Old 06-08-2013, 07:18 PM   #7981
BykBoy
Meshuganeh
BykBoy's Avatar
Oddometer: 561
MRA X-Creen Add-On Variable Windscreen Spoiler Blade
Installed the MRA X-Creen Add-On Variable Windscreen Spoiler Blade on my Carbon Fiber windscreen.
The X-Creen is fully adjustable. The mounting arms have a pivot point at the windscreen and at the X-Creen. This allows the X-Creen to be set at infinite positions.
The X-Creen positioned high over the CF windscreen:
The X-Creen positioned in the middle:
The X-Creen positioned as low as possible:
There are two tabs that hold the adjustment arms in place. When the tabs are vertical, the X-Creen is locked in place. When they are horizontal (as seen in the photo), the X-Creen can be adjusted:
Here is the mounting bracket that connects the X-Creen to the windscreen. I drilled two holes in the CF windscreen for each arm mount. The long arms have two pivot points on the base: up and down + left and right. This allows the arms to be installed on almost any angle windscreen
View from the rider's seat with X-Creen in high position:
Technical drawing showing the arms, pivot points, locking tabs, and windscreen mounts:
Took it out for a short ride. It helps a lot with the buffeting and wind protection when set in the high position. It's probably not suitable for riding single track through the woods though. However, I can easily remove it by taking out the two screws that hold the lower (windscreen) mounting pivots.
Product looks to be well built. It is clearly designed for touring and road use. Not sure how it will hold up in rough riding. Time will tell.
Save $5 when you open a SmugMug account. Use the following coupon: 4l1hicJzWvYNE
BykBoy screwed with this post 06-08-2013 at 07:23 PM
BykBoy is offline   Reply With Quote
Old 06-08-2013, 08:03 PM   #7982
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 3,285
Took this apart:
Orangecicle is offline   Reply With Quote
Old 06-09-2013, 02:05 PM   #7983
RENCRN8
RENCRN8's Avatar
Oddometer: 251
Got it dirty....
Then washed it.....
RENCRN8 is offline   Reply With Quote
Old 06-09-2013, 02:44 PM   #7984
Goosefeather
Captain Slow
Goosefeather's Avatar
Oddometer: 897
Wondered where to go next . . .
On a trip to Central Queensland, where I tested my crash bars on a slimy causeway ( luckily only at walking pace )
Goosefeather is offline   Reply With Quote
Old 06-09-2013, 04:47 PM   #7985
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 7,032
Still messing with my carbs to get the damn thing running correctly. It'll be up for sale in the fall.
'06 KTM 950S Adventure
'12 Ram 2500, Cummins, 6-speed auto, Laramie Longhorn, RamBox.
DakarNick is offline   Reply With Quote
Old 06-09-2013, 05:16 PM   #7986
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,837
Well let's see:
Tore it down
Checked the valves for the first time, ever, on anything
Replaced the air filter
Replaced the fuel filters
Chopped the kickstand for my 19/17 wheels
My ghetto-fabulous quick change extension
Padre's answer to my ghetto-fabulous quick change extension
Replaced the water pump shaft and seal
Put on CJ's peg extensions (which work great for holding the WP impeller!)
Put it back together, put a gallon of gas in the left tank...
CLACK CLACK CLACK CLACK
*heart attack/stroke/brain aneurism trifecta*
Realized the bike died because a gallon of fuel isn't enough for the fuel pump to prime in the supertanker Safari tanks
Burned 2.8 gallons of diesel in a fiery burnout going .18 miles up to the gas station and back
Put more gas in supertanker Safari tanks
Deduced that the horrible noise of death was the lack of oil on the cam chain
Went out and rode it 5 miles in 82* heat during Charlotte rush hour
Drank copious amounts of alcohol when it didn't explode
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 06-09-2013, 07:12 PM   #7987
spencergt66
Oddometer: 808
Originally Posted by smitty141 View Post
Did the "Big washer" on the kickstand trick. Weld on the bottom for a super clean look.
Made a bracket to hold my Spot Tracker. ...
Smitty
Nice bracket but when you in a position like this is a good idea to have your spot on you
It may not look too bad but this was so steep there was no way to walk or climb up if I was alone I would have been screwed
I was about 300 ft away from the bike and below the tree was all that stoped me from going for along way
spencergt66 is offline   Reply With Quote
Old 06-10-2013, 04:52 AM   #7988
1Bonehead
Fearless of Falling
1Bonehead's Avatar
Oddometer: 1,113
First, I went out and got it dirty
Then I crashed a streetbike motorcycle Bikini Wash
Since my Son wasn't able to attend the girls sent him a special note;
1Bonehead is offline   Reply With Quote
Old 06-10-2013, 06:12 AM   #7989
smitty141
smitty141's Avatar
Oddometer: 660
If I was in a spot like that, I would not want anyone to know... :
Smitty
RIP.. Skinny Dave...RIP.. Chester_______________
2015 KTM 690r Enduro, 2010 BMW 800gs. 2008 Suzuki DRZ400SM, 2004 KTM 450 EXC
smitty141 is offline   Reply With Quote
Old 06-10-2013, 06:26 AM   #7990
smitty141
smitty141's Avatar
Oddometer: 660
I like this pic alot better...
Where was this bike wash at???
Smitty
Old 06-10-2013, 07:40 AM   #7991
beewill
beewill's Avatar
Oddometer: 130
Originally Posted by RENCRN8 View Post
Got it dirty....
Then washed it.....
That was a good time. We'll have to do it again soon. Did you get a chance to powerwash your Aerostich yet?
Here's the two dirty girls together, too bad it wasn't three........
2004 KTM 950 Adventure
A bore is someone who deprives you of solitude without providing you with company.
― Oscar Wilde
beewill is offline   Reply With Quote
Old 06-10-2013, 10:14 AM   #7992
trailjammer
trailjammer's Avatar
Oddometer: 381
Smitty
I know right! There's some hotties! I need to find that kind of bike wash near me. haha awesome!
TRAILJAMMER DESIGNS -KTM/Berg/YAMAHA PROTECTION! www.facebook.com/trailjammer408
www.trailjammerdesigns.com
trailjammer is offline   Reply With Quote
Old 06-10-2013, 10:39 AM   #7993
Masso75
Oddometer: 183
New transmission kit 17/44 Sunstar and DID chain ,original chain guide for SM/SMT code 63004066100,new clutch slave with double OR,new tank filter to protect filter pump (and soon I'll modify my pump with a external filter...) and new Heidenau K60 Scout.....I love my Adventure !!!
Masso75 is offline   Reply With Quote
Old 06-10-2013, 10:39 AM   #7994
Vicks
gets stuck in sand
Vicks's Avatar
Oddometer: 3,206
Wanted to prep the bike before shipping her off to India. The weather here is crappy hot and humid so i got her inside the house where i can work in comfort of the A/c.
2007 KTM Adv990S - Sold, 2010 KTM530Exc-Rally and 2012 KTM Adv990
530Exc Adventurization re-build
Vicks is offline   Reply With Quote
Old 06-10-2013, 11:25 AM   #7995
Brokein2
Oddometer: 267
OK Masso......spill the beans on the fuel filters.
Craig A.
'09 990 ADV
'11 R1200RT
'14 R1200GS
Brokein2 is online now   Reply With Quote
Times are GMT -7.   It's 04:01 PM.
