Old 05-20-2013, 04:28 PM   #7876
Shov3BR
Tinkerer
Shov3BR's Avatar
Oddometer: 296
HDB Switch Setup
Originally Posted by Rally_West View Post
VERY NICE setup...that is basically exactly what I am wanting to do.
The ideal setup would be to have Rowe make a version of the PDM60 that had four switch inputs plus a couple of non-switched circuits. Now THAT would be sweeeet. Get rid of the relays and fuses altogether.
WWW.3BRPOWERSPORTS.COM Putting the POWER in powersports
'11 KTM 990 ADV Dakar, '08 KTM 690 Enduro, '09 H-D Road King, '82 H-D FXRS (Shovelhead)
Shov3BR is offline   Reply With Quote
Old 05-20-2013, 05:25 PM   #7877
spencergt66
Oddometer: 789
Is there a map for older FIs on CPR site? I didn't see one if so. I have a CPR on the way and I am little concerned about the map. I got a Tuneecu cable and software, but might just get her dyno'ed at some point.
I have never seen one I believe the owner @ CPR runs the Dyno jet setup on his 990 from what I was told. For right now Im just using the Akro ti slip on tune with the 02 sensors on pry not optimal but works pretty good right now
spencergt66 is offline   Reply With Quote
Old 05-20-2013, 06:04 PM   #7878
Rally_West
Central Scrutinizer
Oddometer: 144
Looking at the manual it looks as if that can be done. You can have any circuit be always on, or non-switched. And it appears as if the aux. wire can be used to trigger any of the circuits, which might not be exactly what you are looking for but might work.
'07 450EXC Sold but not forgotten...you will be replaced soon.
'07 990 Adv...BOOYAH!
Rally_West is offline   Reply With Quote
Old 05-20-2013, 08:13 PM   #7879
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,836
Replaced the graphite exhaust gasket today and started packing for a 5 day desert offroad ride.
Old 05-20-2013, 09:52 PM   #7880
chrish4ku
chrish4ku's Avatar
Oddometer: 863
Got the ADV tank from the old bike onto the new bike - now just need Bert to bring up the pipe!
my fuel line route
_______________________
Chris
I don't normally ride on the street,,,but when I do,,I prefer lane splitting.
2011 KTM 990 Adventure / KTM 500 EXC
Chris' Sat Tracker
chrish4ku is online now   Reply With Quote
Old 05-21-2013, 01:17 AM   #7881
mudder
mudder's Avatar
Oddometer: 315
Yesterday, I changed to a high front fender.
www.hojresor.se
www.youtube.com/user/hojresor
990R & 690E
mudder is offline   Reply With Quote
Old 05-21-2013, 07:56 AM   #7882
Jonasson
Jonasson's Avatar
Oddometer: 35
After some brake faileur i changed all brake fluid.
Old vs New
Then i fited some safecase(peli cooy) instead of the seatbag(touratech) i had before
It fits all i nead for a after work trip ;)
Jonasson is offline   Reply With Quote
Old 05-21-2013, 09:46 AM   #7883
Joeman68
Tanker
Joeman68's Avatar
Oddometer: 29
New place for Shorai
/ Joeman
2004.5 KTM 950 ADV
Husqvarna MC 258 Army
Joeman68 is offline   Reply With Quote
Old 05-21-2013, 01:03 PM   #7884
katanarama
riding > posting
Oddometer: 182
Took the ferry to Nanaimo, road to Tofino. Found another use for the 990: wet suit drying rack.
Image and video hosting by TinyPic
katanarama is offline   Reply With Quote
Old 05-22-2013, 10:34 AM   #7885
Loui€
Rides With Reindeer
Loui€'s Avatar
Oddometer: 50
Anti Gravity 16 cell fits nicely
Got tired of having to drop the skid plate on my 990 to plug in the Shorai battery charger dongle so I called the guys at Anti Gravity to see what would fit my bike. They recommeded the 16 cell small case but it would have to lay flat to fit. Nope, not so much, the terminals hit the BDCW skid plate.
well, Anti Gravity 16 cell small case fits nicely, turn it ccw sideways, so terminals are on left side. perfect!
upper minus, down plus-terminal.
grey filling stuff is from package;
plus-cable is partly in a white plastic tube, so it won't wear off as 'grinding' against chassis (original cable did, and old battery died...);
minus-cable makes a loop down to reduce excess length.
L
Loui€ screwed with this post 05-22-2013 at 11:12 AM
Loui€ is offline   Reply With Quote
Old 05-22-2013, 11:42 AM   #7886
kaptinkaos
Just some nOOb
kaptinkaos's Avatar
Oddometer: 729
Second fan amongst a plethora of other things while I had the bike apart for it's first lube job,
kaptinkaos is offline   Reply With Quote
Old 05-22-2013, 05:41 PM   #7887
Qwik
Adrenaline Addict
Oddometer: 6,893
Put a new sticker on it.
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 05-22-2013, 06:29 PM   #7888
catalina38
Contrarian
Oddometer: 1,659
Infidel!
A mangy man chasing a cautionary tale
Lurking more and posting less
KTM 990R 500EXC
catalina38 is offline   Reply With Quote
Old 05-22-2013, 06:36 PM   #7889
Qwik
Adrenaline Addict
Oddometer: 6,893
Originally Posted by catalina38 View Post
infidel!
Old 05-22-2013, 07:18 PM   #7890
Shov3BR
Tinkerer
Shov3BR's Avatar
Oddometer: 296
L
Cool thanks. still have the Anti Gravity and it is the 16 cell small case.
I'm going to give it a try.
Times are GMT -7.   It's 10:57 AM.
