03-18-2013, 04:58 PM
#7546 |
Mmmm....Orange Kool-aid
Oddometer: 1,557
Go ride the bike for about an hour then just put the bike on the kickstand and pull the clutch cover. If you have a vanilla milkshake on the inside of the cover then you need to call CJ. You have to ride it for a while to get it hot enough to burn off all the condensation, think CJ said something to this effect and I've seen the same thing with my clear clutch cover.
Those who dance are considered crazy by those who do not hear the music. I am not the same having seen the moon shine on the other side of the world. - Radmacher 5 Cylinders vs. Moab..........My East Tennessee |
03-18-2013, 09:53 PM
#7547 | |
Oddometer: 423
Verstuurd van mijn MB526 met Tapatalk
Now: '03 KTM 250sx -- '05 KTM Adventure 950 Before: '00 KTM 250sx -- '03 KTM 450sx '03 Yamaha R6 -- '08 KTM SuperDuke R |
03-19-2013, 07:36 AM
#7548 | |
Meshuganeh
Oddometer: 404
You can see in the video I posted that I'm standing still in 1st gear and the bike is still running but the clutch leaver is not engaged. As soon as I turn the throttle, the gear engages and the bike takes off. Gear box is not full auto because the rider still has to change the gears with the left foot. But this is done without pulling the clutch leaver.
Save $5 when you open a SmugMug account. Use the following coupon: 4l1hicJzWvYNE |
03-19-2013, 12:43 PM
#7549 | |
Mookish Mook
Oddometer: 4,289
Theres an old thread I posted about 2-3 years ago - I had a slow coolant leak (undetected because the rad cap had also failed to do its job so the reservoir tank was still full) - and there was no evidence of emulsion in the oil. However, the oil filter was eeever-so-slightly wavey - like the one pictured - and I wondered the same thing at the time. In my limited observation, healthy oil filters tend to be straight-as-a-die. Always check your actual radiator fluid level - dont just rely on the reservoir level. |
03-19-2013, 12:48 PM
#7550 | |
Meshuganeh
Oddometer: 404
Any metal parts that sink/fall into the hose (because it is in the bottom of the tank) will be trapped at the bottom of the hose. This is the same as being trapped on the magnet. There is no way for heavy metal fragments to float back up the hose. The fragments will be extracted from the tank when the hose is opened and drained. Of course, you won't be able to see the shards when you drain the hose, unless you rummage through the drained oil...
03-20-2013, 11:23 AM
#7551 |
Oddometer: 70
Changed the brakepads, by the looks of it, it was about time
03-20-2013, 02:13 PM
#7552 |
Oddometer: 1,045
On the 1190 Adv it would go into limp mode if less than 2mm of pad, then if the pads are not changed and the ECU reset (using the KTM authorised PC hardwired to the KTM international dealernet database) within 200 miles it will apply the immobiliser and service crew auto callout via GSM/GPRS/GPS.
Honest ;) |
03-20-2013, 04:36 PM
#7553 | |
Oddometer: 1,201
"I'd like to meet the joker who had the nerve to call this a road!" -- Walter Sigmann "Do not follow where the path may lead. Go, instead, where there is no path and leave a trail." -- Ralph Waldo Emerson Facebook Page: https://www.facebook.com/brad.horn.9 |
03-20-2013, 05:08 PM
#7554 |
Oddometer: 1,201
Brought it back to life today:
"I'd like to meet the joker who had the nerve to call this a road!" -- Walter Sigmann "Do not follow where the path may lead. Go, instead, where there is no path and leave a trail." -- Ralph Waldo Emerson Facebook Page: https://www.facebook.com/brad.horn.9 Orangecicle screwed with this post 03-20-2013 at 05:23 PM |
03-20-2013, 05:17 PM
#7555 |
Long way to go
Oddometer: 1,112
Your first day of spring was about like ours... cold
Everybody's on the run |
03-20-2013, 05:28 PM
#7556 |
Oddometer: 1,201
No sheisse! It was 14.5ºF this morning when I left for work. And no, I did not ride to work.
03-20-2013, 08:48 PM
#7557 | |
Oddometer: 1,557
03-21-2013, 06:04 AM
#7558 | |
Oddometer: 70
03-21-2013, 08:25 AM
#7559 |
Oddometer: 1,201
Rode it!!!
03-21-2013, 09:42 AM
#7560 | |
One finger braker!
Oddometer: 2,104
"People in this country sleep peaceably in their beds at night because rough men stand ready to do violence on their behalf." George Orwell If Momma ain't happy ain't NOBODY happy! 2007 950R Super Enduro 2006 Buell XB12X |
