04-22-2010, 06:03 PM
#16 | |
Wanna-be Adventurer
Oddometer: 104
2006 SV1000S 2008 Ninja 250R 2007 DRZ400S 2003 Track Bike Project..... Southern Boyz invade Colorado |
04-22-2010, 06:07 PM
#17 |
Urban dirtbiker
Oddometer: 81
For engine longevity I would jet it rich to help keep it cool since it doesn't have a fan and every little bit helps.
That's not how you change a tire. He's suposed to be flailing around on a nasty garage floor with those cheapo 8" irons the rest of us have. |
04-23-2010, 04:17 PM
#18 |
Adventure? Yes, Please...
Oddometer: 9
Definitely jet the bike properly. It makes a big difference in how the bike runs. I too have a CRF450X, and love it. I'm in Southern California (0-6000 ft), and have a mostly stock bike (stock exhaust, stock motor) and am running a 165 main, and 45 pilot; but I did take the "snorkel" off the top of the airbox underneath the seat. Also, if you don't have one already, get an adjustable fuel screw. I run Engine Ice coolant, and it seems to help keep the bike cool. Enjoy your new ride...
04-23-2010, 04:28 PM
#19 | |
Wanna-be Adventurer
Oddometer: 104
I did purchase a Flex-Jet also, and still waiting on my JD jet kit. The stock jet (142) is what is in the bike now, the PO had a couple of extra jets that he had tried, a 145 and 148, but judging from everyone else's settings (good setup info on CRF's Only), I'm probably looking at needing a 160 or close to it. It still has stock exhaust and header and I'm going to do the airbox mod this week, plus draining the coolant and replacing with Engine Ice, so hopefully by the time I get the jet kit in and installed, she'll be ready to fire up!! Unfortunately I've only ridden the bike twice, due to the poor jetting....
04-23-2010, 04:55 PM
#20 | |
Oddometer: 9,698
So you're letting the bike sit for 8-10 min on enrichner, bumping the idle screw so it will run without throttle? This is a sure-fire recipe for glowing headers and an overheated bike. I suspect there is absolutely nothing wrong with your bike. You need to start it up and as soon as it will take throttle, start riding gently. Get it off the enrichner ASAP. - Mark |
04-23-2010, 05:11 PM
#21 | |
Wanna-be Adventurer
Oddometer: 104
04-23-2010, 06:26 PM
#22 |
Guest
Oddometer: n/a
2006 CRF 450X - This is a great bike
Guys, For what it is worth, I have a 2006 CRF 450X and I have not had any problems with it. And it is for sale! I am replacing it with a KTM 525 EXC. Time will tell if it was the right thing to do.
04-27-2010, 06:45 AM
#23 | |
Oddometer: 80
I also like Sanford and Son but, since I am not a junk dealer in 1970's Watts, I find it hard to criticize his methods. '01 Connie '83 XT 550 '78 XL 350 '73 XL 250 '72 XL 250 (Needs "assembly")
04-27-2010, 07:47 AM
#24 | |
Oddometer: 9
Checking the air boot described above is also good to do, just to rule it out and make sure it won't be an issue after you do your mods. |
04-30-2010, 09:21 AM
#25 |
Wanna-be Adventurer
Oddometer: 104
Finally got a chance to work on the bike.....
Installed JD jet kit (165 main jet with red needle on 4th clip) Changed engine oil Changed tranny oil (Running 1 full quart) Replaced antifreeze with Engine Ice Airbox Mod Installed new Racelite battery Wrapped header Installed Flex Jet screw As soon as the carb primed up, it started right away, idled like a champ, and came off of choke within 1 minute with no stumble, and revved with no backfiring!!!! Took it for a quick run down the road, WOW, it has a nice mid-range grunt that it didnt have before, and it took some effort to keep the front end down under acceleration. It's like a new bike.... Thanks everyone for the tips and advice, can't wait to put it through its paces and fine tune the carb, if it even needs it....... Thanks again!
07-01-2010, 02:51 AM
#26 |
Richie76
Oddometer: 1
Just sold my XR650R (pretty sad about it) and got brand new X set up with TRX piston and SS valves, the whole bit. Going in an 500km enduro race in a few weeks and now have to go thru the drawn out task of setting up suspension from square one.
Have standard springs at this point, I weigh 100kgs, don't suspose anyone knows if standard will be heavy enough? Richie Mc screwed with this post 07-06-2010 at 03:07 AM |
07-22-2010, 11:14 PM
#27 |
BITD/Rallye
Oddometer: 5,305
Honda Crf 450X Thread
![]() Its time for a new thread.. I have looked around and there seems to be no 450x thread.. I have a new (to me) 05 450 x with 80ish hrs and some mods... seems like this needs doin.. if you have mods please put em in here or link old mods to this one... Will do a oil change tomorrow and will start with that...
Mike
Thanks for the 2013 support: DUNLOP, BELL HELMETS, Kriega USA, Carbon-pro.com, Ride 100% Goggles, Renazco Racing, Sidi/Motonation, Acerbis USA,KLeN, FMF, Mx1west,,Masters paint and body, Magura , motolab ,and Freedom Cycle |
07-23-2010, 06:39 PM
#28 |
BITD/Rallye
Oddometer: 5,305
Going over some things beside the normal air box, smog block, pink wire. There are some new radiators with oil cooler built in(= more oil) made by PWR a ozzie outfit offered by Chris Blais here.... http://blaisracingservices.com/Honda.../prod_596.html
When doing a oil and tranny change today I ran into this same issue.. http://www.thumpertalk.com/forum/arc.../t-667390.html and may have a long tap in my future... I was also informed the 05's have a 3rd gear issue and maybe should be replaced by a 06 or 07 slightly different machined gear.. also was told that using 1ltr in the tranny as opposed to .74 will help a bit... Now to test it again tommorow!
07-26-2010, 08:36 PM
#29 |
BITD/Rallye
Oddometer: 5,305
08-09 decomp pin issue
During high-load operation at extremely low
rpm, the crankshaft may experience instanta- neous reverse rotation that momentarily extends the decompressor plunger. The extended decompressor plunger can collide with the rocker arm with enough force to pos- sibly damage the actuation pin on the decom- pressor shaft. If the decompressor actuation pin is bent or broken the engine will not start. The UPDATE PROCEDURE outlined in this Service Bulletin will replace the decompres- sor shaft and plunger on 2008-2009 CRF450X models with more durable components. link to pdf bulletin... via crfs only dot com http://www.crfsonly.com/forum/images...__r36__web.pdf
07-26-2010, 09:30 PM
#30 |
867-5309
Oddometer: 2,528
Interesting. I guess I must have the "more durable components" in my 2005 model.
DO WHAT YOU LIKE - LIKE WHAT YOU DO Explain to me again why enjoying life when I retire is more important than enjoying life now? |
