Old 04-18-2010, 05:55 AM   #61
Sandman 950
Sandman 950's Avatar
Oddometer: 237
You can sing this like an old blues song if you fancy!
I woke up this morning...
the sun was shining...
put bike in the garden...
Took bodywork, tank and seat off...
removed airbox and carbs...
cleaned jets and set mixture to 1 1/2 turns...
removed mudguard, loosened radiator...
took plugs out, put new one's in...
put it all back together and....
S W E E E E E E E T!
(it was sweet anyway mind)
KLX 250Fi
270 REV3
PUCH MAGNUM X
CBR600FA-B
...and too many bicycles!
Sandman 950 is offline   Reply With Quote
Old 04-18-2010, 08:08 AM   #62
1911fan
Master of the Obvious
1911fan's Avatar
Oddometer: 3,277
Canisterectomy, SASectomy, FMF Q4s: Runs great, sounds better. Throttle response seems much improved, or is that just me cranking it up because it sounds so nice?
Installed new Acerbis handguards, a mild PITA. Barely clears the brake master cylinder so it's installed a little lower than I wanted. Had to move the clutch mount inwards so lever would clear, so it's either hack the lever shorter or find a shorter lever. Anybody got a source for stubby levers for the 990?
1911fan
Read The Patriot Post -- It's Right. It's Free.
http://patriotpost.us/subscribe/
Sometimes the light to see your way forward is provided by the bridge burning behind you.
1911fan is offline   Reply With Quote
Old 04-18-2010, 11:16 AM   #63
Jonnas
Oddometer: 98
Washed it.
Added some clutch oil.
Adjusted all spring preloads, rebounce and compression to Sport mode.
Fired it up, wheelied a bit
Made a few feet of black rubber marking by the front wheel brake during fast stop training. Always good to know how much is just a bit too much
2005 KTM 950 Adv
2004 R1200GS (sold)
1981 XL500S (sold)
Jonnas is offline   Reply With Quote
Old 04-18-2010, 02:46 PM   #64
c munch
Destination unknown
c munch's Avatar
Oddometer: 476
Pissed
Cursed at it and rode the duc. Still waiting for a voltage regulater, it's been 3 weeks now.
2004 KTM 950 ADV
2001 Duc ST4
1973 trail90
2006 CBR600RR Track only
2010 ktm 990 ADV
c munch is offline   Reply With Quote
Old 04-18-2010, 03:01 PM   #65
Michhub
Major Medical
Michhub's Avatar
Oddometer: 3,977
Mounted MEFO's....initial 100 mile ride was fantastic compared to the Skorp's. After three front Skorp's that wobbled I give up....I hope to never go back.
Mike
Reinheitsgebot
'07 990ADV '08 530EXCR '04 XR650L
Bonsai Elephant - "
Life without a 990 is no life at all!"
Michhub is offline   Reply With Quote
Old 04-18-2010, 08:01 PM   #66
50X50
50X50's Avatar
Oddometer: 186
08 990 Adventure
Bought the 990 for a trip to Alaska. I will love and protect this moto...it is the everything bike.
My farkle list includes:
Garmin Zumo 550
Akro Exhaust
Touratech Skidplate
Carbon look frame guard
Scotts SHARK FIN
Aluminum radiator protector
Crash Bars
Carbon Ignition Protector
Carbon Clutch Cover
G2 Throttle Tube & Cam
Hard Epuip. Heated Grips
Folding Mirrors
Hollow Bleeder Screws
Adventure Front Axle Pull
TKC 80 Tires
KTM Black Plastic Side Bags
KTM Tank Bag
PIAA Xtreme White Bulb
PIAA Driving Lights
Rotopak 1 gal + Mount
but...
MOST RECENTLY!!!!!
Photobucket
EMIG Steering Stabilizer/Damper/Triple Clamp Kit
Photobucket
Stabilizer with Rotopak and Zumo 550.
I would take any input as to what should be next!!?
Jeff
50 States Ridden
"rocks, sand, mud, clay, ruts, cambers, water crossings, & everything else"
My Pics, Vids, SPOT & Blog
www.santacruzadventureriders.com
50X50 is offline   Reply With Quote
Old 04-18-2010, 08:51 PM   #67
gweaver
Wandering between rooms
gweaver's Avatar
Oddometer: 1,634
Started looking for an oil leak that developed recently. Pulled the upper fairings and tanks, degreased the front cylinder. I'll put the thing back together tomorrow, probably ride it Tuesday, then check and see if I can identify where the leak is. Could be the valve cover gasket (didn't change it at last valve adjust), but I suppose it could be one of the spark plug shaft O-rings or one of the seals on the valve cover bolts.
Looks like there's the beginnings of a small leak on the rear cylinder too, definitely from the gasket.
Maybe I'll wash it after I find and fix the oil leak.
G
I just twist and my eyes glaze over, "uh....errr huh huh, weeeeoooooh---doo dat agin, doo dat agin..." -morriswf
I like my women like I like my instant oatmeal- quick, easy, and covered in facts about dinosaurs.
gweaver is offline   Reply With Quote
Old 04-18-2010, 10:11 PM   #68
unkle_george
unkle_george's Avatar
Oddometer: 106
Hmm, a found why the bike is running a temperature. The water pump seal went from OK to complete failure in about 100 miles. I think I may have cut the lip of the seal when I installed it only 5k miles ago.
unkle_george is offline   Reply With Quote
Old 04-19-2010, 11:33 AM   #69
DeeGee OP
I'm a Yorkshireman thanoz
DeeGee's Avatar
Oddometer: 1,884
Remember this?
So I laid the bike down
And took the clip off it and replaced it with this jubilee clip.
Hopefully all is sweet now
DeeGee is offline   Reply With Quote
Old 04-19-2010, 12:26 PM   #70
Sandman 950
Oddometer: 237
Well done man, simples aye?
(hijack-did you ever hear anything about your KTM that went missing)
KLX 250Fi
270 REV3
PUCH MAGNUM X
CBR600FA-B
Old 04-19-2010, 06:01 PM   #71
Qwik
Adrenaline Addict
Oddometer: 6,947
Went and found some more mud. We both laid down in it but no damage. Then I hosed her off
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 04-19-2010, 07:03 PM   #72
jwalters
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,346
Took the left tank and fuel pump off my 08 990 for the third time this month. I've been trying to cure the slow leak/weeping of fuel from the pump/tank interface. Tried different o-rings, stock and larger/smaller sizes but still no luck. This all started after replacing my burned out stock pump last summer. The new pump doesn't seem to mate to the tank surface as well.
I'm taking it back into the shop and see if KTM NA can help me, because I am out of ideas... Maybe I'll try a custom gasket between the pump and tank if they don't have any solution...
Minnesota North Shore Shindig 10-13 September 2015 -- Finland, MN
Proliferator of Farkles of Mass Percussion
jwalters is online now   Reply With Quote
Old 04-19-2010, 07:16 PM   #73
MT950
"OLD" Adventurer
Oddometer: 252
Ride, maint., ride.
Took a ride over Lost Trail Pass to Salmon ,ID. and up the North Fork of the Salmon river. great weather !! 260 miles. Got back , hosed her off, checked fluids,air pres.,checked & lubed chain. Good to go !!!
MT950 is offline   Reply With Quote
Old 04-19-2010, 11:53 PM   #74
DeeGee OP
DeeGee's Avatar
Oddometer: 1,884
G
I bet it's the oil pressure switch, it sits in between the cylinder heads on the left side.
Yes, some bike breaker not far from where I live was selling parts of it on eBay. Cops done fook all and I've got some parts back via my insurance company, but the prick has butchered a lot of the stuff, knowing he was going to loose them. :mad
Old 04-20-2010, 12:57 PM   #75
imgonnasnap
Motard wrecker
imgonnasnap's Avatar
Oddometer: 808
My $140 HID rally light
So I decided I dont like the stock headlight anymore, and decided to had a rally style race light and fairing. I just finished up the bracket for the light and need to start working on the fairing, but this is what I have so far. What do you guys think? So far I only have about $140 into the entire setup, including the light and the metal. (not counting welder usage & electricity, of course)
Originally Posted by HappyGoLucky
lots of guys make excuses - it must be the tyres, it must be the weight, it must be the power, it must be the water pump.
ride the $*#(@) thing, and you'll quickly learn that the stain marks in your brooks were firstly from fear and then from ecstacy.
Scuderia: LB to SF
Bradshaw Bombrun 2007, 2008, 2009
Stupidly long road trip of 2009
imgonnasnap is offline   Reply With Quote
Times are GMT -7.   It's 04:36 PM.
