Old 08-14-2010, 04:31 PM   #751
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 6,908
Installed a new bushing in the lower left tank mounting hole. Had to use a damn bottle jack to re-align the tank. Noticed my standard-beam headlight filament is burned out. Guess I'll have to use the high-beam.
Heading over to Fraser for a family reunion tonight and tomorrow.
'06 KTM 950S Adventure
'12 Ram 2500, Cummins, 6-speed auto, Laramie Longhorn, RamBox.
DakarNick is offline   Reply With Quote
Old 08-14-2010, 05:04 PM   #752
Michhub
Major Medical
Michhub's Avatar
Oddometer: 3,870
Originally Posted by DakarNick
Installed a new bushing in the lower left tank mounting hole. Had to use a damn bottle jack to re-align the tank....
Funny you should mention that....I think everyone knows that the hardest part of an oil change is re-installing the crash bars/lower tank bolt. I've used a jack in the past but it usually just lifted the front front wheel off the ground and I had to fight the alignment of that lower bolt....this time I removed all the upper fairing bolts and loosened the upper tank bolt(by the fuse block)...that with the jack 'lift' made it alot easier...I mean I saved 20+ minutes of cursing, sweating and frustration...that just me, YMMV....
Mike
Reinheitsgebot
'07 990ADV '08 530EXCR '04 XR650L
Bonsai Elephant - "
Life without a 990 is no life at all!"
Michhub is offline   Reply With Quote
Old 08-14-2010, 07:05 PM   #753
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,954
Originally Posted by Geek
I trimmed mine like this also, BUT adding a 1/4x1" fender washer between the
flap & the mount on the exhaust pipe will shim it out away from the swingarm.
I did both
Brown Dog is offline   Reply With Quote
Old 08-14-2010, 08:20 PM   #754
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 936
Did'nt ride it
Changed my oil, drilled out the barb on rear cyl for my vac pump and worked on my spare wheel.
dogsslober is offline   Reply With Quote
Old 08-14-2010, 10:13 PM   #755
Nut Clutch
was Steve Lavigne
Nut Clutch's Avatar
Oddometer: 429
Originally Posted by dad2bike
Originally Posted by Steve Lavigne
I broke the head off the damned oil jet.
There has GOT to be a great story to go with that post.
How the F did you do that???
Not really that great of a story. I remembered how I couldn't budge the oil jet the first time, and used a screwdriver bit and a wrench to remove it. I did the same thing this time, only I also used the screwdriver bit and wrench to tighten it... too much. Dumbest thing I've done for a quite a while.
I tried a few different ways to extract the screw with no success, so here is what the bike looks like right now:
http://advrider.com/forums/attachmen...1&d=1281849164
Nut Clutch screwed with this post 08-14-2010 at 10:21 PM
Nut Clutch is offline   Reply With Quote
Old 08-14-2010, 10:17 PM   #756
Nut Clutch
was Steve Lavigne
Nut Clutch's Avatar
Oddometer: 429
I'm going to bring the lump to my buddy tomorrow. He is far better at dealing with extracting a broken, bunged up screw that is recessed in a hole next to the side of a cylinder without screwing up the engine case than I am.
http://advrider.com/forums/attachmen...1&d=1281849405
Old 08-14-2010, 11:19 PM   #757
Sundance
Sundance's Avatar
Oddometer: 61
Roc Stompa and TT
Orange Long Stompas. Mmmmmm
The wait was worth it.
Easy install.
Looks great and now I can go to the grocery store with it.
Now she's got a wide rear end.
Sundance is offline   Reply With Quote
Old 08-15-2010, 05:10 AM   #758
stou
stou's Avatar
Oddometer: 350
Very nice cases!
2010 KTM Adventure 990R - 2012 Ossa TR280i
'87 Honda TLR 200 - '72 Honda CB350K4 - '72 Honda CD175
http://www.stoudesign.com
Montreal to Moab 2008: http://www.advrider.com/forums/showthread.php?t=343166
stou is offline   Reply With Quote
Old 08-15-2010, 10:11 AM   #759
Flameout
Flameout's Avatar
Location: I'm right where I'm suppose to be all the time!
Oddometer: 274
Cool2
[/QUOTE]
Wow! I know that feelin!!! Great bike!!!
"Artillery lends dignity to what might otherwise be a vulgar brawl."
Frederick The Great (1712 AD - 1786 AD)
FOLLOW ME!
http://share.findmespot.com/shared/f...rytJ4p77xkQ75p
Flameout is offline   Reply With Quote
Old 08-15-2010, 01:32 PM   #760
pancake
Better with bacon!
pancake's Avatar
Oddometer: 59
I replaced one of the bushings and screws that hold the bodywork on the tank..
and then used the SE to lead my girlfriend's 13 yr old around the neighborhood on a kx100 so she could practice shifting! Breaking in a new rider.. oh yea...!
Need a plated dirt bike!
pancake is offline   Reply With Quote
Old 08-16-2010, 12:24 PM   #761
Questor
More Undestructable
Questor's Avatar
Oddometer: 4,173
I replaced the clutch lever that I snapped off last week when I turtled the bike on a steep switchback...
Another $75 joyride...
Q~
Old 08-16-2010, 12:37 PM   #762
kizniche
pyro
kizniche's Avatar
Oddometer: 165
This week I ended up going to a shop (AMR, Boca Raton, FL) for some service that required tools I don't have.
After mounting a new tire 180 degrees from the proper position (red dot nearest to valve stem), I needed a balance, badly. I also took the opportunity to have the carbs syncronized after installing Head2Wind's jets last week. Last, I had a new DID 525VM2 chain installed.
Today, after buying fasteners for two touratech bottle mounts, I stopped in Craig's Custom Canvas in Deerfield Beach, FL, looking to have new hinge covers made to replace the ones disintegrating from my H&B Gobi hard cases. Craig stopped what he was doing as soon as I walked in. After discussing materials, he built me two custom hinge covers. We decided on materials and I watched as he sewed with an attention to detail that only comes with years of experience. I was very satisfied with the work. He even gave them as a gift after discussing my upcoming motorcycle trip South.
Solo Latin America on a KTM 950, 9/2010 - 2/2011
En Moto Al Surhttp://www.advrider.com/forums/showthread.php?t=616031
2012 KTM 690 Enduro
kizniche screwed with this post 08-16-2010 at 11:04 PM
kizniche is offline   Reply With Quote
Old 08-16-2010, 11:49 PM   #763
summitdog
It's an Azawakh
summitdog's Avatar
Oddometer: 193
Something new is happening here.
Ken Nelson at www.advmachines.com has been helping me with a project.
General Disclaimer: Nothing in the above posting is intended as, nor should it be construed as, legal advice.
Every situation has a particular nuance that needs to be considered individually.
If you believe you need legal advice, please seek out an attorney.
Scotty Storey, Attorneys at Law
800-264-4379
info@twowheellaw.com
AFM #733
summitdog is offline   Reply With Quote
Old 08-16-2010, 11:51 PM   #764
summitdog
It's an Azawakh
summitdog's Avatar
Oddometer: 193
Now What?
So here is the result of the milling. Can you guess for what this is?
800-264-4379
AFM #733
Old 08-16-2010, 11:54 PM   #765
summitdog
It's an Azawakh
summitdog's Avatar
Oddometer: 193
If you looked in the background of the previous photo, you could probably guess what was coming next.
800-264-4379
AFM #733
Times are GMT -7.   It's 09:05 AM.
