Old 09-24-2010, 06:16 PM   #1021
teambft
teambft
teambft's Avatar
Oddometer: 1,183
Thanks - probably could. I carry bungee cords/tie downs anyhow - if I break 'em, can strap 'em down to get home.
Originally Posted by tomdubz
Is there enough room to attempt a lashing ala crisscrossed zipties?
[/quote]
2011 KTM 300 XC-W, 2001 Aprilia Falco, 2010 KTM 530 XCW Six Days, others
2012 KTM 500 EXC - sold, 950 SER-sold (regret)
Prior: BMW XC, TE610, KLR 650, 07 KTM 990 Adv, and many more ...BMWs, Ducs, KTMs, Harleys
teambft is offline   Reply With Quote
Old 09-24-2010, 06:24 PM   #1022
unaweep
Uses lotsa band-aids
unaweep's Avatar
Oddometer: 19,873
Originally Posted by Mfed
I don't have to be right to argue.
NICO
unaweep is offline   Reply With Quote
Old 09-24-2010, 06:56 PM   #1023
SSrider
SSrider's Avatar
Oddometer: 120
Originally Posted by Tirespin
Bike in sig - 2010 990 Adventure R. I made no other changes. It runs nearly the same, maybe a bit more throttle response, but without the snatchyness from trailing to part throttle. Seems to be the same power - easy rollon wheelies in 2nd, but will only lift a couple of inches in 3rd.
Perfect !! I have always been a fan of FMF products. Thanks for the info.
KTM 990
KTM 640
KTM 520
KTM 380
KAW klx650
Honda xr75
Honda trail 50
SSrider is offline   Reply With Quote
Old 09-24-2010, 07:32 PM   #1024
BikeSDP
Reluctantly Crouched
BikeSDP's Avatar
Oddometer: 499
Fmf Q4
So, didn't the 'You might be a Squid' test include a question about installing aftermarket exhaust before some number of miles have passed?
Did the 15 minute idle thing. Seems to run pretty well, slightly louder, but I'm liking 'em.
BikeSDP is offline   Reply With Quote
Old 09-25-2010, 12:37 AM   #1025
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,849
640ADV/625SMC
not much just a complete rear end swap today
sorry about the shit pics but was busy wanted to get some more done.
usual clic pick for BIG:
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls screwed with this post 09-25-2010 at 01:57 AM
veetwo _tls is offline   Reply With Quote
Old 09-25-2010, 12:56 PM   #1026
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,947
Guys, Check your Lower Radiator Mount for Looseness
I noticed my lower radiator mount had been moving left & right on the shoulder bolt that threads into the oil tank.
I added 1 thick washer as a shim after this pic . . . [i like using washers or shims to tighten up loose components wherever possible]
sorry for the blurry pic, but you get the idea
Brown Dog screwed with this post 09-25-2010 at 02:42 PM
Brown Dog is offline   Reply With Quote
Old 09-25-2010, 07:31 PM   #1027
teambft
teambft
teambft's Avatar
Oddometer: 1,183
Installed an ABS bypass rocker switch! Should have done it the day I bought it.
Old 09-25-2010, 08:38 PM   #1028
Eddieb
Eddieb's Avatar
Oddometer: 988
Fitted a new airfilter and Uni Prefilter, and new exhaust gaskets as my bike didn't have any and the join was leaking.
'05 DR650 - '06 Wee Strom - '86 BMW R80 with Velorex sidecar - '67 Ducati 250 Mark 3 Narrow Case
www.AdventureRidingNZ.co.nz Free GPS tracks for New Zealand, over 60 Owners and workshop manual downloads, ADV bike specs chart & more
Eddieb is online now   Reply With Quote
Old 09-26-2010, 06:04 AM   #1029
adiablolex
Lost again
adiablolex's Avatar
Oddometer: 3,692
hey BG, I think you gots the wrong bolt on the rad mount. The ones that hold the oil tank on have a longer shoulder than the rad ones, worth a check
DRCOOL rides with me
adiablolex is offline   Reply With Quote
Old 09-26-2010, 11:22 AM   #1030
Brown Dog
Brown Dog's Avatar
Oddometer: 1,947
You may be right, but it came brand new like this
I lost one of the oil tank bolts on the left side & noticed it had a shorter shoulder
when I ordered & replaced it.
Old 09-26-2010, 11:27 AM   #1031
Cyath
Impetulant Ignoramus
Cyath's Avatar
Oddometer: 432
2010 990 Adventure.
Only 4500 miles, about 500 of which were dusty desert riding.
Did an oil/filter/screen change last week.
Threw on new TKC 80''s last week too.
Yesterday, did an air filter change. Glad I did, that thing was really dirty from breathing dust. I wish I could do the same for my lungs.
I learned how to wrench on my R1200GS, and seeing the complexity of this bike and how it's put together, I'm not sure I'll ever let the dealer touch the bike unless it's a big warranty issue. You can't rush through work on this bike.
"You think I can remember what you posted a year ago? I can't remember what kind of beer I drank for breakfast." -SScratch
'10 KTM 990 Adventure aka The Spork
Cyath is offline   Reply With Quote
Old 09-26-2010, 04:01 PM   #1032
Orangecicle
Quest Adventurer
Orangecicle's Avatar
Oddometer: 2,729
New Horns!!!
First, I finished the install of some Fiamm El Grande horns on the old 950:
It's a really tight fit, but it works. For $19 US, the KTM now sounds like a Cadillac! Lovin' that!
Next, I removed the PO's PIAA driving light setup. That is going to be a winter project of relocating the old PIAA's to the crash bars.
Finally, I finished an unfinished project of rejetting the bike to Pyndon specs, or at least as close as I can come.
Mains: 158 front / 160 rear
Idle jets: 42s
Float height: 3.5
Mix screws out: 2 1/8 front, 2 3/8 rear
Needles: middle position (#3): Pyndon uses stock needles, but I only have Factory Pro sets, so I'll have to use those for now.
I finished out by syncing the carbs with the CB Performance gizmo and setting the Throttle Position Sensor (it was a bit off). The end result is fabulous. The bike now has a consistent idle, is powerful throughout the RPM range, and I bet will have much better MPGs than ever before. If I can keep my right wrist out of it.
Orangecicle screwed with this post 09-26-2010 at 04:11 PM
Orangecicle is offline   Reply With Quote
Old 09-26-2010, 10:05 PM   #1033
EdGear
Edventurer
EdGear's Avatar
Oddometer: 534
Had some time in the garage today, I installed some auxiliary lights from Dustjunkie, cleaned up some other wiring.
These lights are hard to describe, out of this world. (Thanks DustJunkie)
Low Beam, pathetic (street light in the distance)
Low + HID High beam, HID is bright
Low +LED, LED is bright too and can be aimed to give wider view
Low + LED + HID high, I'm going to get a ticket
In the couple weeks I've also put on a headlight guard (Thanks Metal),
adjustable folding mirrors (Thanks Jori)
and a TT locking Zumo mount (Thanks Pairowheels)
2010 KTM 690 Enduro R
2006 KTM 950 Adventure S
2002 KTM 400/453 EXC
EdGear is offline   Reply With Quote
Old 09-26-2010, 10:28 PM   #1034
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 2,163
Straightend out front break pedal after dropping it on some rocks!
My EXC530 Adventure
My KTM690 Adventure
2008 250 Beta Rev3 - Trials with lots of errors
Night Falcon is offline   Reply With Quote
Old 09-27-2010, 08:48 AM   #1035
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,468
so where is your rear brake pedal if that's your front?
Times are GMT -7.   It's 02:56 PM.
