Old 10-03-2011, 03:12 PM   #136
JoelSchmenge
JoelSchmenge's Avatar
Oddometer: 240
My 450X
Hey all,
My bike looks exactly like Daffy67's, it is an '09 with JD jet kit, Twin Air, backfire screen removed, baffle cut in half and screen re-installed..... and for all the good 'ol U.S. of A. folks the piece de resistance...
A FREAKING LICENSE PLATE HERE IN GEORGIA!.... best damn mod ever, and easy as all get out, couldn't frigging believe it.
Just thought I would rub it in... will post pic's later.
"Every tool is a hammer, except screwdrivers, those are chisels."
JoelSchmenge is offline   Reply With Quote
Old 10-04-2011, 12:05 AM   #137
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,890
Honda will be selling 2012 450x's !!!
wrk2surf is offline   Reply With Quote
Old 10-05-2011, 04:21 AM   #138
AndyCBR
Oddometer: 122
Setup for tight hare scrambles
Hey guys I need some help.
I am a 250# novice rider doing some hare scrambles here in LA.
I bought the 450x for running this series and as an all around "dirt bike" and maybe to run a few practice days at motocross tracks . My XR6550L while a great machine isn't really suited to full time dirt use.
We run in some really tight stuff and I struggle with the X. It seems like if you are in first gear and breath on the throttle it bites and heads in whatever direction it is pointed regardless of the bars. So in the goat trail stuff I go from left to right and struggle just to hang on. This being said the power sure is nice when you come to a steep sandy hill with no drive beforehand.
I also had a lot of trouble with stalling in tight stuff and bought a rekluse Z start which helped a lot. I was thinking of moving some of the settings to softer engagement but am worried about heat and wear.
The suspension is resprung for my weight and I have all the clickers 5 above full soft. I was thinking about backing off the rear preload all the way to make it really soft in back. Tires at 13 front 12 rear.
Thinking of trying a flywheel weight next since it is relatively cheap and easy.
Some of the other dudes in my class say "get a KTM" or "450 is too big" or "you need a 250 2 stroke". While some of those may be true I do plan to run the bike I have at this point.
Any advice would be appreciated.
Thanks,
Andy
2012 Super Tenere/2009 crf450x/2006 sm610/2003 xr650l/1990 cbr1000f
"The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles." - Jeff Cooper
AndyCBR is online now   Reply With Quote
Old 10-05-2011, 06:46 AM   #139
header
Chris
header's Avatar
Oddometer: 1,746
How slow are you going? Does it seem like your always moving the bars a lot, as in very far one way then very far the other way? Going a little bit faster will help to stabilize the bike and get you into (hopefully) a good RPM range to have useable power but not too much that you can't control the bike.
KTM 530exc
525exc refresh
header is online now   Reply With Quote
Old 10-05-2011, 06:53 AM   #140
AndyCBR
Oddometer: 122
Pretty slow. A couple of places last weekend were barely wider than the bars. No doubt technique has a lot to do with it too. Just looking for it not to hit so hard coming off idle (I do have a jd jet kit).
Old 10-05-2011, 07:00 AM   #141
header
Chris
header's Avatar
Oddometer: 1,746
It sounds like the same thing I used to battle with. More time in singletrack will get you used to riding in tight stuff and the speed will follow. Im not talking a bunch of speed but once you reach a breaking point (you'll feel it) in speed the bike will stabelize and you won't have to try to maintain balance all the time. Plus the jerky throttle will go away once you start to flow and aren't either "on or off" with the throttle.
What it amounts to is more seat time in the nastiest singletrack you can find.
KTM 530exc
525exc refresh
Old 10-05-2011, 06:21 PM   #142
AndyCBR
Oddometer: 122
Thanks for the advice. I kinda thought that had alot to do with it. Ive felt that flow on sections that were a little more open. One hare scramble my lap times actually went down throughout the 1.5 hrs as I was getting better with the course (even though I know fatigue was setting in).
I'll keep it up. Now if I can only keep from getting run over by the expert class guys coming up behind me....
Later,
Andy
Old 10-05-2011, 11:41 PM   #143
Skinsfan6
Oddometer: 5
Do any of you have a tach and speedo on your 450X? My dad has an 05 he doesn't ride anymore that I really want put plates on, but I'm worried about highway rpms. So can anyone tell me rpms at 60? Or if anyone has a speedo and no tach...what speed are you comfortable cruising at in fifth for long periods of time?
Thanks in advance.
04 Kawasaki Concours - pretty much stock, pretty much perfect
96 Yamaha XT350 FOR SALE- airbox mods, debaffled, both carbs rejetted, modern front fender, homemade turn signals
06 Yamaha YZ250
Skinsfan6 is offline   Reply With Quote
Old 10-06-2011, 07:13 AM   #144
pilo
Rhymes with below
pilo's Avatar
Oddometer: 944
Andy,
What gearing are you using. In the tight stuff you need a pretty good sized sprocket on the back (at least a 51) and a 13 on the front.
Also, set your sag by the book and make sure you have the right spring. Backing down the preload to make it softer will make things a ton worse for handling. You'll have a crazy hard time making it turn in the tight.
Enjoy
pilo is offline   Reply With Quote
Old 10-07-2011, 10:06 AM   #145
AndyCBR
Oddometer: 122
Originally Posted by pilo View Post
Andy,
Enjoy
I did switch to a 12t front (from stock 13) with the stock rear (to avoid chain length issues).
The spring was sized by cannon racecraft and I did set the sag by the book.
The bike still seems to beat me in the butt alot but I think I spend alot more time on the seat than on the pegs as I get tired toward the end of the main.
I'll keep plugging away at it...
Thanks.
Old 10-14-2011, 10:30 AM   #146
helipilot650l
Sweet!!!!!!
helipilot650l's Avatar
Oddometer: 173
CRF450X Photos
Hey Guys Keep sending in those photos of your CRF!!! We need to keep this thread going. Still looking for a Factory Honda speedo for my 450X. Any one out there know where to pick one up?
When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return.
helipilot650l is offline   Reply With Quote
Old 10-14-2011, 12:12 PM   #147
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,523
I've got 1 thats mint, PM me if interested, have pics of it also.
Marko
08 xr650l ,99 xr650l, 10 HDXR1200X ,84atc200s 85atc200s, 80ct110 ,99xr70, 04xr650l ,
Dumb ass people do dumb ass things
thebigman is offline   Reply With Quote
Old 10-14-2011, 09:24 PM   #148
helipilot650l
Sweet!!!!!!
Oddometer: 173
CRF Speedo
Send Me some pics, Where in Texas are you from. I am working in MT Pleasant.
Old 10-15-2011, 06:42 AM   #149
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,523
I'm in Galveston, check it out
also , If someone is looking for a nice new mint pristine rear assy , for a spare , check this baby out , off an 09
have some other mint stuff also .
Marko
Old 10-15-2011, 09:00 AM   #150
helipilot650l
Sweet!!!!!!
Oddometer: 173
Thats Not A Speedometer!!!
Thats the stock odometer. I want the Digital Speedometer that comes one the Austalian Bike.
Times are GMT -7.   It's 05:24 PM.
