Old 05-21-2010, 08:03 AM   #61
claude
Sidecar Jockey
Oddometer: 3,915
If anyone building their own leaner, or contemplating doing so it is essential to understand that there are heim ends and their are heim ends. Going with cheap ones is setting yourself up for a possible disaster. You will find that pricing varies a lot. Look at the rating of the heim ends.
Alos , as far a double shear goes it isn't really necesary in th eright application althoiugh, barring any clearanc eissues, will never be a bad idea.
In single shear it is not a bad practice to design the retaining bolt to work in conjunction with a washer or some type of enlarged end to assure the heim end ball cannot come out of it's home in case of a mishap or unwanted impact.This is overkill but so what.
Heim ends will wear in time and some 'slop' can become evident. Check them for play from time to time.
I am not a huge fan of the ones with grease fittings on them but if they are rated you may want to consider them.
Also, it is best practice to leave as few exposed threads as possible when installing them. And by all means use a jam nut as you do not wan tth eehreads 'working' back and forth.
There are rubber type dust covers avaiable to better protect the ball areas. This may extent life of the unit. It can also retain some slight amount of grease without making a mess. You can find these at speedwaymotors.com among other places.
If a choice is available within design parameters between large and small go large! This will give more bearing area and provide longer life over and above obvious strength ratings.
I would not be tempted to use tie rod ends for pivots. Some have tried this and it just has too many downsides. Strength may be there but typical manufacturing tolerances are not within what one really needs. Sometimes what seems to be a cost saved does not translate into being the best value for many reasons.
Just opinions of course.
Safety is always what must come first followed very closely or directly paralleled by function. Looks take a back seat. The best designs, such as Kalich and others, are those that combine all of these things into a clean looking workable system.
Claude
http://freedomsidecars.com/
Old 05-21-2010, 08:39 AM   #62
Mac OP
Mac's Avatar
Oddometer: 2,153
Before going with the Kalich, I was considering a direct build myself. Now that I've seen the quality and level of engineering required, I'm glad I didn't attempt it myself. I'm not that smart or skilled.
For reference, Ralph Kalich uses 20mm heim joints in his design. Something like this: http://www.mcmaster.com/#59935k48/=76q6dv (these have a 12,836 load capacity each).
And as you allude, it's not just the hiem ends themselves, but the design of the mounts around the joints.
Mac
R1200GSA | 690E | 300XCW
RMAR President - Website FaceBook
Member: NRA, AMA, TPA, MSF RC
Mac is offline   Reply With Quote
Old 05-21-2010, 08:49 AM   #63
Arthurwg
Oddometer: 97
I used leather "gaiters" to cover the ball joints on the front end of my Series 3 Land Rover. Worked great in the Sahara and everywhere else. They were a Land Rover part, but you could easily make some for your application.
Arthurwg is offline   Reply With Quote
Old 05-21-2010, 12:29 PM   #64
claude
Sidecar Jockey
Oddometer: 3,915
I am quite confident that Ralph Kalich has his act together. No one who manufactures anything such as a sidecar ever wants to have failures etc or underdesigned products out there.
McMaster Carr is a good source for many items such as this. Notice thgat at 33 bucks plus these are not your typical el cheapo heim ends.
Some are doing what you call 'direct builds' of leaners and many seem to do well. I am definately not a very knowlegeble 'leaner person' and have never built one but may do so at some point. There IS quite a bit of geometry concerns invloved to arrive at the best combination of weight bias, what leaning does to the camber of the sidecar wheel, what leaning does to to the toe in, how much wheel lead is best for a given outfit if any, and so on. Apparently the concensus of these questions is not settled as it seems alot of different ideas are still out there.
Claude
Old 05-22-2010, 03:57 PM   #65
Willi-Jens
Oddometer: 284
Very good post!
Willi-Jens is offline   Reply With Quote
Old 05-22-2010, 04:03 PM   #66
Willi-Jens
Oddometer: 284
Thought so myself. Doubtful that one is able to match that on a first or even second attempt.
I would buy again anytime. Imho worth every penny/cent.
Very much so.
Old 05-22-2010, 04:15 PM   #67
Willi-Jens
Oddometer: 284
Claude,
the sidecar wheel on a Kalich/Armec Sidewinder leaner just runs beside the bike to spport the main weight of the sidecar. It should be small/narrow (better motorcycle tyre in small/narrow dimensions, don't use a car tyre) and possibly better equipped with a tyre of low grip.
The camber should be basically of low to no impact (the bike still runs like a solo), imho just make it vertical with no camber.
The toe in should be able to be adjusted in one way or the other, but with the front mount higher and a small/narrow tyre the leaning shouldn't be of concern. One will need the toe in adjustment to get neutral handling at your touring speed.
Some wheel lead seems advisable due to the pushing/pulling of the sidecar wheel while leaning in/out (refer to the videos in post #23: http://www.advrider.com/forums/showt...=525279&page=2).
Regards
Jens
Willi-Jens screwed with this post 05-22-2010 at 08:36 PM
Old 06-08-2010, 04:01 PM   #68
Willi-Jens
Oddometer: 284
The sidecar fiberglass and bike plastics are still with my painter, but I hope to be assembling within a week...
Mac
How are the first impressions or is it still unfinished?
Regards
Jens
Old 06-08-2010, 07:02 PM   #69
Mac OP
Mac's Avatar
Oddometer: 2,153
Originally Posted by Willi-Jens
Mac
Regards
Jens
Nice timing. I got the parts from the painter back late last week, and put it all together this past few days. Today, I got it out on the road for a few minutes, and realized I needed a bit of alignment. It was pretty close, so I did the wheel alignment but still have to get it out on the road.
Too early for driving impressions, but it definitely looks awesome. I'll try and snap some pics when I take it out in the morning.
Stay tuned...
Mac
Old 06-22-2010, 03:00 PM   #70
Willi-Jens
Oddometer: 284
still tuned...
Is the weather still not better?
Old 06-22-2010, 03:38 PM   #71
roadracer
roadracer's Avatar
Oddometer: 344
I haven't even picked up my sidecar yet and this thread managed to make me dislike leaners and the people who ride them!
What a bunch of pompous asses, haha!
roadracer is offline   Reply With Quote
Old 06-23-2010, 08:33 AM   #72
Mac OP
Mac's Avatar
Oddometer: 2,153
Eww, a squid farted in the thread.
Mac
Old 06-23-2010, 08:40 AM   #73
Mac OP
Mac's Avatar
Oddometer: 2,153
still tuned...
The weather is fine, that's the problem. Riding.
So, I got out this morning for a ride and snapped a few pictures. They're uploading now, and I'll put them up in my next post.
Mac
Old 06-23-2010, 08:56 AM   #74
Mac OP
Mac's Avatar
Oddometer: 2,153
Finally, I've managed to get the leaner all set up properly and out on the road for a few hundred miles. It's running perfectly. We hit a few snags along the way, but Ralph got those ironed out quite nicely.
As promised, here are the completed pictures. You can click on any of these pictures and will get a high-resolution version.
All these were taken around 0730 Local, with the sun on the east side of Pikes Peak. In the mid-ground, you can see parts of the "Garden of the Gods Park". In the upper left of the third picture, you can see Cheyenne Mountain - inside is where NORAD tracks Santa Claus, and does a few other things.
Mac
Old 06-23-2010, 09:27 AM   #75
Qwik
Adrenaline Addict
Oddometer: 6,922
Gorgeous paint and the graphic is Very Well done.
Topes never seem to make me go any faster.
Qwik is online now   Reply With Quote
Times are GMT -7.   It's 10:54 AM.
