Old 05-27-2013, 08:11 AM   #7906
prince
prince's Avatar
Oddometer: 95
hey guys i seem to have a problem w my throttle response on first and second gear, meaning as i open it the bike rattles a bit. As well as on later gear the throttle feels sometimes "weak". Any idea what it could be?
07 KTM 990 adv
06 Triumph Scrambler
04 1150 GSA (sold)
02 1150 GS ( crashed and stolen)
00 750 Ducati monster ( sold)
prince is offline   Reply With Quote
Old 05-27-2013, 10:33 AM   #7907
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,811
Fastway Adventure Footpegs.
Yes- yes, very much.
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 05-27-2013, 12:11 PM   #7908
mroddis
Oddometer: 205
Got up early and rode it 125 kms down from Whistler to Vancouver, just in time for a morning meeting...these bikes are simply awesome!
Matthew.
2006 KTM 950 Adventure - Black
mroddis is offline   Reply With Quote
Old 05-27-2013, 01:44 PM   #7909
repho
repho's Avatar
Oddometer: 11
Originally Posted by deepsea rider View Post
Got finished installing my ADV monster LED lights and got to say they are great, really lights up the night.
I wired them through the accessory connection and installed this switch, which lights up when on, just to remind me if they are on during the day, they will definatly blind on coming traffic and anyone I am behind
Hey deepsea rider.
What kind of brackets did you use to mount the lights on the crash bars?
They don't look bad!
repho is offline   Reply With Quote
Old 05-27-2013, 03:46 PM   #7910
deepsea rider
deepsea rider's Avatar
Oddometer: 76
I got the brackets from ADVmonster.com. see this link:
http://stores.intuitwebsites.com/hst...unt/Detail.bok
They have outstanding customer service.
Originally Posted by repho View Post
Hey deepsea rider.
2008 KLX 450r
2002 XR650R
2010 KTM 530 EXC CE
2012 KTM 990 ADV
Ride hard, eat good and Drink tequila.
deepsea rider is offline   Reply With Quote
Old 05-27-2013, 04:12 PM   #7911
jon6.0
jon6.0's Avatar
Oddometer: 546
.62 fork springs from Slavens.
Seat Concepts lower and firmer seat. Way better than the stock seat, but still get a bit of numb butt. I might try an Airhawk pad for long slab sections.
2013 KTM 690 Duke w/ performance cam, airbox, and Akrapovic full system. 300lbs and 74.5rwhp
2011 KTM 250XC with lots of protection stuff for when I bounce it down a hill.
jon6.0 is offline   Reply With Quote
Old 05-27-2013, 07:54 PM   #7912
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,836
Replaced the water pump shaft and seal. Pulled the case cover off without breaking the gasket!
Then it got bent over and broke. I suck at mechanic-ing.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 05-27-2013, 11:36 PM   #7913
686 Sahara
Oddometer: 23
Service And Farkles
4000 mile oil change
H&B Racks
And After 80 holes to drill got the Globscouts Installed
686 Sahara is offline   Reply With Quote
Old 05-28-2013, 11:24 AM   #7914
Sheep Shagger
Show me your fleece
Sheep Shagger's Avatar
Oddometer: 2,147
Forgot how much I hate bodywork.
Decided to finally chance the windshield & lights around. After searching there wasn't anything out there I liked, so figured I'd try at making my own.
My main idea was I wanted the 2x 90mm Hella lights from the rally bike and an upturned lip to the screen. Just not as saver as TT setup, and it had to be finished on the backside.
So after finding someone who makes a "plug" twin light setup that fits in the OEM screen, I decided to use that and modify the OEM screen.
After lots of maths, I ended up marking the section to be cut by eye.
Heated up the edges, bent the top over, and plastic welded it in place. (Plastic welding perspex is a real pain)
Nothing a lot of sanding can't fix.
Next I epoxied in the twin light plug, and fiber-glassed the rear.
Filling and sanding
This is where I'm at now. Needs some more finish sanding and filling, then it will be painted blue to match the body.
Sheep Shagger is online now   Reply With Quote
Old 05-28-2013, 01:15 PM   #7915
srad600
srad600's Avatar
Oddometer: 659
Nice work!
srad600 is offline   Reply With Quote
Old 05-28-2013, 03:09 PM   #7916
DeepSea
electronically challenged
DeepSea's Avatar
Oddometer: 237
Looks sharp. Can't wait to see the end product.
CDR 2012 ------ Too Lazy to write my own RR
Commercial Diving flashlight and tools
It's not me. My bike is Narcoleptic.
Research is what I'm doing, when I don't know what I'm doing.
DeepSea is offline   Reply With Quote
Old 05-28-2013, 07:10 PM   #7917
SierraJeep
It's toast
SierraJeep's Avatar
Oddometer: 630
One thing leads to another...
So yesterday I decided it was time to try and fix the wiring issue I've had on my 990 Acc. #1 feed. I hook my GPS to that one so it'll stay on while I stop and fill up for fuel. (And yes, I run the risk of it draining the battery if I leave it on.) Over time, the GPS would start to come on by itself while it was parked (see prior comment) and then it started to switch to battery mode while the bike was running. So I decided to pull the headlight shell and take a look at the wiring.
To remove the shell (with the Safari tanks) I had to remove the two bolts on each side of the front end, and then loosen (but not remove) the lower ride tank mount bolts to allow me to separate the tanks far enough to get the light side tabs undone. (I was working by myself so I didn't have a helping hand.) When loosening the lower tank mount, my left side fuel line start to flow (as in, onto the floor).
Short version: I shut off the tank flows and fixed the wiring issue.
Long version: I then spent three more hours fixing the fuel line and trying to re-attach the Safari tanks. Gotta love the way they fight you every step of the way. Gotta love MORE the way they hold oh so much fuel.
The 20 minute job turned into a 3.5 hour fix a bunch of other shit job.
Tod
2010 KTM 990 Adventure
2010 KTM 450 EXC
SierraJeep is offline   Reply With Quote
Old 05-28-2013, 07:29 PM   #7918
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 6,868
Ugh, I figured I may as well bitch to you guys about it....
I noticed, today, after fixing an ignition switch issue, that my idle is hanging. So, I searched the OC and after reading some stuff I decided to take the bike apart, check my choke cable, breather tubes, etc.
Figured I may as well check the jets and needle while I was in there. Taking the black plastic cap off the carb and down goes on of the black shoulder screws into the bowels of the bike.
I searched for over an hour with a shop light, flash light, telescoping magnet. I even laid the bike down to try to shake it out. Sonofabitch.......
Inside now, I'm starving. Back at it tomorrow.
'06 KTM 950 Adventure S
'12 Ram 2500, Cummins, 6-speed auto, Laramie Longhorn, RamBox
"The bouncer is a bulldog who looks like Wilford Brimley and the password is 'diabetus'"-Stefon, SNL character
DakarNick is offline   Reply With Quote
Old 05-28-2013, 09:15 PM   #7919
StevefrmGV
MotoBro's RetroCycle's
StevefrmGV's Avatar
Oddometer: 411
Pulled Carbs, Installed Larger main jets
04 950, Removed Carbs, Installed larger main jets, front = 178, Rear = 182.
Have not test rode yet.
I had installed a CPR air-filter system. It was running lean. Previously replaced the needles with the Factory pro ones, ran better but still a little lean.Hoping these mains will bring it in? Test ride in the morning.
May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.
Edward Abbey
StevefrmGV is offline   Reply With Quote
Old 05-28-2013, 09:18 PM   #7920
motoracer51
Oddometer: 652
Pulled my stator cover off as it was weeping oil. I suspect the gasket wasn't good. Going to apply some Threebond 1104 and reassemble.
motoracer51 is offline   Reply With Quote
Times are GMT -7.   It's 12:35 AM.
