'Ave it.
BritKit LLC
Old 02-04-2013, 07:00 PM   #7225
FakeName
FakeName's Avatar
Oddometer: 1,806
Originally Posted by amanlikemike View Post
One of the local motocross guys said,"500lbs? That's like riding TWO bikes out there".
2014 500EXC Black
Old 02-04-2013, 10:29 PM   #7226
SierraJeep
It's toast
SierraJeep's Avatar
Oddometer: 630
You finally gonna fix that custom stick in that exhaust mount before it gets crispy?
Tod
2010 KTM 990 Adventure
2010 KTM 450 EXC
SierraJeep is offline   Reply With Quote
Old 02-05-2013, 10:32 AM   #7227
Qwik
Adrenaline Addict
Oddometer: 6,712
Changed the oil
Love pulling the filter and seeing these nice straight pleats
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 02-05-2013, 10:43 AM   #7228
Hobbes950
Darth Kitten
Hobbes950's Avatar
Oddometer: 3,860
Originally Posted by Me, Myself, and I View Post
I'm gonna have to work on that. Mine encourages me to buy whatever I want for the bike but has never installed anything for me. If I could get her to do that I'd have more time to drink. Good on you.
A good way to work on that- buy her one of her own!
When in doubt, take it as a compliment.
My Ride Reports
Hobbes950 is offline   Reply With Quote
Old 02-05-2013, 10:48 AM   #7229
Hobbes950
Darth Kitten
Hobbes950's Avatar
Oddometer: 3,860
Been wanting to hit up Crispy myself. Would love to design something custom. Cant justify the cost just yet. Maybe I can give some hints to the hubby for next xmas.
My Ride Reports
Old 02-05-2013, 06:10 PM   #7230
Qwik
Adrenaline Addict
Oddometer: 6,712
I so wish they would work on the Safari tanks.
Times are GMT -7.   It's 02:27 AM.
