Old 05-20-2013, 04:46 AM   #7861
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,841
Originally Posted by Terence FFM View Post
Even if I am a long way from accomplishing this task without breaking a sweat, I'm down to 45 minutes front an just over an hour for a rear. Good thing I have no ambition to ever be a competetive enduro rider...
Don't worry about t. What this means is when you get a flat in The Great Beyond somewhere, you'll know what to do.
This is what I did to my KTM today (yesterday):
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 05-20-2013, 06:55 AM   #7862
tcskibike2008
SnowHawker
tcskibike2008's Avatar
Oddometer: 195
You left it in the middle of the road while you went and got your tire fixed?
tcskibike2008 is offline   Reply With Quote
Old 05-20-2013, 06:58 AM   #7863
Transalp1999
Oddometer: 13
Dually switch
Originally Posted by mantana View Post
I install this Rigid D2 on SW Motech mounting kit. Fits great!!!
Looks seamless! How did you go about mounting the switch?
I have the same setup on my Transalp and haven't found a solid solution. I'd love to see some more photos!
Transalp1999 is offline   Reply With Quote
Old 05-20-2013, 07:16 AM   #7864
spencergt66
Oddometer: 789
Originally Posted by 1Bonehead View Post
But it does make it hard to ride like this
http://m.youtube.com/#/watch?v=NpI5B...%3DNpI5BNiF8hU
Pretty sure when your in anything that deep your screwed already
Anyone tell you its a bike not a boat
spencergt66 is offline   Reply With Quote
Old 05-20-2013, 07:32 AM   #7865
FakeName
FakeName's Avatar
Oddometer: 1,841
Hah!
All the tire, tools, etc in in the soft, soft grass just off to the right side there. Low traffic road, needed the center hump to get the rear wheel off the ground. The taller suspension needs a taller centerstand which I've not yet completed.
2014 500EXC Black
Old 05-20-2013, 08:45 AM   #7866
kaptinkaos
Just some nOOb
kaptinkaos's Avatar
Oddometer: 722
Originally Posted by zgfiredude View Post
You my friend need a bigger garage......
Yeah... I know... LOL! I spend too much time/money buying tools, riding and enjoying the hell out of myself to house hunt. I work overseas too so my time off is pretty valuable, :)
kaptinkaos is offline   Reply With Quote
Old 05-20-2013, 11:32 AM   #7867
Shov3BR
Tinkerer
Shov3BR's Avatar
Oddometer: 296
Battery Games
Got tired of having to drop the skid plate on my 990 to plug in the Shorai battery charger dongle so I called the guys at Anti Gravity to see what would fit my bike. They recommeded the 16 cell small case but it would have to lay flat to fit. Nope, not so much, the terminals hit the BDCW skid plate.
Thought about modifying the battery box to mount it upright but this would be a hack not an improvement.
Decided to make the Shorai pigtail part of the battery so I could leave it plugged in all the time. Used that Sugru air setting silicone putty to make a plug body.
Routed the pigtail through an existing hole in the side of the battery box...
...and tied it to the jumper cable connector so it is accessible in the same place.
Now I can plug the Shorai charger in when ever I want. Haven't figured out a connector condom yet but I recall seeing something that would work. Just don't remember where or what it was. Anybody got any good ideas here?
Then added a voltmeter up on the dash next to the GPS so I know what is going on with the charging system.
Had the VRR fail in Switzerland last year and didn't know it until the battery went dead on the Motorway. The bike gods were with me as it failed a couple of miles from a Harley dealer who found a KTM dealer for me. The KTM dealer took one off of a Super Duke on the showroom floor for me. That's great service from both dealers
WWW.3BRPOWERSPORTS.COM Putting the POWER in powersports
'11 KTM 990 ADV Dakar, '08 KTM 690 Enduro, '09 H-D Road King, '82 H-D FXRS (Shovelhead)
Shov3BR is offline   Reply With Quote
Old 05-20-2013, 12:05 PM   #7868
Rally_West
Central Scrutinizer
Oddometer: 144
Originally Posted by Shov3BR View Post
I like that dash/bar setup...looks pretty clean.
'07 450EXC Sold but not forgotten...you will be replaced soon.
'07 990 Adv...BOOYAH!
Rally_West is offline   Reply With Quote
Old 05-20-2013, 12:25 PM   #7869
howl
990 Adventure
howl's Avatar
Oddometer: 98
Originally Posted by spencergt66 View Post
Put the CPR intake on the 07 990 since i had the throttle bodies off anyway for injector removal. The filter isnt as easy to get on and Off as i thought it would be but maybe I just need to learn the correct way?
Went to do the 15 min idle and saw the headers glowing red!!! never done that before guess shes a bit lean on the stock setting. REmapped with akro ti slip on map seams alot better test ride confirmed the gain in performance.. The ride was short but wow what a difference
I mean really wow this is a must have that stock air box is such a clunky mess and obviously a huge restriction would deffinetly recommend
Hi
I have just had my 06 990 dyno'd with a custom map (CPR and Ackras with short baffles),the Acra map was close but not spot on . The secondarys now are open and a seperate map for front and rear cylinders . + 8ft/lbs midrange and 5hp all over better than the std Ackra map. It is well worth getting it set up ,it's the same gain again then just putting on the CPR and the NOISE
howl is offline   Reply With Quote
Old 05-20-2013, 12:41 PM   #7870
Sumi
Sumi's Avatar
Oddometer: 1,813
Cleaned and rebuilt forks, cleaned and regreased (mostly the top) the head bearings, retightened them. Tried to get off the fork fluid of the front brake.. This took me a lot of time. I had to take it all apart.. But now they are clean and shiny:) Almost better than new:)
But it's so much fun:)
Still a long way to go (picture is before fork reinstallation) :
Old 05-20-2013, 03:37 PM   #7871
Shov3BR
Tinkerer
Shov3BR's Avatar
Oddometer: 296
HDB Dash Stuff
Thanks. It's mostly Highway Dirt Bikes with a bunch of home brew stuff.
  • One of our TAPP Panel Mount USB sockets on a home brew bracket at the top.
  • 2 Baryl 12VDC panel mount sockets in HDB Powerlet holes. One for tank bag power and the other for heated gloves.
  • Custom circuit board replaces HDB discreet switches and LEDs. I don't have a pic of the actual board but here's the CAD model
Switches run a custom relay board in the glovebox switching power from an Eastern Beaver PC-8 fuse block. The relay board may look like I'm killing ants with a sledgehammer but all those headers and jumpers are fo some selectable control features for future use. I'm thinking of redesigning it to include full size ATO/ATC fuses. I found that there are places where mini-fuses are hard to find, i.e. Russia!
Here's what it looks like installed.
I swapped my locking glovebox for a early-style non-locking type. The locking mechanism took up too much room and made the PC-8 fuses too difficult to remove. No need for a lock. If the bad guys ever got into it they would just be confused. Plus it's covered up with my tank bag.
Old 05-20-2013, 03:57 PM   #7872
Rally_West
Central Scrutinizer
Oddometer: 144
VERY NICE setup...that is basically exactly what I am wanting to do.
Old 05-20-2013, 03:59 PM   #7873
Katoom72
Katoom72's Avatar
Oddometer: 910
Looks like someone is making a 1190 out of their 990
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 05-20-2013, 04:18 PM   #7874
spencergt66
Oddometer: 789
Originally Posted by howl View Post
Hi
had several ongoing issues on my 990 most fuel related and then found broken vacuum lines and a few other small things I added the CPR since I had it apart Ill start fine tuning the map more now that its runing right again but for sure CPR+ stock Map= melted parts
Old 05-20-2013, 04:28 PM   #7875
Rally_West
Central Scrutinizer
Oddometer: 144
Is there a map for older FIs on CPR site? I didn't see one if so. I have a CPR on the way and I am little concerned about the map. I got a Tuneecu cable and software, but might just get her dyno'ed at some point.
Times are GMT -7.   It's 11:06 PM.
