Old 09-17-2013, 06:53 AM   #8491
jeventures
Oddometer: 230
Originally Posted by GoGoGavin41 View Post
Rode with the wife up to Big Sur a few weekends ago. Going to finish the ride report one of these days.
Los Burros or Lost Coast Rd? Was out there with my wife just before labor day weekend. Some nice views.
Every man dies but not every man lives.
jeventures is offline   Reply With Quote
Old 09-17-2013, 07:16 AM   #8492
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,850
Originally Posted by Patacca View Post
Well now that we are like this...
show us some pics (learning how to do)....
photobucket is the problem not my ability to post pics
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls is offline   Reply With Quote
Old 09-17-2013, 07:19 AM   #8493
Patacca
Pimp my SE italian style
Patacca's Avatar
Oddometer: 564
so just post 3 of them....please
If you aren't sure, open to MAX!!!
www.raffaellophoto.com
check out my pimped SE @
http://www.myktm.it/viewtopic.php?f=50&t=223
Patacca is offline   Reply With Quote
Old 09-17-2013, 07:38 AM   #8494
veetwo _tls
RENOVATIO:
Oddometer: 1,850
woo hoo it's working again
CHEERS: brett
MY07 950 SER
Old 09-17-2013, 08:44 AM   #8495
GoGoGavin41
Isn't this that guy?
GoGoGavin41's Avatar
Oddometer: 829
This is actually Nacimiento-Fergusson Rd
http://goo.gl/maps/O48aa
A little out of the way but great riding, good camping (except for the flies), and awesome views.
GoGoGavin41 is offline   Reply With Quote
Old 09-17-2013, 09:06 AM   #8496
jeventures
Oddometer: 230
Ah, yes, another great one. I was visiting from TN and felt like I was cheating with the latest butler maps. No need for gps tracks and weeks of route planning....just follow the pretty colors on the maps and end the day in the national forest for camping.
Thread jack over. Last thing I did to my 950 was look at the photo provided by the guy I sold it to. Already contemplating an /08 990.
Old 09-18-2013, 03:15 PM   #8497
Sumi
Sumi's Avatar
Oddometer: 1,799
Pulled the forks apart to swap the recently installed green wp oil seal for the old style black seal.. as I believe (really hope) that caused my forks sticking.. I'll reinstall the forks to the bike later and see if it made any change.. As always, my KTM dealer was kind enough to lend his shop and tools for me to carry out the job:)
Old 09-18-2013, 03:50 PM   #8498
DuctTape
Oddometer: 351
Sweet! Even bought ya a beer.
2013 KTM 690 (Thanks FLHRCI Buyer! )
2011 990 Adventure Dakar (Thank you Honey!)
2010 Aprilia RSV4 Factory
2010 Ducati 1198S
DuctTape is offline   Reply With Quote
Old 09-18-2013, 06:36 PM   #8499
freebird82
Oddometer: 47
One of my favorite roads that I just discovered this spring!
freebird82 is offline   Reply With Quote
Old 09-18-2013, 07:08 PM   #8500
rburkat
rburkat's Avatar
Oddometer: 293
Gave my bike a platinum spa treatment this past weekend
Valve adjust
New semco hoses
New thermostat
New sparkplugs
Remove grooved waterpump shaft and replace
New rear bearings to replace this mess
Now I'm ready to ride.
rburkat is offline   Reply With Quote
Old 09-18-2013, 07:42 PM   #8501
Shov3BR
Tinkerer
Shov3BR's Avatar
Oddometer: 296
New Horn
I got tired of no one hearing my wimpy 990 ADV horn so it got replaced with something bigger. The new horn wouldn't begin to fit in the stock location so I put it in the left upper where the canister used to be.
That lump next to the horn had to go so it was Dremmel time.
The lumpectomy left a big hole that weakened the panel so I added an aluminum stiffener which got bonded to the plastic. I'll keep an eye on it and if it de-bonds I'll pop rivet it in place.
The horn as installed. The horn wires actually exit from the left side of the harness and normally cross over to the stock horn location so they were plenty long enough to reach the new horn location.
No I can command some respect at those rare moments when I hit the klaxon button.
WWW.3BRPOWERSPORTS.COM Putting the POWER in powersports
'11 KTM 990 ADV Dakar, '08 KTM 690 Enduro, '09 H-D Road King, '82 H-D FXRS (Shovelhead)
Shov3BR is offline   Reply With Quote
Old 09-18-2013, 08:05 PM   #8502
Shov3BR
Tinkerer
Shov3BR's Avatar
Oddometer: 296
Stubby Turn Signals
Since I had the front Tupperware off to replace the horn (see previous post) I decided to do something about the turn signals which had a bad habit of breaking off when I augered in.
My son had some Proton turn signals that he was going to put on his GSX-R 1000 but I snagged them before he had a chance to install them.
I cut off the stock turn signal at the first rib. This is just above the end of the embedded metal mounting stud.
The Proton has a very small mounting stud maybe 4-40 or M3 so I drilled a hole just a little bit smaller than the stud at the back edge of the cut off stalk.
This let me press the Proton mounting stud into the hole where the friction of the rubber held it in place.
A couple of one ounce packets of SUGRU air curing silicone putty filled the gap and provided a smooth surface.
Sorry I didn't take pics of the actual modifications. I was afraid he would catch me using his Protons and take them back.
The ACC2 connector was getting to be rather busy with the addition of the Protons since they require +12V along with the stock turn signal wires. I had already added a digital voltmeter and one of our TAPP all-weather USB power ports to this connector. The solution was to make this splitter with a mating spade connector on the ACC2 end and four shrink jacket bullet connectors on the other. The GND side splitter only needed two bullets as the turn signals are grounded with the stock wiring.
Here's the finished setup running in the "strobe" mode.
Shov3BR screwed with this post 09-18-2013 at 08:16 PM
Old 09-18-2013, 11:12 PM   #8503
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 716
Originally Posted by Shov3BR View Post
Here's the finished setup...
Looks good from the side but not so good from the front-where it counts.
HeatXfer is online now   Reply With Quote
Old 09-19-2013, 09:21 AM   #8504
EZ300
EZ300's Avatar
Oddometer: 1,112
Replaced my stock rear rotor with a new stock rear rotor.
42000 miles out on the first one!
Old rotor was deeply grooved and I had to push the brake pedal a great distance to get the bike to stop.
EZ
AMRA
2007 KTM 990 Adventure
2010 KTM 530 XC-W Six Days
www.rockstarsmc.com
EZ300 is online now   Reply With Quote
Old 09-19-2013, 08:08 PM   #8505
Eldon
950 ADV
Eldon's Avatar
Oddometer: 506
How many miles did you get out of the water pump saft?
05 KTM 950 ADV. Black (Black ones aren't faster. Fast riders just buy them)
06 YZ250 Smoker
00 KTM LC-4 - Sold
93 CR125 - Sold
89 CR80 - Sold
84 XR80 - Sold
74 Honda MR50 - Sold and I wish I hadn't
Eldon is offline   Reply With Quote
Times are GMT -7.   It's 10:09 PM.
