Old 07-01-2013, 05:44 PM   #8116
gozirra
Spam?
Oddometer: 160
Originally Posted by amanlikemike View Post
I did this:
What material did you use for this?
gozirra is offline   Reply With Quote
Old 07-01-2013, 07:49 PM   #8117
kaptinkaos
Just some nOOb
kaptinkaos's Avatar
Oddometer: 912
I beat mine up
Broke a rear signal, got some sweet new scratches on the windscreen while maneuvering it under a fallen log on a rocky downhill section and the rear plastics vinyls are peeling off from my knees rubbing it with dirt combined, lol! Got some pretty good gouges in the skid pan, bark busters and fork guards too. Was a beauty day and only one minor get off on a sketchy little hump after a creek crossing. Nothing hurt in that one except my pride though... All that in only 60 kms, ha! I'm am gonna be pretty sore in two days though... Been a while since I had that kind of workout!
Time to shop for some new flush mounts... And pines after better suspension yet some more... Here's a bit of the single track I rode. GoPro batts died about 2 hours in (forgot to charge the backups derp) and we didn't take many pics... I wish I had, but the going was pretty tough and no one was in a picture taking mood.
kaptinkaos is online now   Reply With Quote
Old 07-01-2013, 08:33 PM   #8118
BigNastybrp
Big Nasty
BigNastybrp's Avatar
Oddometer: 696
I changed the bald 908r for the used 908r, I got from Chris in the 90 deg heat in the drive way. was just over a hour the bad part was I am out of beer. what was I thinking. tomorrow the oil change and Pack
BigNastybrp is offline   Reply With Quote
Old 07-01-2013, 08:43 PM   #8119
DutchVDub
Oddometer: 1,349
Got mine safely home after having STM Suspension got through my forks. It rides down the interstate a lot better now. Before it was really twitchy when going over all the expansion joints on concrete sections of pavement. Now, its butter smooth.
2008 Honda Shadow 750 Spirit
2013 Victory Cross Country
DutchVDub is offline   Reply With Quote
Old 07-02-2013, 10:06 AM   #8120
xTomKx
xTomKx's Avatar
Oddometer: 196
Mounted up a gps to the 990
2012 KTM 990A, 2006 KTM 250 2s, and many other toys
xTomKx is offline   Reply With Quote
Old 07-02-2013, 12:44 PM   #8121
amanlikemike
Recoverin speedfreak
amanlikemike's Avatar
Oddometer: 1,057
I used this stuff: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
There are cheaper options, but I liked how thin it is. Plus, fitting it was a PIA and I figured the extra cash was worth [hopefully] not having to do it again.
I also shielded the inner side of the pump housing and had plenty left over, just in case. Smaller sheets are available, but I needed this in a hurry and that was the only size I could get in time.
Haven't had chance to see if it cures the issue yet, but so far I'm pleased with the way it adhered (all I did was clean and degrease the area prior to application) and am hopeful it will at least help delay things. If it doesn't, it could be time for a second fan and low temp thermostat switch, I guess...
Cheers,
Michael
'Ave it.
BritKit LLC
US Distributor of Kriega Motorcycle Luggage
www.kriega.us / Facebook / vendors thread
amanlikemike is offline   Reply With Quote
Old 07-02-2013, 02:12 PM   #8122
Jaimoto
Spaniard in Chile
Jaimoto's Avatar
Oddometer: 1,345
Good job!
I wish my tanks and airbox had that insulation but I don't want to go through the process of doing it
Jaime
KTM 1190 Adv R
Jaimoto is online now   Reply With Quote
Old 07-02-2013, 02:29 PM   #8123
DutchVDub
Oddometer: 1,349
Hell, I want to put that stuff on the bottom of my seat.
Old 07-02-2013, 05:42 PM   #8124
gozirra
Spam?
Oddometer: 160
I have used both the DEI tape in 2" and the reflective/kevlar adhered with a spray mount and tape, I figured you had used the sheet as I could not see any lines. (I will now be doing the same because yours looks so good)
Epic work, so clean.
You will no doubt see a difference - even with the lower quality stuff (think Lowes or HD tape) you will find that it really reflects heat well. (just the glue fails at like 200-300 degrees)
(dont fall into the its gold trap, silver works better till you hit the big $ material.)
Old 07-03-2013, 07:08 PM   #8125
Vicks
gets stuck in sand
Vicks's Avatar
Oddometer: 3,204
I did this:
Do that for the air box as well. Your engine will like it better. Drop in IAT guaranteed.
2007 KTM Adv990S - Sold, 2010 KTM530Exc-Rally and 2012 KTM Adv990
530Exc Adventurization re-build
Vicks screwed with this post 07-03-2013 at 08:19 PM
Vicks is online now   Reply With Quote
Old 07-03-2013, 08:33 PM   #8126
Vicks
gets stuck in sand
Vicks's Avatar
Oddometer: 3,204
Replaced the crappy hose clamps (worm type) with better quality Jubilee ones and that stopped the coolant leak from the SAMCO hoses. Put in fresh TOTAL Rubia SAE50 Diesel engine oil and a new stock airfilter as well. At the price KTM charges for a paper air filter i'm thinking of going for a re-usable one but concerned about the guaze/fabric mesh ones in my riding environment (desert - fine sand, frequent dust storms)
mounted a set of (louder) car horns through a relay for the India trip , changed the leaking oil tank dip stick O-ring (and bought a few spares from the local hardware shop), checked the clutch and stator bolts. Stator ones were plenty tight so left them alone. Clutch bolts were not so and had zero Loctite on them. Re-tightened them with some Loctite applied. Tried a few variations of the FI tune - its a revelation to be able to download a different mapping with a different engine response within 2 mins, do a 15 min reset and then go on a ride and my tunes are getting better with seat of the pants testing but I do plan to get a dyno tune done one day.
Fitted Charlie's sidestand relocator
made the sidestand adjustable for my 17" SD wheels. Still need to get the brake rotor adapters made for the SD wheels....
Old 07-03-2013, 11:29 PM   #8127
duroturk
duroturk's Avatar
Oddometer: 271
Nice jobs.
Migth be better to stick with the paper filter, unless you use a prefilter.
I removed my prefilter tho, I did not like it.
Nurettin
duroturk is offline   Reply With Quote
Old 07-04-2013, 12:13 AM   #8128
kaptinkaos
Just some nOOb
kaptinkaos's Avatar
Oddometer: 912
Bendy
I beat it into submission... Didn't have the strength to show an after-picture though. Maybe tomorrow, lol!
Old 07-04-2013, 06:51 AM   #8129
EZ300
EZ300's Avatar
Oddometer: 1,169
Rode it north....
EZ
AMRA
2007 KTM 990 Adventure
2010 KTM 530 XC-W Six Days
www.rockstarsmc.com
EZ300 screwed with this post 07-04-2013 at 08:31 AM
EZ300 is offline   Reply With Quote
Old 07-04-2013, 12:59 PM   #8130
srad600
srad600's Avatar
Oddometer: 688
I brought this home...
took them out of the box...
Installed them, it went together much easier than I thought, and ended up with this...
Then rode it here to break in the system.
srad600 is offline   Reply With Quote
Times are GMT -7.   It's 11:05 AM.
