Old 05-18-2013, 07:11 PM   #7846
Mr_Snips
Husky BRAAAAAAAAP!
Mr_Snips's Avatar
Oddometer: 352
Lets see...i did a short ride to the gas station...came to the conclusion my rear tire will be completely ahnialated after tomorrows ride and found out it is pretty easy to power wheelie standing in second...sigh. i cant believe i havent gotten arrested yet knock on wood.
Originally Posted by Reprobate
Familiar. My stock response: "Most people die in bed. So, where do you sleep?"
Mr_Snips is offline   Reply With Quote
Old 05-18-2013, 09:00 PM   #7847
zxwut?
The bee's knees
Oddometer: 7
Rode it, jumped some curbs, rode down a few sidewalks, shopped for tires and new springs. That's about it, I believe.
zxwut? is offline   Reply With Quote
Old 05-18-2013, 09:35 PM   #7848
Rally_West
Central Scrutinizer
Oddometer: 142
Installed new battery, just went with stock for the ease of it all.
AND installed my new skid plate...
It's a Slavens...very nice, very thick, swings down like stocker for services.
'07 450EXC Sold but not forgotten...you will be replaced soon.
'07 990 Adv...BOOYAH!
Rally_West is offline   Reply With Quote
Old 05-18-2013, 10:03 PM   #7849
spencergt66
Oddometer: 792
Cpr
Put the CPR intake on the 07 990 since i had the throttle bodies off anyway for injector removal. The filter isnt as easy to get on and Off as i thought it would be but maybe I just need to learn the correct way?
Went to do the 15 min idle and saw the headers glowing red!!! never done that before guess shes a bit lean on the stock setting. REmapped with akro ti slip on map seams alot better test ride confirmed the gain in performance.. The ride was short but wow what a difference
I mean really wow this is a must have that stock air box is such a clunky mess and obviously a huge restriction would deffinetly recommend
spencergt66 is offline   Reply With Quote
Old 05-18-2013, 11:18 PM   #7850
Rally_West
Central Scrutinizer
Oddometer: 142
Glad to hear you like it...I got one on the way. Can you send me a link of the map you used and some specs of your bike (to see if I can you your map) because I am sure I will need to remap too.
In what way is the filter hard to get off? You think you can do it with the tanks on?
Old 05-18-2013, 11:47 PM   #7851
spencergt66
Oddometer: 792
I used the map from the tune ecu site. Air injection off and o2 sensors on
You should be able to get the filter on and off with the the tanks on maybe just the glove box off I put a filter skin on to extend the life of my filer between cleanings.
The filter takes a bit of finess to clip on and I thought it would slid ove the lip a bit easyer but it takes some finess and tweaking I guess it's better to have the fitter in ther tight then flopping around. Anything is better then the OE airbox
Make sure u get the Superduke trumpets also they are suppose to be good for 1hp alone
Old 05-19-2013, 03:04 AM   #7852
kaptinkaos
Just some nOOb
kaptinkaos's Avatar
Oddometer: 573
'13 KTM 990 ADV Baja SOLD
'08 KTM 450 EXC-R '06 KTM 640 Adventure
kaptinkaos is offline   Reply With Quote
Old 05-19-2013, 07:20 AM   #7853
zgfiredude
Oddometer: 846
You my friend need a bigger garage......
DRZ440E, KLX440R, DRZ250, KTM 950S Adv, F650GS, & F650GS Dakar
zgfiredude is offline   Reply With Quote
Old 05-19-2013, 08:25 AM   #7854
JiTe
Flying Finn
JiTe's Avatar
Oddometer: 19
JiTe is offline   Reply With Quote
Old 05-19-2013, 10:33 AM   #7855
jeventures
Oddometer: 228
Very nice. She is off to a good home!
Originally Posted by RENCRN8 View Post
I brought my new to me 2006 950 home and began my typical routine with new bikes to give it some much needed love. I like to start on a clean sheet of paper....
Every man dies but not every man lives.
jeventures is offline   Reply With Quote
Old 05-19-2013, 03:02 PM   #7856
JJLalas
Oddometer: 43
I was having issues with my BAAS 12V socket + battery tester...like blowing its 5A fuses nonstop in spite of checking the electric installation over and over again...and last week I got a replacement unit. I installed it today and it works like it should.
I also fitted the OEM side racks to mount my beloved Junior 40L cases. I'm pretty much ready for my 5 days tour of Euskadi (Basque Country)!
JJLalas is offline   Reply With Quote
Old 05-19-2013, 04:48 PM   #7857
1Bonehead
Fearless of Falling
1Bonehead's Avatar
Oddometer: 1,113
hmmm
But it does make it hard to ride like this
http://m.youtube.com/#/watch?v=NpI5B...%3DNpI5BNiF8hU
1Bonehead is offline   Reply With Quote
Old 05-19-2013, 05:49 PM   #7858
Bartron
Bike Punisher
Bartron's Avatar
Oddometer: 693
Originally Posted by hontri View Post
After you installed the inline fuel filter did you remove the filters in the tank or do you still need them to protect the fuel pump? Sure would be nice if you never had to change those in tank filters (hard to access and expensive).
My first thought was to protect the injectors by placing the filter as close to them as possible. I don't have anything novel to protect the fuel pump. Would be easy to place a filter on the cross over from the right tank but that would only solve half the problem. I may just use a sock filter at the filler - even though its a PITA. On the 690 side, they used a sock filter for the fuel pump. I'm not sure if that would be an option here.
Ride on.
:: Furious Basterds: Velox, Vehemens, Oblivio
:: "For those who don't understand, no explanation is possible. For those who do, none is necessary."
Bartron is offline   Reply With Quote
Old 05-19-2013, 10:21 PM   #7859
StevefrmGV
MotoBro's RetroCycle's
StevefrmGV's Avatar
Oddometer: 411
Before and After Pics
Before
After
Here's the list:
Rebuilt Forks
Rebuilt Shock
Powder Coat swing arm
Service SWA bearings
Adjust valves
New Chain&sprockets
CPR air filter and jetting
Strip old graphics
Paint plastic
Install new graphics by Crispi
Replace front wheel
New discs onorder
Ride...
May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.
Edward Abbey
StevefrmGV screwed with this post 05-19-2013 at 10:27 PM
StevefrmGV is offline   Reply With Quote
Old 05-20-2013, 01:21 AM   #7860
Terence FFM
prof. cat-herder
Oddometer: 364
new skins on new wheels
No pics. Put a pair of MT21s on my second wheels set (21x1.85 and 18x2.5 - basically a SE950R wheelset).
A big thanks to the Orange Crush Hall of Wisdom and specifically Neduro's "How to change tires" page.
Even if I am a long way from accomplishing this task without breaking a sweat, I'm down to 45 minutes front an just over an hour for a rear. Good thing I have no ambition to ever be a competetive enduro rider...
"The powerful will delegate to the untalented until failure is achieved" Dogbert, CEO
Terence FFM is offline   Reply With Quote
Times are GMT -7.   It's 08:02 AM.
