Old 04-01-2013, 11:59 PM   #7606
Dan950ser
NW Shredder
Oddometer: 476
Installed galfer front disc with new green pads, rejetted carbs and installed CPR filter, Rerouted fuel lines for PowerCell tank and installed tank, installed facet pump with the ADV Machines adapter plate, hard wired the GPS, and cleaned up some wiring behind the headlight. Took for a shakedown before the upcoming Baja trip. Next is a Teraflex rear and D606 front and then I'm off.
[IMG][/IMG]
[IMG][/IMG]
2015 KTM 690 Enduro R, 2007 KTM 990 SuperDuperEnduroR For Sale http://www.advrider.com/forums/showthread.php?t=1046431, 2014 KTM 250 XC-W
Dan950ser is offline   Reply With Quote
Old 04-02-2013, 08:00 AM   #7607
DirtJack
DirtJack's Avatar
Oddometer: 1,571
Originally Posted by mechanical View Post
Thanks! Indeed, that is a possibility. Check the vendor section shortly.
I just didn't have any tapered bolts laying around. But you are right. Do you think the Rotopax cans should be isolated from the flat aluminum with rubber in some way? Will the aluminum plate eventually wear a hole in the cans?
I bolted the mount directly to the plate and then used a piece of inner tube between the plate and rotopax.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 04-02-2013, 08:37 AM   #7608
akarob
Green Cantern
akarob's Avatar
Oddometer: 7,768
Originally Posted by Dan950ser View Post
Next is a Teraflex rear...
where to you find a Terraflex?
akarob is offline   Reply With Quote
Old 04-02-2013, 09:27 AM   #7609
Dan950ser
NW Shredder
Oddometer: 476
http://mandhtires.com/
Old 04-02-2013, 10:08 AM   #7610
jm65
jm65's Avatar
Oddometer: 177
[IMG][/IMG]
[IMG][/IMG]
wahouuu!!!!!!!!!!!!! , beautiful bike , this tank is very success-full
KTM 690 R 2014
jm65 is offline   Reply With Quote
Old 04-02-2013, 11:02 AM   #7611
Dan950ser
NW Shredder
Oddometer: 476
Thanks. The tank is a night and day difference from stock. Better handling due to lower more centered weight, better seat design, two minute tank removal, slim and comfortable to ride. Oh and of course the range is nice.
Old 04-02-2013, 05:48 PM   #7612
go2cnavy
go2cnavy's Avatar
Oddometer: 526
Great price! What do you run on the front?
go2cnavy is offline   Reply With Quote
Old 04-02-2013, 06:30 PM   #7613
vspeed
vspeed's Avatar
Oddometer: 430
Finally got around to installing the CJ kickstand re-locator I bought last summer. I don't really do any serious off-road riding with this bike, but the pictures of cracked engine cases I've seen here scared me.
Being a 990, I had to plug in the device from KTMtwins that fools the computer into believing the stand is up. I didn't really want to disable the switch, but I couldn't find an extension cable.
Also put on a Cox Racing radiator guard, mostly in the hope of improving air flow through the radiator.
vspeed is offline   Reply With Quote
Old 04-02-2013, 06:59 PM   #7614
Orangecicle
Quest Adventurer
Orangecicle's Avatar
Oddometer: 2,704
Finished!!!!
Winter upgrades included:
  • Install Balance shaft seal
  • Install CJ Water Pump shaft and grey seal
  • Tighten head bolts
  • Check valve clearance
  • Install new plugs
  • Install new air cleaner
  • Install Samco hoses
  • Service Forks
  • Tighten triple tree
  • Switch around throttle cable to the right
  • Install new axle & CJ pusher
  • Service all electrical connections
  • Install new Weld86 bash plate
  • Install new Tube/Tire - front
  • Install Chain and Sprockets (purchased in 2011)
  • Service Shock
  • Service Swingarm
  • Finish and install Pelican cases
Now, it's time to ride.
Orangecicle is offline   Reply With Quote
Old 04-02-2013, 09:01 PM   #7615
chrish4ku
chrish4ku's Avatar
Oddometer: 836
Added Heat - Heated grips that is...
Soooo warm.......
Easy install - right into the AUX 2 line under the dash.
_______________________
Chris
I don't normally ride on the street,,,but when I do,,I prefer lane splitting.
2011 KTM 990 Adventure / KTM 500 EXC
Chris' Sat Tracker
chrish4ku is offline   Reply With Quote
Old 04-03-2013, 06:47 AM   #7616
DesertSurfer
Tail sprayin
DesertSurfer's Avatar
Oddometer: 1,420
Doing a live report up to see Pyn...
Originally Posted by DesertSurfer View Post
Air Box refresh... clean/ oiled filterskin over Uni and DNA filter.
Added new TKC80 and new HD tube... cleaned chain, checked tensioner.
First time riding this 500 mile dirt and broken pavement route. Couldn't find a riding partner so going it solo. May do a live ride report if anyone's interested?
With the gracious help of some generous inmates my route plan is ready. After catching up on my prep and packing I'll start a live report today... (Wednesday, April 3rd) prior to leaving tomorrow ( Thursday, April 4th). I'll be posting in the Day Trippin section for anyone interested.
'"This whole memory lapse is gett'in to me. Hopefully I think I'll outgrow it."
DesertSurfer is offline   Reply With Quote
Old 04-03-2013, 10:47 AM   #7617
EZ300
EZ300's Avatar
Oddometer: 1,088
Changed the upper mono shock spherical bearings, again! Slop significantly reduced. Now to do the bottom shock bearings...
Old
New installed
EZ
AMRA
2007 KTM 990 Adventure
2010 KTM 530 XC-W Six Days
www.rockstarsmc.com
EZ300 screwed with this post 04-04-2013 at 11:04 AM
EZ300 is offline   Reply With Quote
Old 04-03-2013, 04:31 PM   #7618
Skinner
Mr.KTM
Skinner's Avatar
Oddometer: 5,731
Mine got adopted today! Had to put her on a trailer :(
You might be an ADVRider if:
You recognize your friends by the sound of their mufflers.
http://www.meetup.com/Chicagoland-Du...torcycle-Club/
www.jimstarwaltteam.com
Skinner is offline   Reply With Quote
Old 04-03-2013, 10:26 PM   #7619
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 698
Installed the (OEM type?) pannier frames and a set of H&B Junior panniers that I picked up from two inmates here.
The Juniors wouldn't latch tightly to the frames; that's when I found the frame latches on the cases could be repositioned.
Now they're on there tight as a drum.
HeatXfer screwed with this post 04-04-2013 at 09:34 AM
HeatXfer is offline   Reply With Quote
Old 04-04-2013, 01:13 AM   #7620
Adventure boy
Adventure boy's Avatar
Oddometer: 531
Added some stickers to the sprayed screen
Live a little Love a little Ride a lot
Adventure boy is offline   Reply With Quote
Times are GMT -7.   It's 04:04 AM.
