Old 12-13-2013, 01:18 PM   #8851
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,510
I hope I remember to put both of them together. New front rim on the 990. New top end on the 450.
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle is offline   Reply With Quote
Old 12-13-2013, 02:05 PM   #8852
srad600
srad600's Avatar
Oddometer: 674
Originally Posted by DirtJack View Post
Wally World
Wish we had one of those around here.
So I picked up this little gadget to check the throttle body sync.
...sent...
BAJA 2014 - 990s
srad600 is offline   Reply With Quote
Old 12-13-2013, 02:14 PM   #8853
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,132
...sent...
O'reilly's or whatever they call it these days has it. Amazon will ship it to your door, too, or you can ride up to hilltop mall and stock up on motor oil and cheap underwear at the walmart.
I use rotella exclusively, but sometimes the synthetic stuff and sometimes the dino stuff. 65k and no oil related problems yet. . . .
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 12-13-2013, 02:19 PM   #8854
srad600
srad600's Avatar
Oddometer: 674
Cool, thanks. I'll pick some up this weekend.
Old 12-13-2013, 07:49 PM   #8855
Decepticon
Decepticon's Avatar
Oddometer: 126
Laugh Temporary shock abs
I sent to maintenance the rear shock absorber. So I built one made of wood to allow a little movement of the bike through the garage. Not suitable for riding!!!
2007 KTM 990 Adventure ABS
A lot of bad things have been said about me, all of them are true
Decepticon is offline   Reply With Quote
Old 12-14-2013, 08:59 AM   #8856
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 723
Did you find that locally or order online?
I'm late, as usual. I'm not a fan of Walmart, I get it at O'Reilly's.
HeatXfer is online now   Reply With Quote
Old 12-14-2013, 04:39 PM   #8857
srad600
srad600's Avatar
Oddometer: 674
Thanks for the tips on where to find Rotella. I was able to grab some at O'Reillys. I flushed the motor and the oil came out clean this time, and the filter came out perfectly straight.
So then I decided to install Charlie's side stand relocator. It's a really solid piece of kit.
Lastly, I synced the throttle bodies using the SK flowmeter. This is a great tool, makes it really easy to sync the TB's.
I went for a little test ride afterwords, put about 20 miles on the bike, and the throttle actuation is much much smoother.
...sent...
BAJA 2014 - 990s
srad600 screwed with this post 12-14-2013 at 04:47 PM
Old 12-14-2013, 04:48 PM   #8858
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,717
Went for a ride to find dirt to knock the edges off the knobs and blow the cobwebs out.
It was different.
...Dick
"You don't go to Mongolia for the food." - Sebastian & Kim
2010 KTM 990 Adventure R
My Life With The 990R
Smugmug
Mr Head is offline   Reply With Quote
Old 12-14-2013, 05:26 PM   #8859
macleod
New guy
macleod's Avatar
Oddometer: 98
Went for a little ride
Sent from my Nexus 4 using Tapatalk
live long and prosper
macleod is offline   Reply With Quote
Old 12-14-2013, 06:40 PM   #8860
spencergt66
Oddometer: 784
Valve Adjustment and spark plugs.
When I pulled the radiator I saw a lot of this goo WTF is that from? Doesnt look like oil really grey and sitting in the hoses
spencergt66 is offline   Reply With Quote
Old 12-14-2013, 06:43 PM   #8861
rattis
rattis's Avatar
Oddometer: 1,209
Flyin´
Put on a plane to Colombia, yihaaa
I wish I had bought a GSA a long time ago
and now I drink Orange Crush as well, thrice up now, two 990 Adv and a 950 SER
rattis is offline   Reply With Quote
Old 12-14-2013, 09:09 PM   #8862
EZ300
EZ300's Avatar
Oddometer: 1,116
Went for a winter ride in Arizona.....
EZ
AMRA
2010 KTM 530 XC-W Six Days
www.rockstarsmc.com
EZ300 is offline   Reply With Quote
Old 12-15-2013, 05:52 PM   #8863
godwinmt
They call me Crash
godwinmt's Avatar
Oddometer: 668
Took her out for a ride today through some of the back roads now that they're clearing off...
Rest of the pictures here
-M
godwinmt is offline   Reply With Quote
Old 12-15-2013, 06:46 PM   #8864
devildogg
devildogg's Avatar
Oddometer: 675
Well in the great white North I have lots of non riding time so in the last month or so:
New facet fuel pump, checked valves, set TPS, balanced carbs, set floats, cleaned carbs, broke carb heater, pulled carbs replaced carb heater, (not in that order)noticed oil sensor wire hanging loose, pulled carbs and air box, plugged wire inreplaced air box and carb, noticed O-rings on carb leaking, pulled carbs, replaced O-rings, replaced carbs re torqued clutch springs, installed new heated grips, bleed brakes, bleed and replaced clutch fluid, new air filter, cleaned pre filter, re wired GPS, added new rally style windscreen, modified seat, added bigger rear brake peg, scraped most of the mud off, cleaned chain, bought 2 Roto pax for next years trip north, oh yeah and put a CJ designs sticker on the new BDCW skid plate removed the fuel tank cross over line and plugged holes, did a flapendectomy
Now it's time to pull the Guzzi in while the 950 sits in the TV room waiting for spring CAN'T WAIT
devildogg is offline   Reply With Quote
Old 12-15-2013, 07:07 PM   #8865
dzrtracin
ride'n 2 live
dzrtracin's Avatar
Oddometer: 2,822
I back tracked my ride from last weekend & found my windscreen, a very sentimental piece to my SE
RIDE ON!
Content, NEVER!
dzrtracin is offline   Reply With Quote
Times are GMT -7.   It's 08:37 AM.
