Old 01-02-2014, 11:00 AM   #8941
howl
990 Adventure
howl's Avatar
Oddometer: 98
Originally Posted by Sumi View Post
Broke the chain.
Unbelievably though, it happened only a couple miles from home and didn't do any major damage, only some scratches on the swingarm:)
10k miles on it..
Looks like it could have done with a bit of lube
howl is offline   Reply With Quote
Old 01-02-2014, 02:07 PM   #8942
DirtyADV
DirtyADV's Avatar
Oddometer: 2,285
Installed some toggle switches for heated grips and aux lights into the stock housing, was tight but possible, should even be possible to squeeze a third in there should I find a need for it:
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 01-02-2014, 05:25 PM   #8943
BykBoy
Meshuganeh
BykBoy's Avatar
Oddometer: 557
Quick Relase for SHED 45 Box
I purchased a used SHED 45 box from an inmate. The box comes with a modular mounting plate. The box connects to the plate with a lockable quick release mechanism. The rack has multiple mounting holes that can be used to attach it to the bike with 4 screws:
The Dirty Dak already has a Black Dog rear rack with a SW-MOTECH horse-shoe style quick release bracket for the KTM Rear Tail bag:
I want to keep the Black Dog plate and the SW_MOTECH bracket, but also have a quick release for the SHED mounting plate.
Solution: make room for the SW-MOTECH quick release horseshoe inside the SHED plate. This is done by cutting the plastic square support ribs on the under side of the plate:
The solution are 4 clevis and 4 cotter pins:
The clevis pins fit exactly into the SHED's plate little red shims. The lanyard cable is there to ensure the cutter pins won't get lost if they slip out of the clevis pins:
The clevis pins are just long enough to make it past the Black Dog plate.
To attach the SHED plate, lower it down onto the Black Dog plate, lining up the clevis pins with the 4 newly drilled holes:
Slide the cutter pins into the clevis pins:
SHED plate and SW-MOTECH are now attached to the Black Dog plate:
And the SHED 45 is mounted on the Dirty Dak with 4 quick release pins:
Total cost for the quick release 8 pins and 2 cable lanyards: $12, including shipping
Save $5 when you open a SmugMug account. Use the following coupon: 4l1hicJzWvYNE
BykBoy is online now   Reply With Quote
Old 01-02-2014, 06:54 PM   #8944
phycospecialties
phycospecialties's Avatar
Oddometer: 47
Pipes
I like this thinking out side the box but, why do you have two different cans??????
phycospecialties is offline   Reply With Quote
Old 01-02-2014, 07:55 PM   #8945
BykBoy
Meshuganeh
BykBoy's Avatar
Oddometer: 557
Left can is a tool box
Old 01-02-2014, 08:16 PM   #8946
Lurkerlou
Lurkerlou's Avatar
Oddometer: 246
SAS removal , Cannisterectomy , Rottweiler air intake , Snap Out Glove ( easy bake oven ) box, Doghouse, and used Tune ECU and uploaded a different map and the bike actually runs ! The last bit I am most proud of as changing the map was the scariest , yet easiest part of the whole project.
Lurkerlou is offline   Reply With Quote
Old 01-03-2014, 09:20 AM   #8947
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,535
Very cool. I plan on adding the intake and toybox soon. I figure when I do the valve check/set in a month or so. I don't have ABS so I'll have a ton of storage under the seat.
Which map did you end up using?
Originally Posted by Lurkerlou View Post
SAS removal , Cannisterectomy , Rottweiler air intake , Snap Out Glove ( easy bake oven ) box, Doghouse, and used Tune ECU and uploaded a different map and the bike actually runs ! The last bit I am most proud of as changing the map was the scariest , yet easiest part of the whole project.:)
...Dick
"You don't go to Mongolia for the food." - Sebastian & Kim
2010 KTM 990 Adventure R
My Life With The 990R
Smugmug
Mr Head is offline   Reply With Quote
Old 01-03-2014, 10:42 AM   #8948
Lurkerlou
Lurkerlou's Avatar
Oddometer: 246
What Did You Do To Your KTM Today?
I used the one from Rottweiler's site listed as "09-13_ADV_990__2_into_1__Rottweiler_Intake"
Unfortunately it's the middle of winter here in Canada so I'll have to pick a good day and go try it out.
I'll be searching for other maps too but needed to get one on and the stock R map off.
No ABS here either , it really is amazing the amount of room under here with the combo.
Lurkerlou screwed with this post 01-03-2014 at 11:13 AM
Old 01-03-2014, 10:51 AM   #8949
Newbusa
Newbusa's Avatar
Oddometer: 613
I have a 990R as well and was told that map would be safe to use. I have dual Akros.
Did you lose the release cable for the glove box lid when you did the conversion to the snap out? Just wondering if I should just yank it out.
2010 990R Adventurer.
2007 Tuono 1000R
Newbusa is offline   Reply With Quote
Old 01-03-2014, 10:58 AM   #8950
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,535
I have a 990 R and I kept the cable attached. It's nice ot be able to lock it.
...Dick
Smugmug
Old 01-03-2014, 11:01 AM   #8951
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,535
I looked at KTM Twins and found a map for the twin akro's and Rottweiler intake for 2011. Should be fine.
We'll see.
...Dick
Smugmug
Old 01-03-2014, 11:18 AM   #8952
Lurkerlou
Lurkerlou's Avatar
Oddometer: 246
Twin Carbon Leo's here and was told the same. I think more and more custom maps will be available very soon.
I personally did ditch the cable but it's very easily reversed anyways.
I didn't want to have the ability to easily remove the glovebox but
not have the ability to put it anywhere but hang it off the side of the bike by the cable.
Old 01-03-2014, 12:40 PM   #8953
Newbusa
Newbusa's Avatar
Oddometer: 613
I think I am going to ditch the cable as well.
2007 Tuono 1000R
Old 01-03-2014, 12:41 PM   #8954
Masso75
Oddometer: 120
a new handlebar is arrived...... Renthal FatBar RC high....
Masso75 is offline   Reply With Quote
Old 01-03-2014, 12:42 PM   #8955
Newbusa
Newbusa's Avatar
Oddometer: 613
We'll see.
I wonder how the 2 maps differ? The 2 into 1 and the one from Ktm Twins?
I have not been able to figure out how to compare 2maps side by side on TuneECU.
2007 Tuono 1000R
Times are GMT -7.   It's 05:49 AM.
