01-03-2013, 08:17 AM
#286 | |
Oddometer: 13
01-03-2013, 08:03 PM
#287 |
Oddometer: 13
Stock CRF 450X muffler is 7.9lbs
Shhhhh don't tell my wife I took her scale down to the garage
01-04-2013, 05:42 AM
#288 | |
Says who?
Oddometer: 372
Explain that one if you can! Honey.......... this inmate, I mean this fellow motorcyclist..........
"What could possibly go wrong"
01-09-2013, 04:00 PM
#289 |
we build, we fight
Oddometer: 1,729
calling an illegal alien an "undocumented immigrant" is like calling a drug dealer an "unlicensed pharmacist" "If guns cause crime, then all of mine are defective." Ted Nugent |
02-05-2013, 08:08 AM
#290 |
Sweet!!!!!!
Oddometer: 137
CRF450X Gas tank
Hey guys I can't decide on what big tank to put on the CRF. Any thoughts. Some have radiator protectors biult in. But can't decide. Please help!!
When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return. |
02-05-2013, 08:23 AM
#291 | |
Oddometer: 115
I've got the IMS 3.2gal and it works with Works Connection Rad braces/stock rads and the stock plastics. Hope this helps.. Andy
2012 Super Tenere/2009 crf450x/2006 sm610/2003 xr650l/1990 cbr1000f "The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles." - Jeff Cooper |
02-09-2013, 09:11 AM
#292 |
Oddometer: 476
My CRF leaked out all its tranny fluid.
I had a look, and it seems that it's the output shaft seal behind the front sprocket. Motor oil level is fine. So did some research and it seems that you can pull the seal and replace without splitting the cases, but it looks like a fiddly job. While I have the thing down, I would also like to address the Clutch grab issue. What happens is you get no fine "clutch release". As you let out the clutch its like this ...nothing...nothing...nothing: FULLRELEASE which is not a porn-tastic as it sounds. Clutch does not slip, it just is like an ON/OFF switch What do you guys think the issue might be there? What to look for? --Nick |
02-09-2013, 09:31 AM
#293 | |
Oddometer: 241
1976 KZ900A4 1985 CR250R 2006 CRF450X(Baja ready baby!!) Team Hammernutrition/T&S Motorsports |
02-09-2013, 10:11 AM
#294 | |
Oddometer: 476
The oil did not really come out until after it was parked. Of course it's impossible to really know because they did not see fit to put a freaking dipstick on the transmission oil. Gotta keep the weight down, huh? I was running a full quart of oil in the trans, FWIW. The bike is a 2005. I have no idea how many hours are on the bike or clutch. I see parts and pieces in my future! thanks! --Nick |
02-11-2013, 01:24 PM
#295 |
Oddometer: 241
When you buy your seal and clutch parts pick up an hour meter. They don't cost much and make it easyer to keep track of the maint. I bought one when I bought my CRF/X and base all of my work off of that and my service notes. BTW, hot spots on the metal plates will make a clutch "grabby".
02-11-2013, 05:44 PM
#296 | |
we build, we fight
Oddometer: 1,729
02-12-2013, 10:09 AM
#297 | |
Oddometer: 808
02-26-2013, 07:07 AM
#298 | |
Oddometer: 476
So the proper method is: Bike on stand such that the rear wheel is in the air, and suspension is fully extended. At the end of the chain slider (top) push down on the chain and measure from top of chain to bottom of swing arm. Push up on chain and measure to stop of swing arm. Difference should be 25-30mm (~1 inch). Sound about right? --Nick |
02-26-2013, 11:32 AM
#299 |
we build, we fight
Oddometer: 1,729
man, i love this machine!
03-09-2013, 10:38 PM
#300 |
Sweet!!!!!!
Oddometer: 137
Anyone with a plated crf450x in Oregon?
